Topic: Seeking freeware for real-time frequency analysis (Read 4969 times) previous topic - next topic
Hi - I'm looking for a program (Windows XP) which will, on a real-time basis, show a frequency analysis when I play music on my computer. I use iTunes and I'm looking for a program which can read the signal off the soundcard and show the frequency analysis. Preferable freeware. Cheers.
Something like that?
foobar2000 shows them during playback as visualisation.
Foobar's visualization is nice but I would like to see some gridlines in it ... perhaps RightMark Audio Analyzer (RMAA) could be a solution, too
The name was Plex The Ripper, not Jack The Ripper
well, not quite. i'm looking for a program which will pickup the signal from the soundcard. i should be able to continue to use itunes for playback and this program (which i;m looking for) should show frequency analysis (not spectral analysis. any thoughts?
Is this a candidate.
http://www.pas-products.de/
thanks. but i was looking for something which can (a) work with itunes - i.e. read the signal off the soundcard and (2) freeware/shareware!
How about this? (Japanise prog.  )
http://www.ne.jp/asahi/fa/efu/soft/ws/wsimage.html
chief, so far you are the closest! though i wish this program had one additional feature: always on top!
however, this program has one flaw: the "noise" level (i.e. when there is no signal is quite high). with adobe audition, where there is no input signal, i see a flat line at -120 dB. any program which doesnt have this problem?
window shot:
http://gmc2004.tripod.com/noise.jpg
Go into your volume control and make sure mic and line inputs are muted. Even with nothing plugged in, they can contribute a small about of noise.
