Topic: Enqueue Plugin (Read 3116 times) previous topic - next topic
Enqueue Plugin
Hi!
I'm looking for a plugin where I can enqueue more files in my playlist, so that I can control the next files in the order I want (Like the Enqueue function in Winamp 2.x, but I HATE Winamp!!;-)) Is such a plugin existing, if yes where can I find it? Thanx!
Enqueue Plugin
The Winamp Enqueue is in Version 2.x (And 3.x I think) Click with the right mouse button at a track and select enqueue/Dequeue file.
Enqueue Plugin
Wow, I knew the 'q' key did that in XMMS, but didn't think it worked in Winamp since it doesn't give you any visual feedback (is there any way to see the songs you have enqueued in Winamp?).
Enqueue Plugin
If you mean, that you have such a good list like in foobar with the temple plugin (Which works really good, b.t.w. ;-)), no, that's not possible. In Winamp you simply see numbers in front of the tracks you have enqueued! But I prefer the foobar plugin!
Enqueue Plugin
You see numbers in front of the tracks you have enqueued?  I don't see anything here using both the classic and modern WA 5 skins.
EDIT: Aha, in WA 5 there is a foo_temple like list in the Preferences under the "Enqueue List" tab in the "Jump to File" section.
Enqueue Plugin
Oh, I see, u are using WA5?! I'm only sure, that it worked in 2.x (Maybe in 3.x too, but I'm not sure!). I just installed WA5 one time, because it already crashed when I started it! And it needed really long to start (With 1.8 GHz!!)
