Topic: foo_rmx beta (Read 64774 times) previous topic - next topic
  • 4nt1
foo_rmx beta
Reply #125
darkain you the man!!!
thankyou sooo much
foo_rmx beta
Reply #126
Before I get started messing with the settings, I was wondering if this supports commandline arguments like "foobar.exe runcmd=YOUR COMMAND". How would one implement or gain some kind of access to menu commands with the Script Command function?
  • darkain
foo_rmx beta
Reply #127
currently, the scripting system in RM-X has no access to foobar specific functions, and RM-X does not work with foobar's command line paramater interfaces.
The "Script Command" function will execute Lua scripts.  The best way currently to experiment with this would probably be the Telnet plug-in for RM-X, as its an interactive Lua console with some basic help features implemented into it.
-=- Darkain Dragoon -=-
foo_rmx beta
Reply #128
darkain,
First off, thank you very much for taking the time to port RM-X over to foobar 0.9. I don't know what I would do without this plug-in.
I've been playing with the beta on my system using 0.9.4, and am running into a few problems.
1. No matter which percentage I set the volume up/down buttons to change, pressing the buttons causes the volume to change from 100% to 0%, with no steps in between.
2. The Play/pause button no longer functions correctly. It will properly play a track, but it does not pause.
Hopefully the bugs can be worked out without taking too much time. Thanks again!
  • bytemastr
foo_rmx beta
Reply #129
I get this error when attempting to download this link: http://www.darkain.com/Download/foo_RMX.dll
Not Found
The requested URL /Download/foo_RMX.dll was not found on this server.
Additionally, a 500 Internal Server Error error was encountered while trying to use an ErrorDocument to handle the request.
[UPDATE for foobar2000 0.9]
Install RM-X Media Edition v1.2 and replace the foo_RMX.dll component with this file.
[/UPDATE]
  • darkain
foo_rmx beta
Reply #130
Not Found
[/UPDATE]
it should all be up and running now (hopefully).  we are in the process of switching web hosts at the moment though, so things are iffy for the time being.
foo_rmx beta
Reply #131
noticed this myself...
just moved over from winamp because the latest release was cpu-hungry as hell. foobar2k barely register in comparison...
edit (late one, sorry. but i dont see the need to post another time on this):
it allso seems that using a hotkey or similar to put the music on pause, and then trying to hit the rmx-managed play/pause button on my keyboard will not unpause the music...
  • Last Edit: 22 October, 2006, 02:55:52 PM by turn.self.off
  • Headless
foo_rmx beta
Reply #132
Awesome plugin. I just got an X-Fi Platinum with the RM1800 and i'm really liking how this works. I noticed the featureset for foobar2k was a bit sparse and was hoping i could use the 'script option' to send it a command or two that wasn't supported, but just saw the post saying that it doesn't interface with foobar2k  With that knowledge in hand, I wanted to ask if it's possible to add the ability to bind a key to the option 'Playback->Stop After Current'...Any chance?
  • darkain
foo_rmx beta
Reply #133
all of the "playback" options available in foobar 0.8 where supported, however, i didnt get that feature re-implemented in the foobar 0.9 build yet.  SO!  if you want it, switch back to foobar 0.8 or use Winamp for the time being.
  • Headless
foo_rmx beta
Reply #134
Hello, and thanks for the response!
I actually tried the 0.8 version first. Neither the 0.9 or 0.8 version includes the option to toggle 'stop after current' menu item in foobar2k  I can choose 'playback order' but i only get the options for Default/Repeat/Repeat one/Random.
  • Last Edit: 05 November, 2006, 10:27:10 AM by Headless
  • darkain
foo_rmx beta
Reply #135
Alrighty.  Its been a while since I've activly worked on RM-X.  I've been focusing more on other projects lately.
Anyways, I just looked into things... And heres how it goes..
* Volume changes to always min/max - FIXED
* Pause, Play/Pause not pausing/unpausing at all - FIXED
* Stop After Current - ADDED
I'll try to get an instal up sometime this week.
foo_rmx beta
Reply #136
looking forward to it
  • darkain
foo_rmx beta
Reply #137
RM-X has seen quite a few library changes lately (due to quite a few of the ones used going silent/dead).  So this is my major slow-down, trying to get the new libraries doing what I want.  I found a major issue with the new XML parser last night, so I've had to slow down things a bit to worry more about the libraries then getting things working for the specific media players.  I'll try to get something out in the next 24 horus tho.  (I kinda wish it was already out tho, but I gotta make sure it works)
foo_rmx beta
Reply #138
better that it works out of the "box" then it needs patch after patch for basic functionality
  • darkain
foo_rmx beta
Reply #139
From Darkain.com:
Two pieces of news to talk about...
Firstly!
Here is a shout-out to all of you developers out there!  Many of the users of RM-X are knowledgable in computer programming as well as hardware/software interaction.  RM-X supports a free and open-source SDK for developing RM-X plugins.  RM-X itself as well as all of the first-party plugins are built directly off of this SDK.  We simply don't have the resources to support every possible device in the world, so we are asking that those out there in the world who use this piece of software to help and contribute.  Most of the first-party plugins are also included with the SDK, so additions/fixes to these are always welcome too!
Secondly!
RM-X v1.3 (20061129) is now available.  This address some specific issues with foobar2000 as well as the XML parser.  This build also has added some basic UTF-8 support to the RM-X core, but should be considered highly experimental at this time.
foo_rmx beta
Reply #140
downloading as i write this.
foo_rmx beta
Reply #141
works fine so far. about the only problem i have had is the odd "cant create tooltip" error...
  • darkain
foo_rmx beta
Reply #142
please send me your "\RMX Settings\Master.xml" file.
foo_rmx beta
Reply #143
how do you want that done? by mail or some other way?
  • darkain
foo_rmx beta
Reply #144
its just a small text file.  you can post it here, or PM me.  either is fine.
foo_rmx beta
Reply #145
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
- <plugin>
- <root name="Master" expanded="0" id="563722862982163648">
  <info name="Identification" lib="20060920" sdk="20060920" windows="5.0.2195" platform="2" host="foobar2000" />
  <function name="Script Command" expanded="0" id="220075391346423488" />
- <tree name="Scripts" expanded="0">
  <button name="Reset Scripts" />
  </tree>
- <tree name="Plugins" expanded="0">
  <bool name="Updates" unique="Updates.dll" expanded="1">1</bool>
  <bool name="User Input" unique="User Input.dll" expanded="1">1</bool>
  </tree>
- <group name="Playback" unique="player" expanded="0">
  <function name="Play" unique="play" id="699806526742492928" />
  <function name="Play/Pause" unique="playpause" id="167717648411599200" />
  <function name="Pause" unique="pause" id="757296416206709504" />
  <function name="Stop" unique="stop" id="611868565957642240" />
  <function name="Previous Track" unique="prev" expanded="0" id="32925850847846912" />
  <function name="Next Track" unique="next" expanded="0" id="509090879044722688" />
  <function name="Random Track" unique="randtrack" id="311438189129433664" />
  <function name="Playback Order" unique="order" expanded="0" id="409870932531088384" />
  <function name="Fast Forward" unique="ffwd" expanded="0" id="1037437062653322496" />
  <function name="Fast Rewind" unique="frwd" expanded="0" id="1094519875211167232" />
  </group>
- <group name="Volume" unique="volume" expanded="0">
  <function name="Up" unique="up" expanded="0" id="720185476318565760" />
  <function name="Down" unique="down" expanded="0" id="1152487476923115264" />
  <function name="Mute" unique="mute" id="170504919036242592" />
  </group>
- <tree name="Configuration" expanded="0">
  <bool name="Enabled">1</bool>
  <bool name="Tray Icon">0</bool>
- <bool name="Configuration Window" expanded="1">
  0
  <int name="X">140</int>
  <int name="Y">188</int>
  <int name="Width">600</int>
  <int name="Height">516</int>
  </bool>
- <bool name="Console Window" expanded="0">
  0
  <int name="X">0</int>
  <int name="Y">0</int>
  </bool>
  </tree>
- <root name="Playlist" expanded="0" id="406340143039852480">
  <info name="Identification" lib="20060920" sdk="20060920" />
  </root>
  </root>
  </plugin>
  • darkain
foo_rmx beta
Reply #146
Well, first off, it appears that the version of RM-X that you are using is a few months out of date.  But, I don't think much has changed in the windowing code though.  So I'll go ahead and start running some tests on Windows 2000.
foo_rmx beta
Reply #147
heh, that may result from me installing the beta over the existing rm-x install...
that way i didn't have to do all the settings again
  • darkain
foo_rmx beta
Reply #148
you ARE using a beta though.  an older beta.  and as for plugins, they dont matter a whole lot.  plugins from the begining of the year till now a nearly identicle.  the main RM-X core is the only thing receiving updates.
foo_rmx beta
Reply #149
strange, the one im using is the one you posted about above...
