Topic: Converting foobar database to MySQL? (Read 3675 times) previous topic - next topic
Is it possible to convert the foobar database to a MySQL database?  Or another way to atleast get the Artist, Year, and Album Title into a database?  Thanks for any help, I'm at a loss right now.
If you were feeling labourious, you could write a proper Copy formatting string, put the output into a flatfile and import it.
I'll try that but I don't have that much time  How can I set the output to go into a flatfile?
I think SQLite is a better choice if anyone wants to embed a database into foobar2000.
Thanks but I should mention that I'm going to be using JSP to display the results and I'm not quite show on how to connect to sqlite with JSP
Where can I find further information about the structure of fb's database?
The idea is to setup up the copying string to output to a format that whatever you write to dump the data to the database can read.
