Topic: foo_massdelete (Read 44007 times) previous topic - next topic
foo_massdelete
Reply #75
The Link and Olive, thank you for feedback, but I've checked context menu of 0.9 before posting and there is no „File Operations->Delete files“. Maybe I should add more components from install package?
Loaded libraries for now:
CORE
foo_input_std.dll
foo_ui_std.dll
foo_rgscan.dll
foo_cdda.dll
Screenshot (19 Kb) of context menu:
http://www.kraeved.com/tmp/foobar09b10contextmenu.png
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
foo_massdelete
Reply #76
Perhaps it's foo_masstag (not sure). I have all components from the installer + some by foosion.
foo_massdelete
Reply #77
Yes it's foo_masstag =)
foo_massdelete
Reply #78
Great, that's it. Thank you
foo_massdelete
Reply #79
So am I understanding correctly that FB2K has a right click - delete file command built into it? But there is not a Recycle command?
If so, it would be great if this invaluable plugin could be updated to 0.9. Thanks.
foo_massdelete
Reply #80
Since v0.9 has the core functionality of foo_massdelete implemented, I will not update it anymore. I've published the source code for eveyone to play around ;-) http://pelit.koillismaa.fi/plugins/general.php#81
foo_massdelete
Reply #81
Very Good Plugin! I just decided to use foobar 0.83 rather than v0.9 for some incompatible issues(wma tag edting, foo_uie_lyrics search problems) and I am missing the quick delete command in V0.9 then I found this plug, it is great for me!
foo_massdelete
Reply #82
I really miss following functionality in v0.9
- Stop and restart playback if necessary (single file deletion only).
