Topic: Mp4 plugin for Winamp? (Read 4475 times) previous topic - next topic
Where can I download this?
"For long you live and high you fly
But only if you ride the tide
And balanced on the biggest wave
You race towards an early grave."
Good ol' RareWares.
(bottom of the message)
Your MPEG4 link (http://www.inf.ufpr.br/~rja00/mpeg4.html)  doesn't seem to be working...
It's is not, it isn't ain't, and it's it's, not its, if you mean it is.  If you don't, it's its.
Inderdeed. Damn borky server.
But the mp4 Winamp input plugin is at the AAC section, "AAC/MP4 Input Plugins for Winamp2/3 and Sonique"
You are too fast Roberto...
Juha Laaksonheimo
INDEED HE IS...
Roberto is way too fast on posting answer to questions...
Cheers
AgentMil
-=MusePack... Living Audio Compression=-
Honda - The Power of Dreams
Originally posted by rjamorim
Good ol' RareWares.
Acually ol'  is true. The Winamp plugins are quite outdated.
The Winamp3 plugin doesn't seem to work with the current Winamp3 build.
I didn't update the plugins lately because there is some weird, weird bug that seems to affect only me. It instantly crashes Winamp if an AAC file is loaded.
I talked to other people about this bug and noone experienced it.
I would like to see this corrected before uploading, but, to make things worse, Menno is traveling.
So, I uploaded a freshly compiled plugin batch, plus FAAD and AACdecDrop.
Hope it works for you.
Regards;
Roberto.
Edit: The MP4 input plugin is still the old one, due to a compile bug.
I'm having a bit of trouble with these aac input plugins (i've got in_aac and in_mp4).  When loading a large (70 minute)  aac file in winamp, my whole system hangs for about 20 seconds before it will play.  This is pretty annoying!  Is this because aac files need a lot of work to decode and play compared to mpc & mp3?  (i have a p3-800, 256ram)
< w o g o n e . c o m / l o l >
