Topic: Play Counter (Read 342387 times) previous topic - next topic
Play Counter
Reply #100
I think I found a minor bug.
Preset name including ']' character isn't saved properly after restart.
Anyway, thanks for the nice component which is really useful.
EDIT:Oops, this is the commet for the extended playlist generator plugin. Sorry, just ignore this.
Play Counter
Reply #101
I mean the current local variables in the callback class. Since the callback is a static class, you can safely move the _played and _length variables out, rename to g_played/g_length, implement the cfg variable storage directly from on_quit.
I gotcha... Mainly I don't do that because global data breaks encapsulation rules of OO... one of the purposes of a class.  My preference would be to have no cfg vars be global since they are "owned" by playcounter.  Though, breaking encapsulation for a relatively simple piece of code like this was acceptable it seems.
Forcing reload of play count / timestamp for all files referenced in the external database (if you change the formatted tag options, they will be regenerated)
Is there a metadb callback in order for you to know when meta data changes for a track?  If so, I would think it would be easy to reload the info fields from the external store automatically.
Forcing scan of external database for entries no longer referenced in the player metadb
- Hilighting entries in the current playlist based on a query to the external database ... could be simplified to facilitate a simpler internal count database, or allow full MySQL query.
Why all this work?  Is there some reason you don't want to store this info in the DB?  If I had a wish, it would be to have true "DB only" info, maybe with the option for it to be "sticky".... i.e., reloading from file doesn't blow away the sticky info.  But I don't have control over that.
Santa is very jolly because he knows where all the bad girls live.  - Dennis Miller
Play Counter
Reply #102
Now if only more people thought this way when writing audio player code, and perhaps emulators that could be modified to play only audio. There's a new N64 format, but it's a huge mess of single instance crap that I'll have to get bored and wrap into classes some day.
Well, you see, I do get a callback notice after the info is reloaded into the database, but I can't modify the metadata within the callback. I have to queue a db-only update for that information to occur after the callback, using a message window. This delay tactic prevents the new info from appearing in places such as the file info dialog. Once again, it's another hack for doing something the API was not designed for. (Yet.)
Can you feed SQL queries to the internal database? :B
Like I said, simple queries would be possible with normal info, but until it's possible to register permanent info variables to a particular service, it will be necessary to either write the values to the files' tags, or maintain them in an external storage system. A simple array would do nicely. You can even use the metadb_handles as indexes, for the duration of the process session. The handles would be translated to path/subsong when saving, then to playable_location to metadb_handle on load. (Of course, you'd be wise to do this translation in on_init, once all the components have been loaded and their services registered, etc.)
Whee, fun.
Play Counter
Reply #103
So, adding *.* to "DB Only Mask" will make it only track in the database, and it WON'T write tags to files?
I like this plugin but I don't like components to write tags to my music, I would prefer it in the database always unless I specificy otherwise.
I think this plugin should log this information should be logged by all file types to the DB by default. It's kinda nasty to have it write to the files themselves unless it is a standard tagging format that most other players would recognize (which this isn't, or am i wrong)
Play Counter
Reply #104
All that will do is defer the write to the file until you specifically tell it to update the file with DB info, or when you do some other tag update operation.  There is currently no way to never write the tags to the file and have the info in the DB.
Play Counter
Reply #105
Now I'm still using Playcount v1.2.
I disable DB and block tag update operations in the same time. So the tags are neither stored in files nor DB. But it really does the counting. I have no idea where the tags are but I like this way.
The later versions lost this "feature".
Play Counter
Reply #106
I disable DB and block tag update operations in the same time. So the tags are neither stored in files nor DB. But it really does the counting. I have no idea where the tags are...
Neither do I....
Play Counter
Reply #107
Maybe they're being stored in the playlists. Check the .fpl files in "C:\Program Files\foobar2000\playlists\"
f to c to f to c
Play Counter
Reply #108
You're right! Tags are being stored there.
So, tboehrer, is it possible to add an option to store tags ONLY in .fpl files?
Play Counter
Reply #109
No clue.  It's not something I control.  That I know of at least.
Play Counter
Reply #110
You can also check with kode54... he posted some messages saying he was working on a version that writes the tags to an external DB.  I don't know the status of it though.
Play Counter
Reply #111
I know nothing about foobar plugin programming. But actually v1.2 was already in this way...
Play Counter
Reply #112
The last version added an option to disable the "skip if not in DB" feature.  It's more likely that when you disabled the DB, the plugin simply ignores the track.  I truly don't have much control over what gets written where... I simply make a call to some SDK code and it does the rest.
Play Counter
Reply #113
Thanks for the reply tboehrer. I will wait for kode54's new version (if it becomes available). Very nice plugin ... once it can write to a DB and not to the files themselves I will be pleased  This is functionaliy from Winamp 5 which I miss in foobar2000
Play Counter
Reply #114
Minor release:
Version 1.5 (May 17 2004)
1) Added julian date format
2) Fixed bug with "Skip tracks not in the DB" not being checked first.
The Julian date is used by specifying either %j or %J in the format.  Use %j to use a julian date without the time fraction, or %J to get the full Julian date.
Play Counter
Reply #115
I searched in the forum, but don't found nothing, then here goes my question:
How can I change:
DDMMYY to YYYY.MM.DD (or YY.MM.DD)
and HHMMSS to HH:MM
I want to show this way in playlist: YYYY.MM.DD - HH:MM
Play Counter
Reply #116
this should do what you want - tell me if it doesn't work as I haven't tested it:
$ifgreater($substr(%play_date%,5,6),20,19$substr(%play_date%,5,6),20$substr(%play_date,5,6)).
$substr(%play_date%,3,4).$substr(%play_date%,1,2) -
$substr(%play_time%,1,2):$substr(%play_time%,3,4)
Steve
Play Counter
Reply #117
Or if you want a much simplier way, try to put
"%Y.%M.%D" in the play_date tag (in configuration of play_count)
and "$H:$M" in the play_time tags
and then %play_date% - %play_time% in your playlist
Play Counter
Reply #118
^ But that would require reformatting old tags wouldn't it
Steve
Play Counter
Reply #119
Paranoia Posted on Jun 20 2004, 11:35 AM
Steve
Yes.  The masstagger works well for reformatting.  I would reformat prior to changing the Play Counter format though.
Play Counter
Reply #120
Steve
true, I hadn't thought to that
My solution is better on the long run, yours is better on the short term
As tboehrer says, the best is probably to masstag and then change the play_date & time tags configuration
Play Counter
Reply #121
Thanks everybody.
I will change that format of the variables, then use the Paranoia's strings to format it in the playlist.
Andu use masstagger to change the old ones.
Paranoia, your string is buggy, it shows 20TA.06.20 20:12 per example, but that ok, i'll use %Y to get YYYY.
Play Counter
Reply #122
@tboehrer:
I had  a look at your website but didn't see the 1.5 version. Is that the foo_playcount.dll file?
Also, this looks like a great plug-in, could you have it added to the plug-ins page?
Thanks for the great work.
"There is no point in saving WAV... unless you have a huge HD in a very slow computer" - Jan S. (WAV or FLAC, Space No Problem)
Play Counter
Reply #123
By the way, could you implement an option to update counter when playback percentage is n% OR nminutes? It would be really great for some songs that have hidden tracks (ie looong part of silence in the middle, which one usually just skips).
Play Counter
Reply #124
Just get all the normal tags the way you like it, then write protect all of your files.
Thats what I am doing.
DB will be updated, but files will not.
