Topic: Cosmetic glitch in v0.8.2 (Read 3991 times) previous topic - next topic
Hi!
Using foobar v0.8.2, W2K+SP4, S3 Trio 3D/2X
Everytime I use from menu Playback->Order and choose a value out of the four ones, a white vertical line appears to the left of "Foobar" menu item
You can see that here:
This doesn't happen if I choose the value that is currently selected, only if I choose one of the rest.
EDIT: I use "Lock the toolbars" and it seems that this line appears in place of the grey vertical slider that exists to the left of "Foobar" menu item when "Lock the toolbars" is not selected.
I could not reproduce in WXP Home version.
Nov schmoz kapop.
can't reproduce XP Pro.
Couldn't reproduce on XP Home (with Classic mode running (same appearance as Win2k))
Steve
Can't reproduce in W2k SP4 either.
Alessandro
Maybe its something to do with ur menu animation Wizard?
Steve
ok guys, thanks for the replies    I guess it must be specific to my system. If I find out any new info, I'll let you know
I can confirm this glitch.  W2K SP4.
It goes away when the window is repainted.
Exactly VLSI, thank you
Hi
I was able to reproduce this "cosmetic glitch" and I have reported it three times...
http://www.hydrogenaudio.org/forums/index....ndpost&p=189248
http://www.hydrogenaudio.org/forums/index....ndpost&p=195668
http://www.hydrogenaudio.org/forums/index....ndpost&p=200586
I am using Windows XP and I can reproduce the glitch... You must switch to "Windows Classic Theme" (same appearance as Win2k) to reproduce the glitch...
I think I have isolated the problem. It is related to the "Order" box in toolbars (Menu, Buttons, Order, Visualization, Seekbar)
Can you try to reproduce it?
- Disable the "Order" box in toolbars
- Enable "Buttons" box in toolbars
- Check "Lock the toolbars"
- Close foobar2000 (you must do it)
- Open foobar2000
- Choose an option in "Order" (from Playback menu)
I hope you can reproduce it this time
Byes
* Sorry for my poor english!!!
Yakusoku wa iranai.
