Topic: What DSP features to you guys use? (Read 24354 times) previous topic - next topic
Just wondering what Dsp features you guys have tested out and had the best effects..?
I use " ", and it works great for me.
i do use the following chain since quite a while.
Continuator -> Convert St. to 4ch -> foo_wider -> Advanced Limiter
foo_wider is used to make a subtle but working pseudo-surround-effect on my 4ch Speaker System. I narrow the stereofield on the front-speakers a bit, and widen it on the rear speakers - the result is a subtle pseudo-surround effect.
- Lyx
I've tested quite a lot. Closest to what I want comes with ...
crappy pc speakers connected to rear output:
Equalizer -> Move stereo to rear channels
headphones on front output:
foo_dsp_hrtf.dll
Resampler
Crossfeed
Volume control
Advanced Limiter
is that this "placebo" effect i keep reading about on HA?
i use only resampler, volume control and advanced limiter. i might use more if there was an easy way of getting to the dsp setup and not forgetting what i used
Well, I don't need resampler because my soundcard doesn't resample 44,1 Khz. I don't need Volume Control, since my amp is on my desk, right beside me. I don't want equalizer either. And if I did, my amp has bass and treble controls too. So...
what is soft clipping limiter and i have a few mp3 files that clip off at the end instead of the smooth ending, does that setting have anything to do with my problem?
Soft clipping limiter prevents clipping. It just limits everything above 6db AFAIK. Very usefull if you haven't replaygained your files. Better solution is to use advanced limiter. It "looks ahead" the song and works only if it is needed.
No.
The clipping this prevents is a sort of overdriven effect having to do with bad mastering on the original CD copy (which occurs in a lot of pop music etc because the sound engineers are pushing the CD format too far in terms of decibel range).
No.
Actually, no filter can fix this problem (can't recover losted information). The clipping refers to some files (like mp3s) where global gain would allow some samples when coverted to pcm (to play from sound card) to go over the maximum value it can have.
Using:
w/ headphones:
Resampler (48KHz) => Volume Control => Crossfeed => 4Front Headphones (18%) => Advanced Limiter
w/ speakers:
Resampler (48KHz) => Volume Control => Advanced Limiter
Volume Control
Crossfeed
On Audigy 2 with kX drivers:
Resampler @ 48KHz
Gap Killer
Skip Silence
Crossfade
Advenced Limiter
24 bit sampling --> Kernel Streaming
"The brightest flame burns quickest..."
Convolution module ( for room correction)
volumen control
upsampler ( 96 KHz)
kernel streamning out: 24 bit
Digital out to a Beheringer DCX 2496
Room correction look at DRC at freashmeat
Morten
Simple Sorround ! That's all !
Resampler @ 48KHz
Gap Killer
Skip Silence
Crossfade
Advenced Limiter
what do you have gap killer set at because some of the tracks are fading on to the next track?
also i won't have to have gap killer if fix mp3 header is installed??
but i read the guide but i still don't get how fix mp3 header works, i know you activate by right clicking but what do you set for padding?
(1) Gap Killer
(2) Skip Silence
(3) Crossfeed (when headphones)
Should i click Don't Reset DSP between files or does it matter
Would you guys recommend using Resampler with an SB Audigy 2 card?
Yeah, but with kX drivers. Using resampler under Creative drivers is useless.
I don't think this is correct.
Please explain.
I would like to hear explanation also.
I don't think that is correct either.  From my searching I've found these settings to be the best for Audigy2:
Output:
Kernel Streaming
Playback:
24bit fixed-point padded to 32bit
No dithering
DSP Manager:
Resampler (SSRC)
Volume Control
Advanced Limiter
From what I've read the internal resampling done by the Audigy2 cannot be disabled.  The kx drivers may disable this but I am uncertain.
Continuator!!!    ...and Advanced Limiter.
