Topic: Odd behavior with FLAC commandline encoder (Read 1928 times) previous topic - next topic
Hello all.
I'm converting a large number of files to FLAC using fb2k and noticed a difference in filesize between a file created with fb2k's diskwriter and FLAC Frontend.
At first I thought the difference was simply because of tags added by foobar, but it remained even after I changed the tags option to "none".
I'm not using DSP, replaygain, or dithering the output.
I'm using FLAC 1.1.0, with a command line of "- -P 4096 -b 4608 -m -l 12 -e -q 0 -r 0,6 -V -o %d" entered into the fb2k diskwriter encoder parameters.  This is the same command line that FLAC Frontend was feeding to flac.exe.
The file that fb2k outputs is 20,141,264 bytes for a compression ratio of .5486.  The FLAC Frontend file is 20,119,718 bytes (.5480).  The decoded waves are the same in a bitcompare, and foobar reports that neither file has any tags.
I'm at a loss here.  Any ideas why flac.exe would output a different file based on the same parameters?  Is it something in foobar that I'm missing?
Yes.. it was something I was missing..
Checking the "encoder requires accurate length" box resulting in fb2k outputting the same file.  I suppose if you leave it unchecked it adds some padding of some kind?
Oh well, thanks for reading.
