Topic: foo_lirc plugin (Read 115626 times) previous topic - next topic
foo_lirc plugin
Reply #75
It doesnt seem to work with the latest Foobar beta 5    Are there plans for a new updated version?  I love this plugin !!
foo_lirc plugin
Reply #77
if someone have latest sources or can download them from homepage - plz share it anywhere....
foo_lirc plugin
Reply #78
Great plugin.. the latest version seemed to work well with Foobar 1.0.3, but after i installed some new plugins (probably the Foo_Bookmark one) FooLIRC will not execute commands that are newly added.
The LastFM 'love' command always worked fine, even with the latest Foobar and the latest version of FooLIRC. But i did some rework to my GUI and re-added the Love command but it doesnt work anymore. That also counts for other commands with different new plugins ive installed, such as FooBookmark
What a pity
foo_lirc plugin
Reply #79
Well, to be more specific: It doesnt work with some plugins after you re-add their specific command. So, its better not to touch your current configuration, untill someone comes up with a solution (which i doubt, the latest build of FooLIRC is dated somewhere in 2007)
Its available to download from his project-page
foo_lirc plugin
Reply #80
I have just upgraded to V1.1 and Foo_lirc no longer works for me. - I get
'Failed to load DLL: foo_lirc.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000/
Is there a solution to this?  Thanks Jeremy
foo_lirc plugin
Reply #81
See the link above... 0.5 works ok.. dont touch your config
foo_lirc plugin
Reply #82
Firstly wazoo thx for the update....
Sorry to keep hassling but I don't use custom info for rating( Which is in new context menus) I use a masstagger script.
In preferences - 'Keyboard shortcuts' I have setup under  TYPE [context/now playing] and ACTION  Scripts : 1 rating, Scripts : 2 Rating etc. etc.
Is there some way to implement this in the context menu of Foo_lirc as it is missing at the moment. There is a 'scripts' with no list of my user scripts
I want to use my remote to rate tag my files.
Hope you understand.
Thx for your help.
Mr E
Hi I found the solution.
1) Use SlyControl and make global hook of IR Control commands (for me its VOL+ and VOL-)
2) In windows.scs script file (SlyControl) add hook
    My2Remote = Hook( "REMOTE", "VOL-", Enabled, Break )
        break( My2Remote<>0 )
        Keyboard( "PRESS", "Ctrl+Alt+Shift+[" )
    My2Remote2 = Hook( "REMOTE", "VOL+", Enabled, Break )
        break( My2Remote2<>0 )
        Keyboard( "PRESS", "Ctrl+Alt+Shift+]" )
3) In foobar go to Keyboard shortcuts, select masstager script wich you want, press VOL- or VOL+, so foobar will receive pressed keys from SlyControl - "Ctrl+Alt+Shift+[" or "Ctrl+Alt+Shift+]".
Shure, using such global hotkeys is not good, better if foo_lirc "understand" masstagger or quicktagger scripts and showed them in assing menu.
foo_lirc plugin
Reply #83
Could someone please upload version 0.5.0 to some other site than eSnips? I really need the plugin but can't get the stupid downloader to work.
Re: foo_lirc plugin
Reply #86
Does this component work with Foobar2000 v2? All components now have a .fb2k-component file type rather than .dll. This is exactly what I was looking for - wow. As well as the current category "other", I suggest you add "remote control". I found this component purely by accident & had missed it in an earlier search. v0.5.0a is still available at the mediafire webpage.
Re: foo_lirc plugin
Reply #87
It does not and since it has been removed from the components page I am not very confident,
But there is an alternative: https://github.com/EventGhost/EventGhost/releases/tag/v0.4.1.r1722
The project seems to be discontinued for a while now but still works well. It has Lirc and foobar2000 plugins and can be used as a connector.
Another (simpler) solution would be global shortcuts in foobar2000 with the winlirc extension https://ramscan.com/irex which can translate the remote buttons to those shortcuts.
