mp3Gain vs mp3Trim
Reply #10 – 2004-03-12 12:38:12
@Mazter: It is not *wrong*, but is very likely that it isn't what you're looking for. Radio analysis will make all the tracks to sound at almost the same "volume", killing the dynamic relationships that exists between different tracks of a typical "album". That is a very quiet track will be strongly amplified while very loud one is likeley to be attenuated. This is good for radio broadcasting, where you want a consistent volume along the broadcast (mainly because you don't want people to constantly play with their radio volume knob maybe while driving) but is definitely not an "audiophile" behaviour. Album analysis, instead, compute a global amplification factor for all the tracks of an album to make the album globally sound at the same level than other albums. And this is what you probably want. The other thing is that you APPLY that computed gain. This operate at the mp3 frame levles, modifying a parameter, the "global gain" field I was talking about. This parameter allows to adjust the MP3 volume in 1.5 dB steps. On the other side, if you don't apply, just a tag is written to the files with the computed amplification coefficients written in it as a floating point dB value (much more precise). The other side of the coin is that while the frame level "applied" MP3 gain will have effect on ANY MP3 player, software or hardware that is, the "tagged" values will have effect only if the player is "replaygain aware". Personally I use Winamp with the Shibatch mpg123 input plug-in that is "replaygain aware". I'm not sure right now if the standard Winamp input plug-in is replaygain aware or not. Many other replaygain aware players exist, notably the much apreciated foobar2000. You would make some test with your favourite player... So, to summarize, 4 options exist with mp3gain: Album analysis, gain applied Track analysis, gain applied Album analysis, gain NOT applied <==== I use this one Track analysis, gain NOT applied "track" is the same as "radio", as far as I know... Best regards Sergio
