Topic: Intended uses of Dibrom\'s Presets (Read 2160 times) previous topic - next topic
  • RD
Originally posted by Dibrom:
With MP3 you need vbr bitrates near 256kbps to really acheive transparency across the board in most situations I think and even then this is not always possible, but with AAC this is much more attainable at bitrates near 180kbps.
When I read this I reflected on your new presets:
(1) --alt-preset normal
(2) --alt-preset high (old standard)
(3) --alt-preset extreme
(4) --alt-preset insane
Since your comments and my testing agree that --alt normal gives bitrate ranges of about 150-200 kbps (220s for metal, etc.) then your comments quoted above should mean that --alt-preset normal is not a transparent setting and thus not suitable for mp3 archiving.
If I am correct about that last point, then I think these are your intended uses for the presets (correct me if I am wrong):
USE: best tradeoff between size and quality without any major quality concessions.
USE: Higher quality than normal; average bitrate around 256 kbps? Bare minimum for mp3 archival?
USE: Very High quality; for people with excellent hearing; good choice for mp3 archival...
USE: Tries to achieve highest quality possible in Lame; for people who must, for some reason, have 320 cbr; for people who need to store Fatboy in mp3  generally overkill and wasteful.
Did I get it right? Or am I underestimating the quality of --alt-preset normal and taking the above quote out of context?
  • Dibrom
  • Administrator
[/b]
Well.. for one thing that statement was made awhile ago and was based on the current technology that was used within LAME.  I have been able to improve many of the areas which I found problems with before so I don't think it is quite so much the case now.
That being said, I'm talking about a relative level of transparency.  MP3 at any bitrate is not absolutely transparent if you factor in the issue that there are many clips (usually impulse heavy) which are still fairly artifacted even at 320kbps.  What I'm trying to achieve is a reasonable level of transparency on the majority of music for the majority of users, with this "normal" preset.
This very much depends.  Considering the fact that normal actually outperforms high (standard) on many of the more difficult clips, and that for the most part in Roel's AQ test dm-standard was shown to be AQ quality, it's reasonable to say that for the most part normal should also be.  Again, this is for the most part, it is not necessarily an absolute.
I think maybe you are underestimating the quality some.  Those statements are pretty much on target though, but I think it should be emphasized a bit more than "normal" isn't your standard "tradeoff" like something like --r3mix is.  It attempts to achieve simply the best quality possible first and then bring down size second.  It's design philosophy is very similar to that of the old standard, it is just taken much more to the threshold and uses much more advanced techniques to keep bitrates lower but without harming quality much.
