How to install Ogg Vorbis on something older systems
2002-07-21 15:53:13
How to install Ogg Vorbis on older systems? I'm searching for an exact description what system requirements are necessary to compiler Ogg Vorbis (there seems to be a lot).pfk@f:/home/cvs/ao > ./autogen.sh I am going to run ./configure with no arguments - if you wish to pass any to it, please specify them on the ./autogen.sh command line. Generating configuration files for libao, please wait.... aclocal libtoolize --automake automake --add-missing configure.in: 30: required file `./ltconfig' not found autoconf checking for a BSD-compatible install... /usr/bin/ginstall -c checking whether build environment is sane... yes checking whether make sets ${MAKE}... yes checking for working aclocal... found checking for working autoconf... found checking for working automake... found checking for working autoheader... found checking for working makeinfo... found checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for gcc... gcc checking for C compiler default output... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for ranlib... ranlib checking for ld used by GCC... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes ./ltconfig: ./ltconfig: No such file or directory configure: error: libtool configure failed pfk@f:/home/cvs/ao > Currently I was only able to compile Ogg Vorbis on a Debian system and such restrictions are a K.O. criterium for archiving tools. Second: Where can I find a static linked Ogg Vorbis Encoder and Decoder for Linux, Kernel 2.0.1...2.5.xx ? Especially for Linux static linked binaries making a lot of sense because every system uses slightly different libraries. The situation is actually worse than the situaution under Windows 95/NT 4.0.
