Topic: MAREO settings for FLAC + LAME (Read 4379 times) previous topic - next topic
  • neuron132
Can someone help me with MAREO settings for MP3s at LAME's Extreme preset plus FLAC at the highest compression setting?
I'm having trouble...
"could not find e:\classic\Mathew Locke - Gavott.wav"
is the error I get in MAREO.  The FLAC is fine, though.
-Ron
  • kwanbis
  • Developer (Donating)
post the whole log file ... and the ini
  • neuron132
Log:
MAREO - (M.)ultiple (A.)pplications (R.)unner for (E.)AC and (O.)thers.
v1.5.1 - Developed in Borland Delphi - Copyright 2003 - 2004 by Kwanbis.
Dedicated to the Hydrogenaudio community; EAC (best Free CD Ripper), CDex (best Open Source CD Ripper), foobar2000 (best Audio Player), Ogg Vorbis (best Open Source MP3 alternative) and LAME (best MP3 encoder) developers, and to Borland, for Delphi & Kylix, the very best Windows and Linux programming environments.
+++ FREE For Commercial and Non-Commercial Use +++
*** Received Command Line ***
"C:\dj\eac\mareo.exe" EAC "Mathew Locke - Gavott.wav" "E:\classical\flac\Mtmp7898(.wav" "E:\classical\flac\Mtmp7898(.flac" "Mathew Locke" "Musical Life of Samuel Pepys; Richard Wistreich & Robin Jeffrey" "Gavott" "1" "1990" "Soundtrack"
*** Parsed Parameters ***
  @program@ (%1) = EAC
@finalname@ (%2) = Mathew Locke - Gavott.wav
  @source@ (%3) = E:\classical\flac\Mtmp7898(.wav
    @dest@ (%4) = E:\classical\flac\Mtmp7898(.flac
  @artist@ (%5) = Mathew Locke
  @cdname@ (%6) = Musical Life of Samuel Pepys; Richard Wistreich & Robin Jeffrey
@songname@ (%7) = Gavott
    @track@ (%8) = 1
    @year@ (%9) = 1990
    @genre@(%10) = Soundtrack
*** PROCESSING LINE 1 ***
flac NONE NONE "C:\program files\flac\flac.exe" -8 "@pathonly@\@nameonly@.wav" --output-name="@dest@" -T artist="@artist@" -T album="@cdname@" -T title="@songname@" -T tracknumber="@track@" -T date="@year@" -T genre="@genre@" -T comment="EAC 0.95pb3 + FLAC 1.1.0 compression-level-8"
*** Track 1 Parameters ***
  @extonly@ = flac
  @pathonly@ = E:\classical\flac
  @nameonly@ = Mtmp7898(
  @fullname@ = E:\classical\flac\Mtmp7898(.flac
*** Final Name Parameters ***
Final Name Name Only = Mathew Locke - Gavott
Final Name Path Only = E:\classical\flac
Final Name Full Name = E:\classical\flac\Mathew Locke - Gavott.flac
*** EXECUTING ***
"C:\program files\flac\flac.exe" -8 "E:\classical\flac\Mtmp7898(.wav" --output-name="E:\classical\flac\Mtmp7898(.flac" -T artist="Mathew Locke" -T album="Musical Life of Samuel Pepys; Richard Wistreich & Robin Jeffrey" -T title="Gavott" -T tracknumber="1" -T date="1990" -T genre="Soundtrack" -T comment="EAC 0.95pb3 + FLAC 1.1.0 compression-level-8"
*** PROCESSING LINE 2 ***
mp3 NONE NONE "C:\program files\LAME\lame.exe" --alt-preset extreme -Z --ta "@artist@" --tl "@cdname@" --tt "@songname@" --tn "@track@" --ty "@year@" --tg "@genre@" --tc "EAC 0.95pb3 + LAME 3.90.2 alt-preset standard -Z" "@pathonly@\@finalname@" "@pathonly@\@nameonly@.mp3"
*** Track 2 Parameters ***
  @extonly@ = mp3
  @fullname@ = E:\classical\flac\Mtmp7898(.mp3
Final Name Full Name = E:\classical\flac\Mathew Locke - Gavott.mp3
*** EXECUTING ***
"C:\program files\LAME\lame.exe" --alt-preset extreme -Z --ta "Mathew Locke" --tl "Musical Life of Samuel Pepys; Richard Wistreich & Robin Jeffrey" --tt "Gavott" --tn "1" --ty "1990" --tg "Soundtrack" --tc "EAC 0.95pb3 + LAME 3.90.2 alt-preset standard -Z" "E:\classical\flac\Mathew Locke - Gavott.wav" "E:\classical\flac\Mtmp7898(.mp3"
ERROR: "C:\program files\LAME\lame.exe" --alt-preset extreme -Z --ta "Mathew Locke" --tl "Musical Life of Samuel Pepys; Richard Wistreich & Robin Jeffrey" --tt "Gavott" --tn "1" --ty "1990" --tg "Soundtrack" --tc "EAC 0.95pb3 + LAME 3.90.2 alt-preset standard -Z" "E:\classical\flac\Mathew Locke - Gavott.wav" "E:\classical\flac\Mtmp7898(.mp3" returned the error code 1
*** DONE ***
1 errors ocurred. Press any key
ini:
; Flac 'high'
; Wave Normalize
; wav NONE NONE "C:\Wavegain\Wavegain.exe" --radio --apply "@pathonly@\@nameonly@.wav"
; MP3 LAME "extreme" (220-320 kbps VBR -- usually averages around 240 kbps):
; Remove No-Longer Needed Wave
;  wav NONE NONE "@ownpath@\delete.bat" "@pathonly@\@finalname@"
  • kwanbis
Log:
*** EXECUTING ***
*** EXECUTING ***
the source file on line 2 (E:\classical\flac\Mathew Locke - Gavott.wav) is wrong, the source should be the same as the one in line 1 (E:\classical\flac\Mtmp7898(.wav).
  • Last Edit: 07 July, 2004, 08:31:38 AM by kwanbis
  • neuron132
I'm sorry -- I don't know how to fix that.
-Ron
  • phwip
  • Members (Donating)
I think all you should need to do to fix the problem is replace "@pathonly@\@finalname@" in your mp3 line in the ini file with "@source@"
You can also make the ini file a little more readable by using "@source@" instead of "@pathonly@\@nameonly@.wav" throughout.  And by using "@fullname@" instead of "@pathonly@\@nameonly@.mp3" in the mp3 line.  But that's just a matter of personal preference.
Edit: Typo.
  • Last Edit: 07 July, 2004, 10:51:34 AM by phwip
  • kwanbis
that's it
  • neuron132
I'm in business!  t h a n k  y o u  g e n t l e m e n..
  • neuron132
[a href="index.php?act=findpost&pid=223902"][{POST_SNAPBACK}][/a]
Now that I have ripped a fesw CDs, I have a new problem:  getting  MAC 2.92 to scan the FLAC files.  It just seems to stall on .flac files.  I tried it on tow machines, with DVD and HDD (also with and without tags enabled in EAC) on each and the same resustls.
Having the flac's won't be that useful without a good catalog.
-Ron
  • neuron132
Now that I have ripped a few CDs, I have a new problem:  getting  MAC 2.92 to scan the FLAC files.  It just seems to stall on .flac files.  I tried it on tow machines, with DVD and HDD (also with and without tags enabled in EAC) on each and the same resustls.
-Ron
[a href="index.php?act=findpost&pid=224470"][{POST_SNAPBACK}][/a]
OK.  I tried making a few flacs directly from wavs using the front end.  These files scanned fine with MAC, so I figured something in the above code for MAREO was making MAC choke.  I thought I would strip the tags from files made via MAREO, and I loaded the folder intoTGF, but there seemed to be no tags.  And MAC still doesn't like them.
If anyone has any ideas, I'd love to hear them.
-Ron
  • neuron132
BTW, I found the catalog in TGF, and it scans the flacs fine.
Still puzzled,
-Ron
