Topic: feature? questional behaviour... /Adding tracks. (Read 1713 times) previous topic - next topic
when i /ADD X miscelaneous tracks from different places on my harddrive to foobar (through the command line) they are sorted before added.
this is very unfortunate.
how can i remove this behaviour?
if i do the same with albums (playlists) i do not get this behaviour.
other players do not behave in this way. if i add X Y Z in that order, i want them to appear in that order.
thanks for any input regarding this.
Actually this behaviour is not questionable at all.
There is a "sort incoming files" feature in the core preferences.
You can customize this in any way you like.  In this case %_path% is probably what you are looking for.
Hope this helps.
it sure does help
thanks!
