Topic: XMMS MPC Linux Plugin for x86_64 (Read 6389 times) previous topic - next topic
I've been trying to get the MPC plugin for XMMS to work with x86_64 and managed to get everything to compile by changing some of the gcc options.  Unfortunately, XMMS segfaults when I attempt to play an MPC file (though it will allow me to open the configuration window just fine).  Does anyone have the MPC plugin working on x86_64?
which version ?
It's a 'Jump to Conclusions Mat'. You see, you have this mat, with different CONCLUSIONS written on it that you could JUMP TO.
which version ?
[a href="index.php?act=findpost&pid=225307"][{POST_SNAPBACK}][/a]
XMMS 1.2.10
libmusepack 1.0a (had to add symbolic links to make it work, otherwise it wouldn't get found)
plugin version 1.1a3
I set the architechture to x86-64 in both makefiles because otherwise it would say that the architecture was incompatible, I'm running on my 32-bit partition at the moment or I'd give you the exact error.
The new version of libmusepack & the plugin work great on x86-64, just change the arch. in the makefiles:
old:
CPPFLAGS  = -Wall -fPIC -DPIC -O2 -march=i686 -pipe -DPOSIX -D_REENTRANT
new:
CPPFLAGS  = -Wall -fPIC -DPIC -O2 -march=x86-64 -pipe -DPOSIX -D_REENTRANT
