Can't reproduce. What other plugins do you have loaded? I got the plugins listed in my sig, but after installing beta 4 I can't reproduce this using the same playlist, so I can't be bothered about it. You made a great plugin whichever way you look at it. Hmm I think I was too hasty saying I had no problem.... Now it looks like when I enable playlistdragging (in b4 ofcourse), I restart foobar, I drag one playlist, I remove another playlist and then try dragging again an other playlist, foobar shuts down at this last action...and now I also get a failure log :-)Illegal operation: Code: C0000005h, flags: 00000000h, address: 00426B76h Access violation, operation: read, address: 01D8E888h Call path: WinMain=>app_mainloop This is the first crash logged by this instance. Code bytes (00426B76h): 00426B36h: 00 A1 38 59 44 00 83 C4 10 3B C3 7C 20 8B 0C 86 00426B46h: 8B D0 EB 05 8B D1 8B 0C 8E 3B C8 75 F7 B9 28 59 00426B56h: 44 00 89 15 38 59 44 00 E8 92 AB 00 00 A1 38 1B 00426B66h: 44 00 83 F8 FF 74 16 8B 0C 86 8B D0 EB 05 8B D1 00426B76h: 8B 0C 8E 3B C8 75 F7 89 15 38 1B 44 00 8D 4D FC 00426B86h: E8 8B F4 FD FF FF 75 0C 56 E8 0C 00 00 00 59 B3 00426B96h: 01 59 5E 8A C3 5B C9 C2 08 00 55 8B EC 83 EC 18 00426BA6h: 53 8A 1D 70 59 44 00 56 68 E0 AD 43 00 8D 4D E8 Stack (0012FD40h): 0012FD20h: 00D2F8D4 77FA88F0 77F521E0 0000005E 0012FD30h: 00D2D078 C0000005 00D2D054 00D2D064 0012FD40h: 0000000C 77D45F0E 00445954 0012FDD8 0012FD50h: 00F574F2 01CCE860 00000011 0012FE4C 0012FD60h: 00F571EB 00000000 FFFFFFFF 0012FD98 0012FD70h: 77D43A50 001003B8 00000020 001003B8 0012FD80h: 02010001 00F571EB DCBAABCD 00000000 0012FD90h: 0012FDE0 00F571EB 01CCE860 00000044 0012FDA0h: 00000044 00000000 00000256 0000000A 0012FDB0h: 00000004 00000234 00000010 00000006 0012FDC0h: 0000000D 00000011 0000000C 0012FE5C 0012FDD0h: 00F6368C 00000001 0012FE04 77D43A50 0012FDE0h: 001003B8 00000200 00000001 00100234 0012FDF0h: 00F571EB DCBAABCD 00000000 0012FE4C 0012FE00h: 00F571EB 0012FE6C 77D43B1F 00F571EB 0012FE10h: 001003B8 00000200 00000001 00100234 0012FE20h: 0012FF00 0012FEF8 006149D8 0012FEF8 0012FE30h: 00000000 00000001 00000014 00000001 0012FE40h: 00000000 00000000 00000010 00000000 0012FE50h: 00000000 0012FE20 0012F968 0012FEBC Registers: EAX: FFFFFFFE, EBX: 00000000, ECX: 0003000A, EDX: 0003000A ESI: 01CCE860, EDI: 0044591C, EBP: 0012FD4C, ESP: 0012FD40 Crash location: "foobar2000", loaded at 00400000h - 00451000h Loaded modules: foobar2000 loaded at 00400000h - 00451000h ntdll loaded at 77F50000h - 77FF7000h kernel32 loaded at 77E60000h - 77F46000h USER32 loaded at 77D40000h - 77DCC000h GDI32 loaded at 77C70000h - 77CB0000h ADVAPI32 loaded at 77DD0000h - 77E5D000h RPCRT4 loaded at 78000000h - 78086000h ole32 loaded at 771B0000h - 772D1000h COMCTL32 loaded at 71950000h - 71A34000h msvcrt loaded at 77C10000h - 77C63000h SHLWAPI loaded at 70A70000h - 70AD5000h utf8api loaded at 10000000h - 1000D000h comdlg32 loaded at 763B0000h - 763F5000h SHELL32 loaded at 773D0000h - 77BC2000h foo_abx loaded at 008D0000h - 008DA000h foo_ac3 loaded at 008E0000h - 008F0000h foo_albumlist loaded at 008F0000h - 008FA000h foo_bitcompare loaded at 00900000h - 00908000h foo_burninate loaded at 00910000h - 0091B000h VERSION loaded at 77C00000h - 77C07000h foo_cdda loaded at 00920000h - 0092E000h foo_clienc loaded at 00930000h - 00944000h foo_console loaded at 00950000h - 00958000h foo_diskwriter loaded at 00960000h - 0096E000h foo_dsp_crossfade loaded at 00970000h - 00977000h foo_dsp_crossfeed loaded at 00980000h - 00986000h foo_dsp_extra loaded at 00990000h - 009A5000h foo_dsp_nogaps loaded at 009B0000h - 009B7000h foo_dsp_pause loaded at 009C0000h - 009C7000h foo_dsp_skip_silence loaded at 009D0000h - 009D7000h foo_dynamics loaded at 009E0000h - 009E7000h foo_faac loaded at 009F0000h - 00A23000h foo_freedb loaded at 00A30000h - 00A5E000h WS2_32 loaded at 71AB0000h - 71AC5000h WS2HELP loaded at 71AA0000h - 71AA8000h foo_history loaded at 00A60000h - 00A6E000h foo_id3v2 loaded at 00A70000h - 00A96000h MSVCP60 loaded at 55900000h - 55961000h foo_input_std loaded at 00AA0000h - 00B39000h MSACM32 loaded at 77BE0000h - 77BF4000h WINMM loaded at 76B40000h - 76B6C000h foo_masstag loaded at 00BC0000h - 00BD0000h foo_null loaded at 00BD0000h - 00BD7000h foo_output_std loaded at 00BE0000h - 00BE9000h foo_out_dsound_ex loaded at 00BF0000h - 00BF9000h DSOUND loaded at 73F10000h - 73F65000h foo_out_ks loaded at 00C10000h - 00C1B000h SETUPAPI loaded at 76670000h - 76757000h foo_read_http loaded at 00C20000h - 00C29000h foo_rgscan loaded at 00C30000h - 00C3B000h foo_search_ex loaded at 00C40000h - 00C48000h foo_shuffle loaded at 00C50000h - 00C5D000h foo_toolame loaded at 00C60000h - 00C73000h foo_ui_std loaded at 00C80000h - 00C97000h foo_unpack loaded at 00CA0000h - 00CD1000h OLEAUT32 loaded at 77120000h - 771AB000h foo_vis_manager loaded at 00CE0000h - 00CE8000h foo_wma loaded at 00CF0000h - 00D09000h WMVCore loaded at 08530000h - 0872D000h WMASF loaded at 07260000h - 07299000h foo_mpeg4u loaded at 00D10000h - 00D39000h foo_stfu loaded at 00D40000h - 00D47000h foo_addall loaded at 00D50000h - 00D56000h MSVCR70 loaded at 5D000000h - 5D04C000h foo_audioscrobbler loaded at 00D70000h - 00D92000h LIBCURL loaded at 00DA0000h - 00DB9000h foo_bluetooth_ctrl loaded at 00DD0000h - 00DE1000h MSVCP70 loaded at 5D080000h - 5D0F8000h foo_custom_sort loaded at 00DF0000h - 00DFA000h foo_delete loaded at 00E00000h - 00E06000h foo_infobox loaded at 00E10000h - 00E23000h foo_nero loaded at 00E30000h - 00E40000h MFC42 loaded at 73DD0000h - 73EC2000h foo_pl_hopper loaded at 00E40000h - 00E46000h foo_quicktag loaded at 00E50000h - 00E5C000h foo_setyear loaded at 00E60000h - 00E73000h foo_syfm loaded at 00E80000h - 00E8A000h foo_text loaded at 00E90000h - 00EA3000h foo_tunes loaded at 00EB0000h - 00F00000h uxtheme loaded at 5AD70000h - 5ADA4000h foo_ui_columns loaded at 00F50000h - 00F70000h foo_web loaded at 01070000h - 01088000h foo_write_http loaded at 01090000h - 010A1000h foo_vorbisenc loaded at 010B0000h - 011AF000h mswsock loaded at 71A50000h - 71A8B000h DNSAPI loaded at 76F20000h - 76F45000h winrnr loaded at 76FB0000h - 76FB7000h WLDAP32 loaded at 76F60000h - 76F8C000h rasadhlp loaded at 76FC0000h - 76FC5000h wshtcpip loaded at 71A90000h - 71A98000h imagehlp loaded at 76C90000h - 76CB2000h DBGHELP loaded at 6D510000h - 6D58D000h Stack dump analysis: Address: 77D45F0Eh, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "SendMessageA" (+00000000h) Address: 00445954h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 00F574F2h, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 77D43A50h, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 00F6368Ch, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 77D43A50h, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 77D43B1Fh, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 77D7390Ah, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "CreateAcceleratorTableA" (+0000032Dh) Address: 77D99B68h, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 77D43D79h, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "GetMessageW" (+00000125h) Address: 00F571EBh, location: "foo_ui_columns", loaded at 00F50000h - 00F70000h Address: 77D43A33h, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 77D4B1A9h, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "IsDialogMessageW" (+0000008Dh) Address: 77D7390Ah, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "CreateAcceleratorTableA" (+0000032Dh) Address: 77D99B88h, location: "USER32", loaded at 77D40000h - 77DCC000h Address: 77D43DDFh, location: "USER32", loaded at 77D40000h - 77DCC000h Symbol: "DispatchMessageW" (+0000000Bh) Address: 100038ECh, location: "utf8api", loaded at 10000000h - 1000D000h Symbol: "uDispatchMessage" (+0000000Ah) Address: 0041161Bh, location: "foobar2000", loaded at 00400000h - 00451000h Address: 70A9F1ABh, location: "SHLWAPI", loaded at 70A70000h - 70AD5000h Symbol: "Ordinal125" (+00000027h) Address: 00410076h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 00437A05h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 70A9F1ABh, location: "SHLWAPI", loaded at 70A70000h - 70AD5000h Symbol: "Ordinal125" (+00000027h) Address: 00437A30h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 0043B160h, location: "foobar2000", loaded at 00400000h - 00451000h Address: 77E814C7h, location: "kernel32", loaded at 77E60000h - 77F46000h Symbol: "GetCurrentDirectoryW" (+00000044h) Address: 70A9F1ABh, location: "SHLWAPI", loaded at 70A70000h - 70AD5000h Symbol: "Ordinal125" (+00000027h) Address: 77E94809h, location: "kernel32", loaded at 77E60000h - 77F46000h Symbol: "SetThreadExecutionState" (+00000097h) Address: 77E91210h, location: "kernel32", loaded at 77E60000h - 77F46000h Symbol: "OpenConsoleW" (+0000EDBEh) Address: 004378D1h, location: "foobar2000", loaded at 00400000h - 00451000h Version info: foobar2000 v0.8 beta 10 UNICODE But now it doesn't seem foo_ui_columns related, because when I unload ALL plugins that aren't in the special setup, ie using the standard gui, I got the same problem: after deleting any playlist, I can not move any other playlist without foobar crashing on me...
foobar 0.8, addall 0.7.b29.001, audioscrobbler 1.2.1, bluetooth_ctrl 0.4, delete 0.7.b29.001, infobox 1.3.6a, nero 0.3.7, pl_hopper 0.1, quicktag 0.5a, setyear 0.3, syfm 2.5.5, tunes 0.1, ui_columns 0.1 beta 8, text 1.3.6a, write_http, some but not all from special installer 0.8b10
