Topic: Tell us why have you chosen foobar2000 (Read 181547 times) previous topic - next topic
Reply #250
+ Has all the techy features you could ever wish for.
- Needs wine to run here...
For this last reason, I'm mostly running Quod Libet lately. Integrates well with the desktop environment, and at least the tagging and library features are about as extensive as those in fb2k. It lacks the dsp-features, but I'm trying not to worry about that anymore and just enjoy the music now
Reply #251
replaygain, diskwriter and notepad look.
did I mention replaygain? I couldn't live anymore without it.
that's pretty much it I guess.
Reply #252
I first tried it for the lower resource usage. I got hooked on for:
- high amount of costumization possible
- awesome playlist handling (the only thing I miss is the "update file sources")
- masstagger
- replaygain
- support for any kind of format there is
thinking about it, I'm not even sure what I could use in place of Foobar now.
Reply #253
+ CUE support
+ Extreme customization
+ Replaygain
+ Converter
+ ABX
- Doesn't properly support .aac files
- No easy way to check for component support
- Not scriptable natively
For the minuses, I still have to have MediaMonkey & WinAmp.
Reply #254
I would have to agree 100% with all of these features and more.
The only things I don't like about FB2K is the nature of the plug-ins and how they integrate (or don't integrate) and how the authors disappear w/ a trace between major versions.
I would much rather FB2K be open source (versus proprietary) and all plug-ins be the same, but I'm just one of those open source monkies with a lotta bias.
Overall, however, I could never go back to Winamp.
+ CUE support
+ Replaygain
+ Converter
+ ABX
Reply #255
@bytemastr: LOL... well WinAmp is not *that* bad actually... besides it's the only player on my PC that can properly play .aac files... so I have no choice there, do I?
Reply #256
Winamp is also one/the only (?) player that defaults to ripping to .aac, so it's quite natural that the Winamp developers would work around the issues that are the result of not using a proper container. The anser you will get around here when asking for "proper" AAC support is to use AAC the way it was meant to, that is inside a proper container (like .mp4).
Reply #257
You know... I never figured out how to rip with WinAmp  Always did it with AudioGrabber, before having a brief fling with CDex, and then converting completely to EAC
Still my elderly Nokia6230 can't play *any* properly contained .mp4 files, so I am stuck with .aac
Reply #258
I still don't know what is ReplayGain
And now I have another reason for using foobar2k:
- Converter, for burning audio CDs
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
Reply #260
I chose foobar because of it efficiency... Its small and I absolutely like, that I can make playlists very quick and switch between fast too.  Later I discovered columns_ui
Reply #262
+Sound Quality
+Extremely Customibility
+Miniamal Resource Usage
+Support for just about every format i can think of
Like others have said, "I dont think I could ever go back to using winamp"
Reply #263
I like it because it sits in my system tray/'notification area' and plays music. Why would I LOOK at a music player?
Oh, and because it looks like notepad. I found the concept of a notepad that played music great at first. It's a pity two other people have said this already
Reply #264
i like it because of its simplicity and multiple playlist handle. But i don't use it anymore because music sounds wayy better with izotope ozone plugin and i couldn't make it work on fb2k
Reply #265
Low resource usage.
Reply #266
ReplayGain. Compatible with so many formats. Low resource usage. Great tagging power.
Project Leader of DDResampled
Reply #267
I love Foobar because it still  is able to disprove my opinion i am not longer influenced by the players i used before even if i think so.
I wrote one page before:
The only weak point i can recognize is the fact that foobar isn't able to update database automatically by watching database folder ...
But why it should? If you rip a cd your tracks are corectly named and organized taken in media library, if you use renamer to add/remove or rename files to media library your database is updated. And that without scanning harddrive!
Reply #268
Before i got foobar, i just LISTENED to music, but then a friend showed me Foobar and i was excited. It´s not only a Player for music, it´s also a nice Freetime Activity  I mostly work on the player instead of listening with it  but now i´ve got 2 Foobars on my computer, one for the music and one to work on.
Reply #269
my only solution to manage and play and keep track of my thousands albums collection
Foobar : leap forward
Reply #270
+ Only gapless I could get to work flawlessly on my computer
+ Supports all my formats (flac, wav, mp3)
+ Supports a directory-tree interface (via foo_uie_explorer), the only way I will EVER use a music player.
- Steep learning curve
- Changing the look of the UI can be a lengthy process
- Does not do my laundry for me
Reply #271
I have moved from Winamp to foobar2k because of the GUI. The GUI appears to be faster than winamp. There is no memory consuming design, just a good old well structured standard window. So you can concentrate on functions and not on fucking design like winamp.
Reply #272
I tried many players (winamp, jetaudio, musicmatch, dbpower...) before discovering and adopting F2k 0.8.2.
+ low resources usage
+ reads the good formats (ogg, mpc, flac)
+ a lot of very good plugins
+ the best tagging capacity
+ higly customizable
- I still have a lot of troubles to handle (understand) the purpose of some plugins, script and configuration writting, but...
+++ the F2k community is so helpful !
Reply #273
I was actually working on a WA3/5 skin that emphasized the playlist (part of the 'working' was that the layout didn't exist in any at the time, so coding it was a bit odd)...and found Foobar2000,
+ Gapless playback, natively.
+ Replaygain (I like the report in 0.9).
+ Good tagging (even nicer in 0.9).
+ Good conversion tool (though the 0.9 one's UI is my one and only gripe for FB2K, ATM).
+ ABX...
+ Shuffle by album; not a killer feature that gets you right off, but it has certainly grown on me.
+ Independent volume setting, with intutive default keys of numpad+/-.
+ No skins required, and the buttons aren't too tiny.
+ Multiple flat playlists, tabbed.
+ Every version I've tried so far has worked under WINE w/o hassle. I haven't tried 0.9.3.1 yet beyond Windows, but I have already read simple success cases.
+ In general, it hasn't sucked more with newer versions, as is generally common in software.
+++ As with the above, it does not organize my music for me, or get in the way of my going through it. Non-flat database interfaces add plenty of hassle, and offer no benefit when wanting to listen to my music. Sure, they're handy, but not as a default method of handling the playlists. The work required to use players like iTunes, Amarok, and Banshee is just too great, and even then, they still get in the way. FB2K has multiple big flat playlists with good drag&drop support.
- Hard to read mostly functional scripting langauge for formatting.
+ Er, a scripting language for formatting that does orders of magnitude more than I have yet required of it (all I've really needed has been $replace(s,'&','and')), and much more than I ever will need.
Reply #274
I might as well jump on this bandwagon, new account here, and all.
I played with foobar back as far as 0.5, and, now, 0.9.3.1.  Between them, I opted to drop Windows, and go MacOS X native.  I loved UNIX, and, hey, it gave me UNIX and Photoshop.  However, now I need to be compatible with about 90% of the world - like it, or not.  The only thing that could play MOD files mostly-correctly (and wasn't DeliPlayer), is foo_dumb.  I take my MOD files too seriously.
What I like:
I like how much power foobar has, that you can make it do almost anything you want.
I like that foobar has a wonderfully documented (and BSD licensed) API.  That's tasty.
I like that it starts out simple, and it's primary focus is the audio, not some extra flashy junk that has nothing to do with what I'm listening to.
I like that it DOESN'T require me to install the .NET frameworks, or some bizarre not-found-anywhere-but-here OCX, or strange widgets.
What I don't:
I don't like that the API has changed so much that the jump from 0.8x to 0.9x has broken things so completely.  There are many 0.8x utilities that will never be recreated.
Lack of documentation.  Most dates back to 2003, and references long dead items: I was incredibly annoyed how long it took to find a 'recent' foo_modplug (since foo_mod is gone), only to find that it didn't work at all with 0.9x.
The whole Tagz system needs an overhaul.  It's powerful enough to be archaic - or is that archaic enough to be powerful.  It's nifty that you can register your own, but there should be a universal way for a plugin to notify foobar that it has these new display variables, and allow the user to decide what to do with them without padding or insane justification tricks, jeeez.
Closing Comments:
I'm old, lazy, and spoiled enough to want something to 'just work', or at least have some functionality that I don't have to wade through a hex editor to find what I want.  (Ok, this one was partially kode54's fault.)  Foobar isn't anywhere near there.  However, I love it now that it works - if an upgrade breaks it horribly, I'll probably dump it forever.. there are thousands of media players in the sea.
