Topic: 74 minutes = 650 MB on a blank (Read 3643 times) previous topic - next topic
hi there,
I wonder how it is possible to store 74 minutes of audio tracks on a 650 MB blank - or 80 minutes on a 700 MB blank. I mean 1 Minute needs a bit more than 10 MB right? However, one minute of music is supposed to need more than 8.78 MB if it should fit on the blank...so am I missing something here? I mean the *.wav is that what's on the CD, right?
Audio CD uses simpler error correction than CD-ROM -> more room for audio-data.
That's because of the 3rd error correction layer that's used on data CDs and not used on audio CDs. On audio CD each sector is 2352 bytes long, on data CD it's 2048 bytes long. The reminer is error correction data.
-Eugene
The  greatest  programming  project of all took six days;  on the seventh  day  the  programmer  rested.  We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
Data discs use more than 300 bytes per sector to store data correction information.
If you create a VCD or Audio-CD those correction bits are used to store real data.
That's why you need programs like EAC to reliably rip audio from a disc. There's nothing to tell you that a reading error has happened.
On the other hand, a data disc can't be read with errors.
http://www.cdrfaq.org/faq07.html#S7-6
to oversimplify, it should be read 80min OR 700MB, that's why they usually put a "/" between the 2 numbers.
The Plan Within Plans
Actually a "74 min cdr", can store 650 Mo in MODE-1 (data, error correction), or 746 Mo in MODE-2 (no error correction).
Is this correct? I've been recording all my discs in mode 2/XA (in Nero) because some drives only recognise multisession discs when they're mode 2.
thanks to all of you! Now it makes perfect sense
This not correct:
IIRC a DATA (yellow book) CD comes in three possible formats:
Mode-1: 2048 Bytes/sector of usable data, 276 bytes of ECC
Mode-2 - Form 1: 2048 Bytes/sector of usable data, 276 bytes of ECC. Difference between that and Mode-1 is different sector format and headers/subheaders
Mode-2 - Form 2 has NO ECC and 2324 Bytes/sector of user data. Mostly used for VCD, IIRC...
Most CD readers of today recognize multi-sessions CDs even if made with Mode-1. If you make a Mode-2 data CD, anyway, it will be a Mode-2-Form-1 and it will have the same error correction as Mode-1 and you will able to fit the same amount of data on a given CD.
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
