Topic: In Vorbis 1 specification (Read 3526 times) previous topic - next topic
  • yesjoon
I don't understand below explanation.
In Vorbis 1 specification, 3.2.1. codebook decode
If the [ordered] flag is unset, the codeword list is not length ordered and the decoder needs to read each codeword length one-by-one.
The decoder first reads one additional bit flag, the [sparse] flag. This flag determines whether or not the codebook contains unused entries that are not to be included in the codeword decode tree:
byte 8: [            X 1 ] [sparse] flag (1 bit)
The decoder now performs for each of the [codebook_entries] codebook entries:
  1) if([sparse] is set){
        2) [flag] = read one bit;
        3) if([flag] is set){
              4) [length] = read a five bit unsigned integer;
              5) codeword length for this entry is [length]+1;
            } else {
              6) this entry is unused.  mark it as such.
    } else the sparse flag is not set {
        7) [length] = read a five bit unsigned integer;
        8) the codeword length for this entry is [length]+1;
==> '1' is [ordered] bit and 'X' is [sparse] bit. Is it right?
What is a difference between "1) [sparse] is set" and " 3) [flag] is set" ?
  • kjoonlee
byte 8: [               X ] [ordered] (1 bit)
byte 8: [             X 0 ] [sparse] flag (1 bit)
byte 8: [           X 1 0 ] [flag] flag (1 bit)
  • Last Edit: 26 May, 2004, 10:54:33 PM by kjoonlee
  • kjoonlee
I got some big help from Xiph.org (Michael Smith in particular) in writing that answer, but I still might be wrong.
If you want a definitive, accurate answer, then please email vorbis-dev@xiph.org with your question.
  • kjoonlee
An unchained Vorbis stream has one (1) codebook header packet, which contains all the codebooks that are used in that stream.
For each codebook, [sparse] is always read.
if [sparse] is 1, then [flag] is read for each and every "codebook entry"/"codeword."
Thanks go to Michael Smith.
