Topic: Quick, simple encoding advice (Read 4373 times) previous topic - next topic
I'm about to encode a whole load of 24bit/48k .wav files as mpc.  I'm using --xtreme --xlevel --ms 15  --deleteinput and mppenc.exe version 1.14.
Will there be any problems?  Is the command line ok?
I would not use --deleteinput as this way I couldn't verify that all went well, but it's your choice
Life is Real...
(But not in audio :) )
Why not mppenc v1.15r?
Why "--ms 15" ?
It's a 'Jump to Conclusions Mat'. You see, you have this mat, with different CONCLUSIONS written on it that you could JUMP TO.
"Why "--ms 15" ?"
Dunno, read it some where.
Read here about --ms 15.
It's so easy, standard command line is:
--standard --xlevel
if you need higher bitrates:
--xtreme --xlevel
or
--insane --xlevel
Check "List of recommended MPC settings" http://www.hydrogenaudio.org/forums/index.php?showtopic=1927
--ms 15 ???
Why not --quality 5.7738826 --xlevel ? Sounds very cool...
