Topic: HA Knowledgebase (Read 7377 times) previous topic - next topic
HA Knowledgebase
Yes, the site is down.  It will be back soon.
HA Knowledgebase
Problem is still here...
HA Knowledgebase
Is there any posibility to put the knowledgebase online in any form?
Ple-ease! It's very VERY helpfull...
HA Knowledgebase
It will be online in a read-only state since dibrom wants to change wiki system.
It will happen when dibrom has time....
HA Knowledgebase
It's back up.
Hopefully it will be more active than before.
HA Knowledgebase
Right now I'm a bit torn between whether I should just leave the system as it is, or really move to mediawiki.  If people are barely going to use it, it's not worth the time it'd take to learn and move over to the new software.  On the other hand, if it's going to be seeing heavy use, then it makes more sense to have that done with the newer system...
HA Knowledgebase
Is the registration disabled? It gives me SMTP errors with all my email addresses.
HA Knowledgebase
[a href="index.php?act=findpost&pid=232797"][{POST_SNAPBACK}][/a]
I just changed something and then tried registration myself again and it works.  You might want to give it another shot now.
HA Knowledgebase
Still doesn't work for me.
We were unable to send your password to your email address: {'ruby@****': (550, '(agent.animus-facticius.org) [209.152.181.169] is currently not permitted\nto relay through this server. Perhaps you have not logged into the pop/imap\nserver in the last 30 minutes or do not have SMTP Authentication turned on\nin your email client.')}
HA Knowledgebase
[a href="index.php?act=findpost&pid=232804"][{POST_SNAPBACK}][/a]
I made another possible changed, and was able to register again without errors using a different email.
Might work for you now.
HA Knowledgebase
Yes, it works now. Thanks.
