Topic: Changes Made to TAG.EXE (Read 138545 times) previous topic - next topic
  • [proxima]
Edit: @ [proxima]: Again, thanks for your help. FYI: Since Beta 5 I am no longer using the --tofile code, so:
TAG --tocuea --recursive *.wv
... works.
[a href="index.php?act=findpost&pid=348607"][{POST_SNAPBACK}][/a]
Thanks for your work Syntetic Soul, it is really appreciated.
I'm happy you finally ended up with a successful recursive mode
WavPack 4.3 -mfx5
LAME 3.97 -V5 --vbr-new --athaa-sensitivity 1
  • [proxima]
@Synthetic Soul: the new switches you added return always zero even if the input file does not contain an embedded cuesheet. It would be useful for batchfiles creation if you can return "non zero" in this and the other possible failure cases.
edit: i've just found a workaround with batchfiles, i can check for filesize. You can ignore this request
  • Last Edit: 09 December, 2005, 08:27:54 PM by [proxima]
WavPack 4.3 -mfx5
  • Synthetic Soul
  • Global Moderator
I can't really return a non-zero value, as it is not an error, per se, if no cuesheet tag exists.
You can use --tocue/a/n while tagging, or any other action, so returning an error would be inaccurate in many situations.
I could report when no cuesheet tag is found, but I guess that is of no practical use.
Anyway, I'm glad that you found a workaround.
I'm on a horse.
  • JJZolx
I'm sure TAG.EXE has a long and storied past, but I haven't been able to find that story anywhere.  What's the reason that the writing of id3v2 tags is not supported by this tool?
  • Synthetic Soul
  • Global Moderator
Much of the story I can't explain.  I am a relative noob to this forum.
My small part of the story is detailed in this thread.  In essence, I wanted to embed a cuesheet in my Monkey's Audio files as part of an automated archive process.  I asked Case whether he would add the functionality to set the tag from the contents of a text file and he replied that he had no interest in updating Tag.  So, I took it upon myself to add the functionality. I never intended to do anything else with Tag, but although the application was popular, no-one else seemed interested in updating it further, so as libraries that Tag uses were updated  I have updated my mods of Tag, in case they are relevant.  I have made a few other minor amendments as and when people have requested.
I have always been confused why a competent C(++) programmer has not taken on the role.
I tend to get one or two emails a week regarding Tag.  Many ask me when I will add ID3v2 tagging.  Sadly, I have to tell them that I simply don't have the skills to implement such a thing.  That said, Case didn't add ID3v2 tagging for a reason.  He must surely have the skills to utilise the ID3lib library, so I figure that ID3v2 was never meant to be.  I have always been concerned about corrupting Tag's good name, and, stupid or not, it seems to me that adding ID3v2 tagging to Tag would be sacrilegious in some way.
I know many people on the forum seem to have a low opinion of ID3v2, stating that it is a poor standard and can result in corrupted files.  I can only assume Case subscribed to this thinking.
I for one would like to hear Case's story more.  He was posting infrequently when I joined the forum, and seems not to post at all now (hopefully the two events were no related).  On checking he was last active two days ago, but hasn't posted for six months.
I'm on a horse.
  • lossman
Reply #30
Is there any way to pipe the output to a text file? Im just trying to read the artist, album and genre tags into my vb app. I could use metaflac but would rather keep tag as its such a versatile tool.
Whenever I do
tag "1.flac"  --hideinfo --simple --hidenames >> test.txt
I get a blank text file
  • Synthetic Soul
  • Global Moderator
TAG.EXE --stdout *.* > report.txt
You will need at least version 2.0.44 to use the --stdout switch.
  • Last Edit: 20 January, 2006, 04:30:02 AM by Synthetic Soul
I'm on a horse.
  • hawkeye_p
use the --nfo switch!
Edit: Ooops Synthetic_Soul was quicker. However, --nfo works with earlier versions.
  • Last Edit: 20 January, 2006, 04:37:14 AM by hawkeye_p
  • lossman
Reply #33
Thanks guys, cant believe i missed that one!
Edit:
tag "1.flac"  --hideinfo --simple --hidenames --stdout >> rep.txt
worked perfectly.
  • Last Edit: 20 January, 2006, 05:09:06 AM by lossman
Reply #34
...i hope for an id3v2 writing support....
... if i'm just a good programmer, i can contibute to synthetic soul.
  • cyborg
Reply #35
Tag.exe doesn't seem to be able to read ID3v2 tags written with foobar2000 0.9. Can you fix that Synthetic Soul?
  • Synthetic Soul
  • Global Moderator
Reply #36
Sorry, no.  I just don't have the knowledge of ID3v2 or C++.
Perhaps it is time that a competent C++ programmer took on the mantle?
I'm on a horse.
  • odyssey
Reply #37
Damn, I really hoped tag.exe could write ID3v2!!
I use Helium as tag manager, which reads APEv2 tags, but are appearent not very good at it. If I remove ID3v2 tags and update the "year"-tag, nothing shows up in Helium. I need this to update series of files with a script gathering data from a database.... so now i'm stuck :-(
  • vasya_pupkin
  • Banned
Reply #38
I have a small feature request. Since foobar2000 started to write tracknumber field in format MM/NN where MM is track number and NN is total tracks count, it is hard to rename tracks using tag. Is it possible to strip '/' and everything after this char from tracknumber field when renaming?
  • db1989
  • Global Moderator
Reply #39
Try loading all of the MP3s whose tags you want to alter into foobar2000, selecting them and removing the TOTALTRACKS field. I have no idea how you could do this with TAG or another program, though.
  • vasya_pupkin
  • Banned
Reply #40
Do you feel the difference between correcting Tag's functionality and modifing tag information to let Tag work as expected?  I need this field, I don't want to remove it.
  • odyssey
Reply #41
HMM does it pretty much the same way... (Oh and by the way - It actually supports most of the ID3v2 standard which fb2k doesn't )
  • Last Edit: 31 October, 2006, 10:48:27 AM by odyssey
  • urak
Reply #42
Sorry, what's "HMM"?
thanks
  • rjamorim
Reply #43
Me too. I understand that this subject is pretty much taboo here, but tag would be so much more useful to me if it just dropped the politics and wrote ID3v2 tags...
http://www.rarewares.org
  • Daijoubu
Reply #44
I've got those ID3v2 tag that iTune produce with the cover and it crash when applying it to a ogg file
  • Andavari
Reply #45
I agree as well, and have wanted that feature implemented since the get go and the likes of Winamp and Foobar2000 can write them so I don't see why it was never implemented regardless of "taboo, and paranoia."
  • fairway
Reply #46
Hello
Is there a reason that tag.exe does not create an extended m3u file for TAK files? I tested it with tag.exe --playlist *.tag but it did not creat an extended m3u playlist with the artist / title names.
  • Synthetic Soul
  • Global Moderator
Reply #47
I'm not familiar with M3U playlists, or Tag's --playlist switch, but I used:
TAG --playlist *.mp3
... and created:
#EXTM3U
#EXTART:Lali Puna
#EXTALB:Tridecoder
#EXTINF:309,Lali Puna - 603
01 - 6-0-3.mp3
#EXTINF:237,Lali Puna - Rapariga da Banheira
02 - rapariga da banheira.mp3
#EXTINF:273,Lali Puna - Antena Trash
03 - antena trash.mp3
#EXTINF:214,Lali Puna - System On
04 - system on.mp3
#EXTINF:283,Lali Puna - Everywhere & Allover
05 - everywhere and allover.mp3
#EXTINF:279,Lali Puna - Tocadisco's
06 - toca-discos.mp3
#EXTINF:149,Lali Puna - Press My Tummy
07 - press my tummy.mp3
#EXTINF:235,Lali Puna - Fast Forward
08 - fast forward.mp3
#EXTINF:266,Lali Puna - Superlotado
09 - superlotado.mp3
I'm on a horse.
  • fairway
Reply #48
... and created:
#EXTM3U
#EXTART:Lali Puna
#EXTALB:Tridecoder
01 - 6-0-3.mp3
04 - system on.mp3
did you try with tak files?
  • Synthetic Soul
  • Global Moderator
Reply #49
Just tried.  I got the header (below), but not any track info.  I'll try to take a look.
#EXTM3U
#EXTART:Lali Puna
#EXTALB:Tridecoder
I'm on a horse.
