List of recommended LAME settings
Reply #321 – 2004-01-06 10:09:57
Simba7, --preset extreme (as well as standard) drops bitrate down to 32kbps on silence automatically. No need to add -b 32 - you'll only get some < 128kbps frames on *audible* content which can lead to audible problems. There were problem samples that were solved by setting min. bitrate *on non-silent content* to 128kbps, that's why this is included in the --presets. So far almost no listening tests have been published about lame 3.94b1. If you use it there's a much higher probability that you run into audible artifacts than with the well-tested recommended version 3.90.3. If you read a bit throught this thread you'll notice that there's a consensus about what the 'recommended Lame settings' are - and people read it (especially the beginning), ask questions that remain open and get answers. This consensus is based on a huge ammount of time spent on scientific tests and will change if new facts based on evidence appear. If everyone who doesn't have enough knowledge yet to know what he's doing, posted his favourite settings based on assumptions here, this thread would turn into a complete mess and lose its purpose. So please ... - don't post things as facts that are based on potentially wrong assumptions - if you have still questions feel free to ask them - if you have performed double blind tests (ABX) and found that the settings you use are better, your input will be more than welcome, ideally in a separate thread
