Poll
  • SV8 should provide just a limited set of switches. (Mainly the profiles)
    113 (64.6%)
  • SV8 should provide a full set of switches.
    62 (35.4%)
Total Members Voted: 193
Topic: What is your instance regarding Musepack SV8 switches? (Read 30518 times) previous topic - next topic
  • lucpes
Reply #50
And here's my new command line:
mppenc --quality 7.33  --maxbitrate 320 --minbitrate 128  --stereoquality  10  --bandwithquality 10 --temporalquality 10
So there's nothing new under the sun... I already know that I wouldn't be able to abx it against --quality 5 but it will sound better for transcoding... I just know it  --kidding
perhaps it would be better to stick just to --quality?
Reply #51
Indeed - great job! Looking forward to putting it to use! Puts that other thread in a new perspective, too.
/ Uosdwis
  • NickSD
Reply #52
I think this poll should be closed... Since we have the q-scale now, everyone seems to be happy.
  • Dibrom
  • Administrator
Reply #53
Agreed.  Poll closed.
  • andy2kxp
Reply #54
I say make 1 encoder for that has the quality scale and another encoder with the tweakable switches for people who enjoy tweaking or want to debug the current quality scale.
-Andy
  • Dibrom
  • Administrator
Reply #55
Umm..
Why would you possibly want to limit the upper bitrate with MPC?  One of MPC's greatest strengths is that it can go well over 320kbps for short periods if it needs to.  It does this quite regularly on some of my music as well.
There should be no need to limit the upper bitrate unless you are planning to stream the files.  Given your other switches, it really doesn't make sense either.
Probably.
  • ssamadhi97
  • Developer (Donating)
Reply #56
heh, even more - if i understand the new switches correctly, the --stereoquality, --bandwidthquality and --temporalquality are all tradeoff switches - thus you'd push the encoder into one single direction with the above commandline (for example: sacrificing audio quality for stereo imaging quality)
A riddle is a short sword attached to the next 2000 years.
Reply #57
Well, I still thinks that q scale is bad idea. There are two reasons:
1) The units of quality scale are unknown.
2) It's limited above by 10, and I still don't understood why. In old encoder version all settings were in db, and the limitation by, for example, 100 db could be explained that -100 db is almost unheareble by any ear. But how could I garantee, that 10 is enough, if I don't know the units?
To my mind all psyhoacoustic tunings should be given in some basic units, like ms, or db, and they should be fully explained.
  • Garf
Reply #58
The problem of this naming of switches is that it gives the impression of giving more/higher 'quality' (though it is explained in the comments that they are tradeoffs).
What about
--stereovsquality
--bandwidthvsnoise
--temporalvstmn
Less chance of someone blindly changing them without stopping to think of the consequences.
You are assuming that it is at all possible to give the tuning parameters in simple to understand or explain units. That's won't be the case.
GCP
  • Dibrom
  • Administrator
Reply #59
What about
--stereovsquality
--bandwidthvsnoise
--temporalvstmn
I like this idea myself.  Anything with the words "quality" on it will send people straight to tweaking whether they understand what they are doing and recognize the possible consequences or not.
  • smg
Reply #60
I won't respond to that comment
What if the Hokey Pokey....is What it's all about?
  • Dibrom
  • Administrator
Reply #61
You just did.
Reply #62
What about
--stereovsquality
--bandwidthvsnoise
--temporalvstmn
GCP
I support this, makes sense and explains at the same time.
  • Volcano
  • Members (Donating)
Reply #63
I second that. An encoder that has only the --quality scale (and maybe a few "utility" switches, like delete input file etc.) would be absolutely idiot-proof. You'd just have to promote it heavily to keep the clever-cloggs types away from the advanced encoder.
@ Frank: Do those --quality values have corresponding nominal bitrates, as in Vorbis?
CU
Dominic
  • GeSomeone
Reply #64
Maintaining two version would be contraproductive and cause confusion among the users. Almost everybody would want the "expert" version anyway
Ge Someone
edit: contra
  • Volcano
Reply #65
Why? They'd be built from the same source (the only difference being the front end, which I guess is stored in one separate file anyway), and my idea is that the advanced encoder gets updated as usual, whereas the "easy" encoder is only updated if a beta or final version comes out. That shouldn't be too big a problem, shouldn't it?
Ach, forget it, someone will come up with a much better idea anyway
  • R.A.F.
Reply #66
Please, no, oh, no. No switches at all. I speak from experience. Because once I feeled like being a good codec-tweaker ...and some here still do. - But now I´m clean.
Edit:
Ohhh.... I just noticed that the last thread before mine was nearly before WWII. I was just wondering, why this "SV8"-thing became so actual again, as i thought it would be already dead & buried.
  • Last Edit: 12 September, 2003, 03:31:22 PM by R.A.F.
My used codecs and settings:
FLAC V1.1.2 -4 / APE V3.99 Update 4 -high / MPC V1.15v --q 5 / LAME V3.97b2 -V2 --vbr-new / OGG aoTuV V4.51 Lancer -q5
  • rjamorim
Reply #67
I wonder how did you find this thread to start with
http://www.rarewares.org
  • R.A.F.
Reply #68
And imagine! I even didn´t vote for this poll out of WWII !! Okay, maybe it was simply because I was not yet born these days.  No, seriously: I wanted to start a poll (which isn´t possible here for normalos like me; but I didn´t know) and so I discovered this one.....
BTW: You still can vote for my poll, it´s under "Off topic". There it´s allowed. Concerning upstream-speed of your internet-line. - Really interesting topic, I think.
  • Last Edit: 12 September, 2003, 05:36:57 PM by R.A.F.
