Topic: New, experimental matroska splitter (Read 2277 times) previous topic - next topic
  • ChristianHJW
Haali made a new, experimental matroska splitter :
http://haali.cs.msu.ru/fonts.html
This new splitter can load FONTS from matroska files, if they were attached to it. This will only work if you set the correct mime type for the FONTS when muxing them with mkvmerge/mmg, it is
application/x-truetype-font
This splitter will parse all attachements of a matroska file for this mime type, and then load them automatically for the embedded SSA subs of this file.
Its important to understand that the FONTS are only temporarily loaded for the playback, and not installed. As soon as the playback graph is closed, they are unloaded.
Have fun and report problems you find. If the build proves stable, it will become the next standard build ....
Support matroska - the bestest vapourware project ! http://www.matroska.org
