Topic: XviD 1.0.0 RC4 available, Codenamed "Hola" (Read 7702 times) previous topic - next topic
  • AndyMutz
Changes since 1.0.0 RC3 (Ni Hao):
    * xvidcore
          o GMC 1 warp point (DivX5)
          o GMC 2 warp point fix
          o Minor postproc code fixes
          o Motion Vector clipping fix for stressing test cases.
          o Problems caused by wrong cooperation of bframes and frame dropping code.
          o Decoder provides quant information in stats.
    * VFW frontend
          o Multiple instance memory leak fix.
          o Improved bitrate calculator.
          o Some other minor changes.
    * DShow frontend
          o Release packages have all needed files to build from source.
source: http://www.xvid.org/
watch out for new compiles at the usual places:
http://xvid.gamrdev.com/
http://www.roeder.goe.net/~koepi/
-andy-
  • Last Edit: 04 April, 2004, 07:57:54 PM by AndyMutz
  • neoufo51
Thanks for the news!
  • AndyMutz
koepi'b build is now available..
-andy-
  • askoff
Koepi should use BitTorrent or something. I hate to download anything in his pages.
  • dev0
Elaborate. I never had a problem downloading anything from his pages and the speed has always been excellent too.
  • hyper84
And the file size for xvid is under 600KB...
  • MugFunky
weeeee!  better than an april fool joke
will try out as soon as humanly possible
(i run ZoneAlarm and never had trubs with Koepi's site...)
  • airon
All my XVid material is getting decoded by the DivX filter, acording to the Media Player Classic, despite me choosing XVid to decode everything.
I have Xvid 1.0 rc4 and DivX Bundle 5.11 (minus player) installed. Media Player Classic is at 6.4.8.2. I already uninstalled all Xvid versions and reinstalled, but to no avail.
Any ideas on how to fix this ? I'm getting green goo and lots of garbage coming up from the bottom of some material.
  • Last Edit: 06 April, 2004, 05:48:12 AM by airon
  • raf
  • Members (Donating)
Athlon optimized + thunderbird build (no sse) :
http://allies.freezope.org/#xvid
  • Last Edit: 06 April, 2004, 07:32:34 AM by raf
I promise you I will listen to what has been said here, even though I wasn't here.
  • JohnV
Well, one option is to go to the MPC settings, go to options->Filters->Overrides. Push "Add Filter". Select "XviD MPEG-4 Video Decoder",  then set it to "Prefer" status. Also, you can similarly even block the divx filter completely.
Juha Laaksonheimo
  • AgentMil
Use ffdshow if you are getting wrong output on XviD streams (i.e. DivX codec decoding XviD streams). It works on my system thanks to mobius!!
-=MusePack... Living Audio Compression=-
Honda - The Power of Dreams
  • airon
Yep. Thanks guys, I did that.
Shame I still get garbled video at the bottom of the screen.
They're all mod32 X*Y, 480x360 for example. So it can't be that.
Whenever stuff moves up from the bottom I get these artifacts. The picture is reset with each i-frame, but it's annoying nevertheless. I don't get this with new encodes. They're all encodes with an older build (2002 probably), but played fine with older builds.
  • Last Edit: 06 April, 2004, 01:01:30 PM by airon
360 is definitely not mod32, not even mod16. Anyway, this is a known issue with the older xvid encodings, try ffdshow or divx5 for for playback.
  • airon
Yeah, you're right. Must have left my calulus implant in a drawer.
I hope they fix this. It's not like DivX has this problem with its encodes.
Otherwise a fine release.
  • Gecko
I tried the Athlon XP (I have a 64) build and it acted up rather strangely.
I tried reencoding one of the WMA9 hdtv democlips ("The Punisher" trailer, 720p) and it just stopped while encoding the first pass, leaving the cpu at 100%. Encoding the same clip, speed was sometimes very erratic and awfully slow (still, CPU at 100%) bursting out a handfull of frames every 10 seconds or so.
Went back to koepi's build and all was fine.
  • JohnV
Thread split. Anti-leech etc. discussion moved here:
http://www.hydrogenaudio.org/forums/index....howtopic=20627&
Juha Laaksonheimo
