Topic: Quick question :What codec is best at 64kbps? (Read 3248 times) previous topic - next topic
Topic.
Thanks in advance
gday...
HE - AAC.
if it don`t work for you.. i suggest
looking at ogg or mp3pro.
in the days mp3pro was new..
ogg did bypass mp3pro..
i haven`t tried out the latest pro v.
but last time i checked.. ogg had bells
beneath 96. so try mp3pro instead..
HE - AAC.. Mp3pro.. Ogg Vorbis.
ps. roberto`s 64 test.. shows the same..
At the moment, HE-AAC is considered the best quality option for 64 kbps. Vorbis is also a very good option.
However, i don't know many players for PDA that can actually play it.
You need to tell us which formats your PDA supports before any of us can give you a definative answer as to what format you should be using.  Most PDAs don't support MP3Pro, HE-AAC or Ogg Vorbis.
If you have to stick with MP3, Fraunhoffer. It's much better than Lame at low bitrates.
Glauber Ribeiro
Yoyodine Propulsion Systems - The future starts tomorrow!
I don't know about 64kbps, but this has definately been proven incorrect for 128kbps. Check these results.
For 64kbps, FhG is indeed theoretically better than Lame, because it implements IS coding.
Oops, I had forgotten about that.
Ogg can be played on pocketpc with PocketMVP for years.
Last I heard that faad support was planned to be implemented in PocketMVP, theoretically making it possible to listen to HE-AAC somewhere in the future.
