Topic: Exact Audio Copy (Read 4812 times) previous topic - next topic
Exact Audio Copy
Hello!
I am experiencing some problems with EAC's synchronized mode. Everytime Exact Audio Copy tries to find the starting sector, I get "Unhandled exception at 0045DE27 -> ACCESS_VIOLATION". It seems that I get this error with all drives and with all drivers (ASPI, ASAPI and NT Native Interface). Secure and burst mode work OK. Paranoid mode is suffering under the same problem.
BTW, don't tell me that I should use secure mode, as I do that 99.9% of the time. It's just that I have this badly scratched CD which reports read errors with secure mode and burst mode. Wanted to try out the other two options as well. Also, I am aware of the fact that paranoid mode might damage my drive.
Regards,
Sebastian Mares
  • Last Edit: 31 May, 2004, 06:59:43 AM by Sebastian Mares
  • Halcyon
Exact Audio Copy
Have you tried this (taken from EAC forums):
"Deactivate LAME or Ogg ACM Codec (Nemo Codec Pack)..."
regards,
halcyon
Exact Audio Copy
I don't even have them installed.
Anyways, the error pops out just after starting (it says "Spin up drive" -> OK; "Searching for start sector" -> Error). It happens on both test and copy mode.
  • kl33per
Exact Audio Copy
You could take some brasso to it.  That always helps on my CD's.
www.sessions.com.au - Sessions Entertainment
Exact Audio Copy
What on earth is brasso?
FreeTranslation.com didn't know how to translate that.
  • boojum
  • Members (Donating)
Exact Audio Copy
Brasso is an Anglo-American metal polish.  I finer one is Simichrome.
Nov schmoz kapop.
Exact Audio Copy
Well, it might help the CDs, but it won't help EAC.
  • Halcyon
Exact Audio Copy
What ASPI layers have you tried? Adaptec (which version)? Nero? VOB ASAPI?
This might be totally off-the base as well, I'm purely guessing here...
  • kennedyb4
Exact Audio Copy
It may if the first few sectors are under a scratch.
Eac has never performed well for me on badly scratched cd's.
Resurface the cd as suggested and see what happens.
Exact Audio Copy
Initially, Adaptec ASPI drivers, but then I copied the Nero ASPI DLL to system32 and also to EAC's directory, but it didn't help. I also tried the VOB ASAPI drivers and the Windows NT Native Inteface without success.
Nope, that isn't the cause. It happens on all CDs,
  • Never_Again
Exact Audio Copy
If neither Secure nor Burst mode extracted the audio properly, Synchronized mode won't help.
Try PlexTools Pro with a Plextor drive (preferably a Premium). Resurfacing is the last resort.
Exact Audio Copy
OK, thanks. Unfortunately, I don't have access to any Plextor drive. I will try to polish the sourface.
Anyways, that isn't the big deal. The problem is that I don't know how to get rid of the error.
  • Last Edit: 31 May, 2004, 01:58:28 PM by Sebastian Mares
  • Jan S.
Exact Audio Copy
I think you should post this EAC forum. I get the same errors.
No program should give AV errors for any reason.
  • Madrigal
Exact Audio Copy
Have you tried de-activating "Spin up drive before extraction" under Drive options?
Regards,
Madrigal
Exact Audio Copy
OK, just did and it now crashes right away.
