Topic: foo_rmx beta (Read 83745 times) previous topic - next topic
foo_rmx beta
Reply #175
maybe not the right place to ask but im playing around with the stand alone version and i cant find a way to control the system volume when using it.
as in, i have two multimedia keys that is supposed to control volume up and down (and a mute to), but how do i go about assigning those to volume control?
do i need to write a script or something?
i thought that by adding the system mixer plugin i should get the option to do simple volume control...
what you request currently isnt available.  this is a planned feature of the system-mixer though.  the problem is?  the required API for it is only a month old now, and other things have had much higher priorities.
-=- Darkain Dragoon -=-
foo_rmx beta
Reply #176
well there i no hurry darkain. by setting up some hotkeys in powerpro and using rmx stand alones ability to send keyboard combos i made them interact
in theory i should be able to use powerpro (and have so in the past) to manage those keys. but the internal key recognition system for powerpro do not see said multimedia keys, and the plugin that supposedly extends on it appears to be temperamental...
now, while there is a good deal of overlap between powerpro and rmx, it would be interesting to have a plugin that allowed on to interact with the other.
i tried to do so by using the "launch" function in rmx to send commandline commands to powerpro, but that didnt work for some reason. maybe if i buildt some batch scripts or similar but that would be to much work
still, the hotkeys work for now
foo_rmx beta
Reply #177
1) never heard of powerpro, i'll look into it, eventually (and possibly make a plugin?)
2) come to think of it, i dont think RMX's "launch" command supports command line arguements, i'll look into this and implement it ASAP if its not already there
foo_rmx beta
Reply #179
Darkain. First of all, thanks for the RMX program. Its very usable in my everyday life.
I suggest that you make it an option to close windows media player just like its possible to close winamp and bsplayer with one button.
I have an audigy 2 zs platinum pro. that means i have a big box outside the computer and when i touch any of its buttons and have rmx running at the same time, rmx crashes... to bad. just wanted to hear if any has the same error?
thanks again darkain.. it must be nice to help so many people
foo_rmx beta
Reply #180
what version/build are you using?  please attach your master.xml file.
foo_rmx beta
Reply #181
im using the 19. of january edition of both media edition and standalone edition. following is the code in the master.xml for standalone edition which crashes as well as the media edition and winamp as well when i touch the extern panel for audigy 2 platinum pro.
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
- <plugin>
- <root name="Master" expanded="0" id="-456091386476183744">
  <info name="Identification" lib="20070119" sdk="20070119" windows="5.2.3790" platform="2" arch="x86" />
  <function name="[NONE]" id="-1443182112830393600" />
  <function name="Script Command" expanded="0" id="7037930815016912896" />
- <tree name="Scripts" expanded="0">
  <button name="Reset Scripts" />
  </tree>
- <tree name="Plugins" expanded="0">
  <bool name="App Commands" expanded="1" filename="app_commands.dll">1</bool>
  <bool name="IntelliRemote" expanded="1" filename="intelliremote.dll">1</bool>
  <bool name="Power Management" expanded="1" filename="power_management.dll">1</bool>
  </tree>
  <function name="Launch" expanded="0" id="6933527318802745344" />
- <tree name="Configuration" expanded="0">
  <bool name="Enabled">1</bool>
  <bool name="Tray Icon">1</bool>
- <bool name="Configuration Window" expanded="0">
  0
  <int name="X">204</int>
  <int name="Y">159</int>
  <int name="Width">597</int>
  <int name="Height">400</int>
  </bool>
- <bool name="Console Window" expanded="0">
  0
  <int name="X">0</int>
  <int name="Y">0</int>
  </bool>
  </tree>
  </root>
  </plugin>
foo_rmx beta
Reply #182
I'll be honest.  I don't have any Creative hardware anymore.  Theres not a whole lot of testing I can do.  The entirety of RMX is open source now, so if someone else wants to take a dab at it, they can.
foo_rmx beta
Reply #183
Unfortunately I do.  I have an Audigy 2 platinum ex and i have the exact same problem.
Disappointed to hear this. This is the main reason why I had to uninstall RM-X. Well...i'll just keep my fingers crossed then...hoping to see a fix for this.
-DudeXP
foo_rmx beta
Reply #184
Please add a plugin with the ability to use the x10 usb RF remote
foo_rmx beta
Reply #185
I've been trying to figure out if there's a way to have more functions than the basic play/pause/stop/volume up/volume down. Is there one?
Also, I can't find anywhere what the LUA scripts can do except print("????"). Anyone can help?
