Topic: SACD vs. DVD-Audio (Read 58299 times) previous topic - next topic
SACD vs. DVD-Audio
The "high-res formats" are definetely susceptible to clipping, just like CD Audio is. If the behaviour of the recording industry in the past is any indicator then we will get badly clipped DVDA/SACD as soon as the formats are a bit more whidespread. It's all about being the loudest, "sound quality" is just something to lure early adopters with.
I never met even 1 SACD or DVD-A with clipping. I will gladly buy the disk with such problem, if you can recommend me any. As as we can see, 2001 CD is not relative to "early adopters" ...
This doesn't have anything to do with the format itself! If the recoding industries set themselves a higher standard in the production of digital music than they have in the past, I will for sure only applaud that. But no new format such as DVDA or SACD is needed for that. See also krabapple's post.
WmAx and krabapple already explained why I consider the paper you mentioned rather "controversial" in this discussion.
SACD vs. DVD-Audio
In slight OT, I had a recent run-in with Telarc's Michael Bishop in e-mail. I was upset that a new cd from them had so much clipping in it and was set ast such high absolute levels, and only something like -40db min, levels of the 96dB avaialble. In this exchange, he told me something suprising: That the RBCD version had been more compressed then the SACD version. Apparently to 'compete' with the other RBCDs. No such warning were found on or inside the CD case!
Take a look at this excerpt from the reply email stating this:
The Tierney Sutton "Dancing in the Dark" CD release is put up side-by-side
with Diana Krall and Norah Jones releases and other similar jazz vocal CDs.
Like it or not, those CDs are quite heavily compressed and limited (much
more so than the Sutton CD) and have very high apparent volumes.  They also
exhibit an even more pronounced cut-off of peak levels.  Since Tierney's CD
will be put in multi-disc CD players alongside these other  CDs, we have to
make sure her CD stands at least a chance of being as "present" as the
competition and still maintain as much of the dynamics of my original mixes
as possible.  It's a very delicate balancing act.  Certainly compromises
are made, just as in any other mainstream CD that has high apparent volume
level.  I know one would find much more aggregious level compression taking
place on most mainstream CDs than what you would find on "Dancing in the
Dark."
If you are interested, the DSD stereo and surround programs on the SACD
release of "Dancing in the Dark" (SA-63592) do NOT have this competitive
compression imposed on the audio.  The DSD programs represent what I
recorded in the mixes from the sessions without the compromises needed on
the CD-only release.  However, the CD layer of the SACD is exactly the same
as the CD-only release.
In this case, we literally have a CRAP PERPUTUATING CRAP scenarion. Egads!
-Chris
[a href="index.php?act=findpost&pid=235653"][{POST_SNAPBACK}][/a]
SACD vs. DVD-Audio
So, the SACD-version was mastered less-agressive because of a "less-competitive" market....... does that imply that once the SACD or DVDA market becomes "more competitive" that they will the just start another loudness-race?
If only replaygain would be a standard inplementation in almost any hardware-player, then this whole mess would solve itself..... because it would be the hot-mastered records which would sound "less competitive" then.
So in other words - what would really improve "dynamic-range" in the music-world, is NOT another audio-format...... but instead a technology like replaygain which makes the loudness-race irrelevant.
- Lyx
SACD vs. DVD-Audio
We have a lot of opinions of well known respected people in audio, for example Doug Self's ... and many others, the whole tweaking industry is based on this principle. "Potentially" is a nice word, potentially I hate you ... what does it mean?
In my case, it means it's not unreasonable to consider the possibility of bias, when a person might make a profit from his claim (in your case), or when he's paid a lot of money for a mod (in the customer's case).  It would be unreasonable to dismiss the possibility outright or to ignore it.  I hope you don't hate me for that.
Which particular belief of Doug Self's are you referring to, btw?  I have found his work to be pretty reasonable...
Please note that I have no reason to hate you in reality nor any intention to abuse you, just used your word
I know . ;>
I tried to make a suggestion about the difference, it is here - has to replace the old measurements with my Audigy with the new ones through Lynx L22  though.
http://members.cox.net/alexhardware/opa.htm
In the DBT I can recognize the difference between PCM1704+OPA627+OPA2134 and PCM1704+JRC5534+JRC2068+JRC2068 with 17/19 probability in the best case, usually it is 14-15/19 ... You still don't think it is enough information to make the suggestion? Well, this is a point to write another article, it is "on the way"
I don't think that I am any kind of "superhero", though potentially you know better
Well, your DBT results might make you one. ;>
Seriously, we need more *good* research into audible difference between formats; ther are *far* too many claims out ther alraedy that seem to believe the matter is settled (usually on the side of 'SACD is clearly superior to CD').  I look forward to detailed presentation of your DBT methodologies and results. ANd *this* is definitely a good  place to have both dissected!  This forum has the means and experience to help you conduct a multiple subject test,if you want to go through with that.  Another place to get good feedback from skeptics -- at least a few of whom have engineering/audio component design backgrounds  -- is rec.audio.high-end.
can be blamed - bad equipment, bad sources of information, etc., etc. Please supply those opposite sources, we can discuss them as well. I am not a scientist, but I hear the difference using DBT as stated in the article, with 19/19 probability, and it looks as the samples are different only in the ultrasonic area ... I also see the ultrasonic images, and I have no other idea how to explain the difference in sounding through the same path ... there is no difference in implementation, as for PCM exactly the same path is used.
The NHK labs results have already been mentioned, and a search of 'Oohashi' on many audio forums (including this  one) will produce the usual objections.  Your hypothesis about the ultrasonic area remain that...you still need to demonstrate that they are making the difference, and not something else, because as you surely know, not all measurable differences are audible.
High-Res format is a winner (I am talking about presented in the article DVD-A Advanced resolution and SACD multi-channel), in other case they are simply useless (and we know that this is not true). I can hear the difference through my system easily - as stated before, the same path for PCM audio signals. Not only me - as the moderator of this forum pio2001 said, and I agree with him:
However, ABX success seem to show that after all, there might be an audible difference between a 44.1/16 bits recording and a 96/24 bits one, whatever causes this.
He says *might be* -- which is an important qualifier.
Highly controversial? It is published in the well-respected Journal of Neuropsychology,
Actually, how well-respected that journal is, is something I'd have to ask a neurophysiologist about.  I know from my own field that 'respect' is hard for people outside a field to gauge.  I know which journals are 'respected' in developmental biology, but I wouldnt' be surprised if a physicist had no idea whatever.
10 people are co-authors in it
What matters much more, is who the authors are, not how many.
, it is "scientifical enough" for me. Can you provide the links with the opposite information? If you are talking about this document http://www.nhk.or.jp/strl/publica/labnote/lab486.html I have some points to discuss.
YEs, that's a standard one.  You also cite Dr. Greisinger...I wonder what he'd make of your data.
DBT and easily recognized that it is necessary to know what difference are you going to hear and train yourself for a while, then it becomes completely different. If you use just some participants who know nothing about the test, the probability that they can hear the difference is very low when signals are more or less equal. A very important point, which never had been discussed or researched  - ultrasonic images in multi-channel audio, we have a significant difference in perception of it vs stereo or even mono signals, usually used in the tests.
An interesting idea, worthy of more research.  If you can set up some sort of audio comparison through this forum, I'll be happy to participate.
SACD vs. DVD-Audio
Quote from: lexor,Aug 19 2004, 02:40 PM
That is incorrect/misleading! Though Microsoft does provide such capabilities in their WMEncoder, such audio is NOT part of HD-DVD specification ratifiend by the DVD forum and will not be found on future HD-DVD disks.
Dolby, DTS, LPAC (lossless), and mp4 (including HE and that new stuff Nero is working on to improve it, I'm bad with acronims) are the codecs. Only WMV9 Video has been approved.
You are right, this information will be corrected. WMV9 is approved, not WMA9. Thank you.
Quote from: WmAx,Aug 19 2004, 02:48 PM
Do you realize the 'audibility' chart on your site pertains to pure sinuisodal waveforms? The tolerances for audbility are far higher with music program. Even, with a purist piano recording, the JNDs are in the 1-2% average range of total THD of detectiablity thresholds for listeners:
This is a different story. The audibility of op amps was created using RMAA, and this is a measuring software, which uses sine waves for measurements. I compared the graphical results with Albini graphs. This just illustrates the suggestion. It is not related to DBT (musical samples).
Quote from: krabapple,Aug 19 2004, 08:02 PM
I don't provide the mod services anymore (till over two months) to be able to avoid such questions.
http://www.dself.dsl.pipex.com/ampins/webbop/opa627.htm
The OPA627 (Burr-Brown) is a very expensive opamp with excellent DC precision. But is it any good for audio? The answer is yes.
http://www.anthemav.com/OldSitev1/pdf/sfd2mk3.pdf - page 3
OPA627+OPA2134 is a recommended combination for PCM1704 by Burr Brown engineers as well (take a look in PCM1704 data-sheet)
No, I had made DBT only after some attacks on AVS forum, I was too lazy to make it before.  I hear the difference, it was not necessary to make DBT from my point of view, but people wanted it ...
Seriously, we need more *good* research into audible difference between formats; ther are *far* too many claims out ther alraedy that seem to believe the matter is settled (usually on the side of 'SACD is clearly superior to CD').  I look forward to detailed presentation of your DBT methodologies and results. ANd *this* is definitely the place to have both dissected (not avsforum)!  This forum has the means and experience to help you conduct a multiple subject test,if you want to go through with that.   Another place to get good feedback from skeptics -- at least a few of whom have engineering/audio component design backgrounds  -- is rec.audio.high-end.
Thank you, it is a good advice, seriously
For me NHK tests are significantly less valuable then Oohashi's. First of all - it is not possible to fool DBT system when you want to hear the difference, but it is very easy to fool it when you don't want or just too lazy to hear the difference ... some people who just don't want to pay attention or don't know what they intend to hear can break any test. Then -  the used equipment. Why use in the listening tests not professinal monitors, which can reveal anything, but High-End speakers, which are designed to provide the most pleasurable sound, hiding imperfections?
As well as yours "potential"? You guys are trying to have no responsibility and never be caught  I don't need such word as I listen to DVD-A, SACD and CDs almost every day in my system, all types of them. I have my own opinion and can share it, right? If people who financially benefit from the High-Res formats, don't make massive DBT to scientifically prove that they sound better, why do I need to bother to do it by myself for free?
The results of measurements can be flawed intentionally or just because of mistake and signed by one person, the probability with 10 is significantly less ... don't you think so?
I have no doubts that Dr. Griesinger is a great scientist and I made my measurements just because I hear the difference on my equipment ...
An interesting idea, worthy of more research.  If you can set up some sort of audio comparison throuhg this forum, I'll be happy to participate.
I am not ready to spend so much time yet  May be a bit later.
Quote from: Lyx,Aug 19 2004, 04:02 PM
SACD version had been mastered less aggressive because it has more reserve in DR ... IMO
SACD vs. DVD-Audio
These are not valid arguments. The Ooashi test, in the so-called audibility section, was poorly documented and produced.
(1) No individual data is provided for the audibility section.
(2) Vague details of the actual session.
Remember, Ooashi's main focus was the brain scan section. The NHK lab paper was carefully produced and focused on audibility. Their is no cmoparision, the NHK paper is extremely well documented on the audbility information and all data. The equipment used was cutom made precision systems. It is irrelevant if it was a name-brand monitor,e tc. Actually, the speakers they made would have to perform superiorly to any standard monitor, since they were so careful to divide, filter and actively power so many discrete multi-way speakers to insure no IM products contaminating the test. The listeners were many, and nearly all audio experts. This is a far better test of actual audibility then Oohashi's. Besides, the Plenge, Shone and Jakbuwskis paper that is the established standard landmark, has yet to be rebutted successfully. It still stands.
You can have any opinion you wish. :-) However, it's not supported by factual information in this case. With a properly dither, a RBCD format can approach 96dB dynamic range. This is far beyond what an be used in any pratical listening environment, or what speakers/equipment can even produce. Let's say you have an extraordinarily quiet special built room that has a noisefloor of 35dB(RARE): let's start the noisefloor of the RBCD at or under this,  your playback system would ahve to be able to produce nearly 130dB cleanly. Not considering potential hearing damages, the only speaker that can manage this in a home environment are large line arrays or super-efficient large horn speakers.
Besides, analyse the waveforms on some of your CDs. You'll find around 20dB RMS used on much modern rock/pop, perhaps 40dB on some jazz, etc. and no more then 65-70dB RMS average used on very dynamic classical recordings. So, the dynamic compression that is imposed on RBCD has nothing to do with any physical limitation, but a purposefully imposed limitation by the recording engineer(s).
Besides, the [1]optimal dynamic range in most practical situations for speakers is approx. 75dB, and headphone about 80dB. RBCD is signficnatly more capable.
[1] Signal-to-Noise Ratio Requirement for Digital Transmission Systems
Spikofski, Gerhard
AES Preprint: 2196
-Chris
SACD vs. DVD-Audio
Dark."
It's a sad day when Telarc are competing in the loudness race.
[a href="index.php?act=findpost&pid=235707"][{POST_SNAPBACK}][/a]
That's an irrational statement, isn't it?
1. The person who made the CD has said that it was dynamically compressed to compete with loud sounding CDs. That was the reason he gave.
2. Telarc make hundreds of non-squashed CDs - some of them with very quiet passages far below the lowest level that this recording would have without dynamic range compression. They don't squash these CDs for classical markets where there is no need to compete in the loudness race.
3. Telarc are very pro DSD and will tell you how much better SACDs sound than CDs whenever they have the chance - yet this time there's no suggestion that this is the reason for the squashed CD sound - it's just a commercial competative decision.
4. The background noise limit on a CD is 96dB below full scale or lower (I don't think I'm telling you anything new here  ) so this recording isn't going to fall below it. Even the (highly) subjective improvement that can be gained by going from 16-bit to 24-bit or DSD is tiny/minute/inconsequential compared to the audible damage that is done by dynamic range compression. So the recording would have sounded better on CD without the compression.
Despite all this, you suggest that the SACD version has less dynamic range compression because SACD has a greater dynamic range?
The cynic in me thinks that, if there is any other reason, it's to make sure that the better sounding version is on the more expensive format. To be fair to Telarc, I don't think they're that cynical - I'm sure other labels are though.
I reckon other labels will try to degrade the CD compared to the SACD or DVD, but they will find that users just copy the SACD or DVD-A through the analogue outputs, convert it to 44kHz, encode it with MusePack (or even mp3), and send it across the net. Then anyone using a file sharing network will be able to obtain a better CD by downloading the files and burning them to a CD-R than by going to the shop and buying the over compressed commercial CD. The industry couldn’t be so stupid, could they?
David.
SACD vs. DVD-Audio
Reply #32
Come on, Alex, there's nothing on that page about audible effect of using this op amp versus another. He just shows that it's a technically fine audio op amp.
Again, the question was whether the mods make an audible difference.  Not whether one could swap one op amp for a *measurably* different/better one!
Self is about as 'objectivist' as they come...maybe i'm missing something, but I don't see him advocating modding of devices like the top-line Pioneer receivers.
SACD vs. DVD-Audio
I am sorry for the late response, guys. Some corrections had been made in the article, for example concerning Microsoft.
Remember, Ooashi's main focus was the brain scan section. The NHK lab paper was carefully produced and focused on audibility. Their is no comparison, the NHK paper is extremely well documented on the audibility information and all data. The equipment used was custom made precision systems. It is irrelevant if it was a name-brand monitor,e tc. Actually, the speakers they made would have to perform superiorly to any standard monitor, since they were so careful to divide, filter and actively power so many discrete multi-way speakers to insure no IM products contaminating the test. The listeners were many, and nearly all audio experts. This is a far better test of actual audibility then Oohashi's. Besides, the Plenge, Shone and Jakbuwskis paper that is the established standard landmark, has yet to be rebutted successfully. It still stands.
Chris,
I am not qualified enough to discuss non-perfection of scientific articles. I would like to remind you, though, about Legato Pro audible difference, it is not a natural way to add audible ultrasonic, but using slow roll-off in digital filters instead of sharp roll off some ultrasonic images had been artificially restored. The system sounded differently, I don't want to argue here better or worse, but no doubts we could hear the difference, and it is only in ultrasonic frequencies.
You can have any opinion you wish. :-) However, it's not supported by factual information in this case. With a properly dither, a RBCD format can approach 96dB dynamic range. This is far beyond what an be used in any pratical listening environment, or what speakers/equipment can even produce. Let's say you have an extraordinarily quiet special built room that has a noise floor of 35dB(RARE): let's start the noise floor of the RBCD at or under this,  your playback system would have to be able to produce nearly 130dB cleanly. Not considering potential hearing damages, the only speaker that can manage this in a home environment are large line arrays or super-efficient large horn speakers.
Actually it was a provocative answer, I am sorry for it. I had a hope that someone would explain mentioned by jheoaustin two SACD modes:
http://www.avsforum.com/avs-vb/showthread....899#post4196899
"The plots are really interesting, and reminds me of the Sharp demo/presentation for DSD to the industry in 1997. They were showing 2 DSD modes, and one was high quality mode of 120dB SNR and 20 ~ 22kHz bandwidth. The other was the wide band mode of 96 ~ 100dB SNR and 100kHz bandwidth."
Since my experiment confirmed some kind of those two modes http://members.cox.net/alex_lat/Tests/SACD_modes.PNG , I had a hope that someone would explain to me -100dB 100kHz SACD mode
I know that with dithering and noise-shaping DR in CD can significantly exceed the limit for S/N 96dB and can be:
http://www.megabitmax.com/content/technicalinfo
"MEGABITMAX provides up to 14 dB increase in perceived dynamic range over the standard white noise TPDF dithering, and up to 6 dB increase over the most powerful of today’s Word Length Reduction systems"
Over 14dB increase vs already dithered signal!
Therefore we have some technologies, which can increase the DR for CDs above the level of DR for 100dB 100kHz SACD, right? And "higher dynamic range" can't be a reason for non-clipped signals in SACD
Some additional information about 16/44.1kHz vs 24/96kHz
http://www.nanophon.com/audio/antialia.pdf
http://www.tnt-audio.com/sorgenti/2496e.html
Agreed.
David,
It really is  The explanations are above. Thank you for your input.
krabapple, you had ignored another link, posted by Sonic frontiers:
the amp is the Burr Brown OPA627 ... This amplifier doesn't only perform excellent on paper and in measurements, IT ALSO SOUNDED THE BEST OF ALL OPERATIONAL AMPLIFIERS WE TESTED.
Take a look here as well, it is in German, but anyone can use babelfish now, right?  http://www.hoer-wege.de/dacupPCM1704.htm
Actually I modded it for myself (swap was for 3 op amps per channel, and what is most important, in I/V stage - see also the information about importance of this stage in Hawksford's article), and only after that decided to share such information  Do you think that guys as Chris Johnson (SFI/Anthem/Part Connexions http://www.partsconnexion.com/assemblage.php), Walter Liederman (Underwood Hi-Fi http://www.underwoodhifi.com/whoweare.html), Dan Wright (ModWright http://www.modwright.com/) don't deserve to be respected just because they "advocate" modifications in High-End devices?
Take a look here and http://web.telecom.cz/macura/opamp_mer_en.html
The purpose of measurement was to find the best opamp (from THD point of view) for use in preamplifiers
THD point of view is not 100% relative to the sounding, though if we know the spectrum in the audible range, quite informative.
May be this paper will be helpful fior you? http://www.essex.ac.uk/ese/research/audio_...20amplifier.pdf
Here is a discussion about op amps for I/V in DIYAUDIO forum: http://www.diyaudio.com/forums/showthread/t-34324-p-1.html
And finally I had made some measurements with different op amps and DBT as well, this is an idea for another article, though no time for it yet ...
P.S. After the discussions in Audio Asylum forum there is an interesting suggestion concerning ultrasonic images in measurements, as assumed by some people, produced in 49TXi. I have only one suggestion at the moment - if we don't have such images on multi-channel tracks of James Taylor "Hourglass" and Steely Dan "Two against Nature" DVD-A 24/96, as claimed by Dave Kingsland and John Kotches, (I still have some doubts about that due to the following information):
http://www.warnervision.com.au/bio.asp?id=1883
http://www.scotthullmastering.com/Articles.html
"But for this project, the entire signal path was digital – but utilizing the higher sample rates and bit widths. The Genex source went directly to my Sonic Solutions editing system recording at the full bandwidth of 96x24. After the mixes were edited and compiled, the 96x24 bit AES signal was routed to my Z-Sys 96k 24-bit 6 channel digital EQ. We only needed 2 channels for this version, but this is such a nice sounding digital EQ."
Then this statement of Pioneer is not truthful: http://members.cox.net/alex_lat/images/Audio_scaler.PNG
and so called "Audio Scaler" works for DVD-A and SACD as well as for CDs and DD/DTS sources, adding artificial ultrasonic images, and I can see only one ability for that at the moment - switching from sharp roll-off to slow roll-off in digital filters DF1706 (exactly as in Legato). I need to make some additional measurements to prove what is correct.
SACD vs. DVD-Audio
Reply #34
There is no need for me to responsd to each article. I did skim through some of them, but I did not notice anything proving positive results in a listening test that woudl hold up under scrutiny.
That's really my only point -- people like to speculate and assume things that have not been proven under the strict controls required to be accepted as a truth. It really does not matter what the title or what degree the person holds that makes this speculation. Speculation is speculation, regardless of who spreads it around. :-)
Don't you find it curious that a big compnay like Sony has not produced a single scientifically valid test to prove that it's new format has an audible advantage? Such tests were paramount in development of RBCD format. In truth, they developed the RBCD specs based on parameters that exceeded the overwhelming majority of human discernability in the relevant playback conditions. Such recent audibility tests as the NHK labs test, that took every precaution possible to prevent errors(special speakers, special amplifier/filter systems, special recordings, audio expert listening panel, etc.) have only failed to produce positive results of audbility. The only examples I have seen of positive results were those that had many open-ended variables not accounted. Of course, you can feel free to critize the filter that NHK implemented. But it was ideal, in that it allowed a simple switch in/switch out of the ultrasonic spectrum. But then, criticize the filter method used in the other paper (What Bandwidth Is Necessary for Optimal Sound Transmission?, Jakubowski, Schone, Plenge)I referred to, which simply increased the filter cuttoff point until it was not disceranbe in reference to the unfiltered signal. NOt even 20kHz was reached before it was not discernable.
-Chris
EDITED FOR FACTUAL ERROR/TYPO.
SACD vs. DVD-Audio
Reply #35
[a href="index.php?act=findpost&pid=236559"][{POST_SNAPBACK}][/a]
There is actually a word for that, axiom. I'll give you an example of why your logic doesn't hold. Please prove to me that "up" is where you think it is. You just know that it's there, but can you even begin to prove it to a person that has no notion of direction (brain demage/trauma) and would say there is no such thing as "up"?
The imposibility of proving something doesn't translate to it's incorectness. There is a few things in math that are known to be true, but it is believed that they cannot be proven (Set Theory is full of that, the basics of Set Theory cannot be proved, as in not possible at all, but all math of today has been re-derived from Set Theory).
The Plan Within Plans
SACD vs. DVD-Audio
Reply #36
That's an  uneeded statement. I never claimed such a thing, if you that is an implication. But, the illogic of assuming ideas that have no strong evidence to support them as true is ultimately counterproductive. That's exactly why scientific methodology is the standard. Do you know of a better/more efficient way? I don't.
In this particular case of audiblity of ultrasonic bandwidth -- I'm not aware of credible data(that can hold under any degree of scrutiny) has proven, or strongly suggested audibility should be possible.
-Chris
SACD vs. DVD-Audio
Reply #37
-Chris
[a href="index.php?act=findpost&pid=236561"][{POST_SNAPBACK}][/a]
That sentence I don't understand, could you refraise "if you that is an implication", you mean if I'm implying that? If so then you seem to be forgetting your main argument which you actaully repeated in this last post above. You argue against the author of the article because he cannot provide anything solid to support the claims.
All of moderm mathematics has been re-derived from Set Theory, the very basic assumptions and statements of Set Theory (such as what is empty set) cannot be proved and have no credible data(that can hold under any degree of scrutiny) supporting it, and I mean absoluteley nothing, we as humans just have an understanding of what empty means.
To give a more tangible example, Set Theory backs up simple arithmetic, arithmetic says 2-4=-2, that is based on the fact that Set Theory tells us so, but set theory has no prove or any evidence to even remotley support it's basic axioms, so according to you, we can't say  2-4=-2.
SACD vs. DVD-Audio
Reply #38
Ok, it seems clear now that you are(understandably) confusing the methdology of math with that of science, which in fact are two different things:
1. Science is a systematic approach developed for efficiency of progress/development/understanding of the physical universe. This site is founded on such. Hypothesis and Theories are developed, and tested in science. They are not assumed as true until they have been proven. Even then, they may only be provisionally accepted. This is a system developed for a purpose. Mathematics has a purpose, too, and it's systematic operations for development seems to be rather different from that of what has been found optimal for physical analysis. IT seems that each has developed a system based on it's own requirements for efficiency. Unless you have a yet more efficient system, it seems useless to debate the validity of science based on the optimal system for a different application.  Mathematics are not a physical entity. Consider the alternative of science in the physical world [1]
2. You refer to this as "according to you(me)", but I'm hardly the one that developed/established scientific methedology. But, since math has different needs to be efficient, I don't make any claims that it should be approached in exactly the same way as the physical universe, nor be subjected to precisely the same burdens of 'proof'. I follow it (science) because it's highly efficient in comparison to the alternative: [1] Abandonment of science would open up every matter to an infinite number of possible variables, never being able to quantify anything. To abandon means you must accept all theories/ideas/speculations equally. No requirement for evidence, remember.  If you want to abandon the requirement for proof, go ahead please. But will you enjoy living in a world of where ANY idea deserves merit without substantiation? I personally think your just arguing for the sake of argument; it's hard for me to believe you assume everything/every idea true by default.  Perhaps you enjoy philosiphy? See next item....
3.  One thing I am definately not interested in is a debate of science vs. rational/justification of mathematical assumption(s), which is really a philisophical debate. A google newsgroup search will probably yeild hundreds if not thousands of results, if this is of interest to you.
-Chris
SACD vs. DVD-Audio
Reply #39
Chris,
Let's prove the results of this scientific research, OK?
Very old research using 500Hz tone with harmonics till 25kHz. Actually they were defining the audibility of harmonics of one tone, not ultrasonic images. Their result - 15kHz is enough even with the phase distortions of analog cut-off filters. Enough for what? For mp3 or for 500Hz tone? May be ... It is THAT easy to break those scientific research results for the music signal of high resolution ... here are two files for download, both made from the same source - the spectrum of one is limited at 30kHz (as you suggest, anyway we don't hear ultrasonic images, then no reason to limit 30kHz spectrum to 25kHz to match the results of those measurements), the spectrum of another one is limited at 15kHz. Use DBT (I recommend ABX plug-in for foobar2000). Please note, that I used digital filtering WITHOUT phase shift. Score your result.
I got 13/20 in the beginning, and 15/20 (2.1% of guessing) after some time ... the limit is 5%, right? It means I can hear the difference. I am an average listener, because I made a sonogram at the doctor for my listening abilities ... the limit is 18kHz for me.
Then - this is REALLY IMPORTANT - I didn't use my perfect M&K 150 THX monitors here by purpose!!! I used Sony DP-IF5100 IR headphones, from analog output of Lynx L22 soundcard to analog input of DP-IF5100 ... I would like to remind that those headphones can handle only 48kHz sample rate ... and they convert the analog signal to digital ... we have the regular situation here with an average listener and average electronics ...
here are the results:
In the beginning: http://members.cox.net/alex_lat/Tests/beginning.PNG
After some training (I am sure I can do it better): http://members.cox.net/alex_lat/Tests/tests.PNG
And here are the files for you to do DBT:
I'd put two files at my server with 30kHz and 15kHz FR limits. My server's limit is 300mb, so please download the files fast enough: http://members.cox.net/alex_lat/Tests/Test.zip
Used software - Adobe Audition 1.5, Marquee tool.
Here is the comparison of spectrums for two signals:
http://members.cox.net/alex_lat/Tests/test1.PNG
SACD vs. DVD-Audio
Reply #40
[a href="index.php?act=findpost&pid=236562"][{POST_SNAPBACK}][/a]
Well, we can say 2-4=-2, but we can't say "This statement is false" is false.
More to the point of the topic: you are grossly confusing inductive reasoning (science and statistics - from the specific case to the general case) with deductive (mathematical - from the general to the specific) reasoning. Physical phenomena can't be directly reasoned with deductively, because we can't test each statement across all possible values and cases. When we make any statements about reality, we must implicitly weigh them against the weight of the observations backing up those statements.
SACD vs. DVD-Audio
Reply #41
Chris,
I don't know what you mean by prove.  That is a peer-reviewed journal paper. Has not been successfully discredited in the over 2 decades it's been around. :-)
And, what is the problem with the test signal? It's consistent test signal with spectral content that is broad and high in amplitude. As for ultrasonic image... that is an unproven concept, at least if you mean an 'audible' image.
Their result - 15kHz is enough even with the phase distortions of analog cut-off filters. Enough for what? For mp3 or for 500Hz tone? May be ... It is THAT easy to break this scientific research results for the musical signal of high resolution ... here are two files for download,
Easy? 1st, it seems you have not followed the other threads such as the 96khz listening test thread, etc.. You can't break this reseach so easily with so many open variables that can potentially cuase false positives. Their were some positive results obtained in that thread too(you should read it), but they are inconclusive due to lack of necessary controls/analysis of hardware.
Then their is the NHK labs experiment that used music program material, and more extensive precautions then the original JVC(plenge, schone, jubowski) research. Where were the ultrasonic images? Why could not one person identify these elusive ultrasonic images? A test performed using equipment and recordings that were insured to have rich ultrasonic content. Maybe the test was 'fixed'? :-)
A positive result from conditions/equipment/hardware/signals with unknown behaviour in ultrasonic frequencies does not conclude anything.
-Chris
SACD vs. DVD-Audio
Reply #42
"Prove" means - let's try to use those results for our music signals, as you tried to use them ... OK?
The problem is that 500Hz tone signal with harmonics is not equal to the misic signal, as well as a sine wave ...
I don't even need to break it  You can do it by yourself, if you will use the provided samples  Hardware? I had provided the used hardware, but it doesn't really matter
Let's do it step by step  First of all let's finish with the first scientific research, then we will talk about another one
Why "unknown behaviour" if we know the schematics and used elements with their limitations?
SACD vs. DVD-Audio
Reply #43
If you believe that, then consider it already broken. Their have been numerous 'tests' that established audibility WITHOUT closely analysing the source signal, ampllfiers, transducer distortions.....
Well, you seemed to not like the idea of non music signals. So with that NHK lab test using music signals, you can't use that as an objection.
No, we don't know. That's the point. We don't know what differences(errors) the filter may have caused in the software(careful analysis of test waveforms needs to be performed first, in the software before/after this filtering), the possibility of hardware distortion(transducers will very probably do this if the ultrasonic amplitude is anywhere near the ampllitude of the audible band content, see earlier referenced Griesenger presentation), possibility of error by person prepping the file(s), etc.
I have no intention of ABXing the files you presented(becuase of the above reasons), but I did download and the first thing I noticed is that you already made one error. ONe file is mono, while the other is stereo. Errors are easy to make. An error free test is very difficult to pull off. That's why I don't give much respect to such loosely controlled tests such as your trying to perform. No where near the level of controls are being used to near scientific validity.
-Chris
SACD vs. DVD-Audio
Reply #44
[a href="index.php?act=findpost&pid=236598"][{POST_SNAPBACK}][/a]
What is the relevance of ABXing a 15kHz low pass? Is it just to demonstrate that a previous experiment (which showed a 15kHZ low pass was inaudible) was wrong? I don't think we need to prove that again - there are enough threads already! Anyway, the experiment wasn't wrong - it showed that those listeners with those equipment listening to that particular sound couldn't detect a 15kHZ low pass filter. It's almost irrelevant to high quality music listening - drawing the conclusion that 15kHZ was enough for music was a false conclusion, but it's the applied logic that's faulty, not the scientific results.
As for the CD/SACD/DVD argument, none of them use a lowpass of 15kHz, so again, what are you trying to prove here?
David.
SACD vs. DVD-Audio
Reply #45
[a href="index.php?act=findpost&pid=236599"][{POST_SNAPBACK}][/a]
ok I did stear the discussion off topic so I'll just correct this last statement and switch gears.
The reason I said 2-4=-2 can't be said is because WmAx claimed we need to back-up with solid evidence, I made no statement of incorrectness of above math.
Second "This statement is false" is not a mathematical statement. A mathematical statement has to be either true or false and never both or neither. You are getting confuddled by logic statements, so it's better to stop with this here. Believe it or not this could get hairier than the audio discussion we have going on.
SACD vs. DVD-Audio
Reply #46
I make this a separate post, just so it doesn't get lost in above mess.
Is it possible (aka did someone try, successfully or not) to create a sound file which would be flat lined in the scope of current CD resolution (aka should be silent/have no information encoded) but have varying ultrasonic data (or anything else that CD format wouldn't store), varying for the purpose of creating interference pattern (i.e. don't just stick monotonous wave in there), and see if interference distortions propagate into audible segment (aka on playback we get spikes in what's considered audible segment)?
Someone experienced with Audition/SoundForge could attempt. Unless of course this has been tried and refuted before?
BTW:
last time I checked that thread the guy doing the listening could ABX 96 vs 44 flawlessly, what are you alluding to there?
SACD vs. DVD-Audio
Reply #47
[a href="index.php?act=findpost&pid=236707"][{POST_SNAPBACK}][/a]
Dude, it was a joke about Godel's Incompleteness Theorem! Laugh!
SACD vs. DVD-Audio
Reply #48
Alluding? If you paid attention to the enire poist, you would realize the results were inconclusive due to unverified hardware and distortion analysis.
-Chris
SACD vs. DVD-Audio
Reply #49
I'm not impressed by the grammar of the claim , and even less by the lack of scientific listening data in that white paper.  No description of listening test methods, controls, quantitation and statistical analysis of results...just a dubious claim that 'warmth, speed (!) and smoothness were the key words described by members of the listening panel'.  I already told you what my criteria for convincing comparison reports are..this doesn't even come close.
So, so far, neither of your links supports your claim, AFAIK..
Even Babelfish failed to find any proper listening test results on that site.
That's three sites, no joy.
And so far, no evidence other than anecdotal (from the manufacturer, in two cases).[/b]
Self is about as 'objectivist' as they come...maybe i'm missing something, but I don't see him advocating modding of devices like the top-line Pioneer receivers.[/b]
Depends on what the modification is, and what the evidence is for audible difference.  They deserve respect as far as their claims are supported by good reasoning and empirical evidence, no more, no less. It's quite possible -- I've seen it many times -- that smart people can believe wrong things as well as right things ...hey, it's happened to me once or twice too.  Chris Johnson, I am familiar with, and he *generally* takes care to support his claims....but I've also seen him get into some huge wars with objectivists over on RAHE overs some of his claims.  Have any of these people reported results of listening tests for particular mods?
No listening test results there.
THD point of view is not 100% relative to the sounding, though if we know the spectrum in the audible range, quite informative.May be this paper will be helpful fior you? http://www.essex.ac.uk/ese/research/audio_...20amplifier.pdf
Page doesn't open.. does it report properly done listening tests?
Again, SHOW ME THE PROPERLY DONE LISTENING TESTS.
Measurably differences do not necessarily translate into audible ones.  That's a foundational concept in this forum... which is why here, unlike on 99% of forums about audio, claims of audible difference have to be backed up by proper empirical tests.
