Topic: Vorbis 1.1 RC1 in SVN (Read 66161 times) previous topic - next topic
Reply #75
The bitrate is extraordinarily high because of the way I've tuned it to reduce pre-echo in samples like castanets.  For q 4, trying to get castanets to sound transparent was perhaps overkill so I'm in the process of down-tuning it to reduce the bitrate (so far, down 10 kbps).
Reply #76
I look forward to trying it out.    Although even with that inflated bitrate it still isnt right (at 2.5 secs) and i prefer the encode made from a managed version of megamix 2 (ive abxd successfully).    Can anyone explain why this would be the case?  Even just using gt3b2 with managed limits is pretty good - but at under q5.    And definitely better than either gt3b2/megamix2 at q4.99.
Does engaging the managed mode (without the -q mode) have an effect on the way the gt3b2 tunings (im assuming a lot of the tunings are for pre/post echo) are used?  Or maybe the usage of short vs long blocks?
Reply #77
[a href="index.php?act=findpost&pid=226205"][{POST_SNAPBACK}][/a]
Unfortunately, I don't have an answer for that but I'm certain someone else like nyaochi will since he knows the internals better than me.  This block switching thing is quite interesting and I wonder whether all this pre-echo tuning I do is really worth the effort.  I'll stop flooding this thread with binaries since I don't want to cause confusion with these different experimental versions floating around.
There will always be killer samples for all codecs, much like how amnesia, waiting, and fsol kill mpc --standard.  Good thing is that with these killer samples, you can devise fixes for them.
Reply #78
Hi.  This is my first (successful) foray into ABX testing.  I have never been able to successfully ABX anything unless the samples were encoded to super low bitrates (e.g. 64...).  I decided to embark on an experiment with the different Vorbis tunings available because I own a Rio Karma.  I am deciding if I should use either the new Xiph Vorbis 1.1 RC1, aoTuV b2, or the new megamix v2.  The current encoder/settings I use for my Karma are aoTuV b2 -q4.  While experimenting, I found a sample that I can very easily ABX from the original.
The sample is from Images and Words by Dream Theater.  The song is called “Surrounded” and I found I could ABX the solo keyboard introduction of the song.  I am very shocked at how easy it is to ABX this track with all three Vorbis tunings I tested.  All three tunings exhibit a louder sounding background hiss (this could be some sort of pre-echo or some other artifact that I have not the experience to name correctly) vs the original file.  Below are the ABX results.  I used foobar2000's ABX program.
foo_abx v1.2 report
foobar2000 v0.8.2
2004/07/18 12:17:18
File A: file://E:\Stuff\My Documents\My Music\Karma Music\Dream Theater - Images And Words - 04 - Surrounded.ogg
File B: file://E:\Stuff\My Documents\My Music\Karma Music\Dream Theater - Images And Words - 04 - Surrounded.flac
12:17:45 : Test started.
12:18:31 : 01/01  50.0%
12:18:39 : 02/02  25.0%
12:18:52 : 03/03  12.5%
12:19:02 : 04/04  6.3%
12:20:08 : 05/05  3.1%
12:20:20 : 06/06  1.6%
12:20:35 : 07/07  0.8%
12:20:57 : 08/08  0.4%
12:21:11 : Test finished.
Total: 8/8 (0.4%)
oggenc-megamix2 -q3.5 - -o %d
bitrate = 127
channels = 2
samplerate = 44100
bitrate_nominal = 120
codec = Vorbis
vorbis_vendor = Vorbis Megamix II: Xiph.Org 1.1 RC1 [20040629] + QKTune beta 3.2 + GTune 3 beta 2
foo_abx v1.2 report
foobar2000 v0.8.2
2004/07/18 12:37:08
File A: file://E:\Stuff\My Documents\My Music\Karma Music\Dream Theater - Images And Words - 04 - Surrounded.flac
File B: file://E:\Stuff\My Documents\My Music\Karma Music\Dream Theater - Images And Words - 04 - Surrounded.ogg
12:40:07 : Test started.
12:40:21 : 01/01  50.0%
12:40:35 : 02/02  25.0%
12:40:42 : 03/03  12.5%
12:40:58 : 04/04  6.3%
12:41:09 : 05/05  3.1%
12:41:21 : 06/06  1.6%
12:41:29 : 07/07  0.8%
12:41:42 : 08/08  0.4%
12:41:45 : Test finished.
Total: 8/8 (0.4%)
oggenc-1.1rc1 -q4 - -o %d
bitrate = 125
channels = 2
samplerate = 44100
bitrate_nominal = 128
codec = Vorbis
vorbis_vendor = Xiph.Org libVorbis I 20040629
foo_abx v1.2 report
foobar2000 v0.8.2
2004/07/18 12:51:07
File B: file://E:\Stuff\My Documents\My Music\Karma Music\Dream Theater - Images And Words - 04 - Surrounded aotuv.ogg
12:51:28 : Test started.
12:51:51 : 01/01  50.0%
12:51:59 : 02/02  25.0%
12:52:08 : 03/03  12.5%
12:52:15 : 04/04  6.3%
12:52:27 : 05/05  3.1%
12:52:36 : 06/06  1.6%
12:52:44 : 07/07  0.8%
12:52:53 : 08/08  0.4%
12:53:05 : Test finished.
Total: 8/8 (0.4%)
oggenc-aoTuV b2 -q4 - -o %d
bitrate = 125
channels = 2
samplerate = 44100
codec = Vorbis
vorbis_vendor = AO; aoTuV b2 [20040420]  (based on Xiph.Org's 1.0.1)
I lowered the quality setting on megamix v2 because I wanted to test at a similar bitrate (128) and the setting of 3.5 gave me closest to that bitrate with this tuning.
I don't know if this helps anyone out much, but I hope it does.
Sample uploaded here:
http://www.hydrogenaudio.org/forums/index....ndpost&p=227000
Reply #79
Dont know if this will help, best results i could get with my problem sample (without resorting to using the managed mode) was from garfs GT2 tuning of the old RC2 encoder:
http://sjeng.org/vorbisgt2.html
Reply #80
That's an good suggestion. I guess oggenc does have much less tweaking options than mppenc.
Or even better a few added command-line switches to the advanced-encode-option on the encoder that allow you to tweak noise biasing and mapping values, etc? Would be quite convenient ;-D.
There is already a switch for tweaking noise bias.  Check [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=23466&view=findpost&p=227974]this[/url] out.
Reply #81
Given different time zones, I'll have compiles at Rarewares later in the day (my time).
[a href="index.php?act=findpost&pid=224046"][{POST_SNAPBACK}][/a]
John : could you make a compile of libvorbis.dll using this 1.1 RC1 ?? This library is not on rarewares.org now...
Reply #82
[a href="index.php?act=findpost&pid=237138"][{POST_SNAPBACK}][/a]
Standard and P4 compiles now at Rarewares.
