Topic: CDex 1.50 beta4 (Read 4937 times) previous topic - next topic
CDex 1.50 beta4
http://cdexos.sourceforge.net/
CDex 1.50 (beta 4)
Changes since CDex 1.50 beta 3:
- Fixed problems with saving profiles
- Added support for Monkey's APE encoder DLL
- Warn if lame encoder is initialized with invalid bitrate/sample rate settings (could lead to a divide by zero)
- Fixed problem with WMA8 Track number tag that was not filled properly
- Added feature to select local CDDB file type (DOS/Unix text files)
- Fixed problems regarding Native NT SCSI library setting and ASPI warning message boxes
- Added feature to digitally play back a CD, so you can listen to the CD even though it is not connected to the sound card.
- Added MCDI tag to WMA8/MP3 ID3V2 files, so in the Windows Media player can query additional album information (Thanks Sam)
- Added support for the NTT VQF encoder DLL
- Patched vorbis DLLs, fixed managed bitrate problem
- Many improvements to the Analog Recording function.
- Fixed crash with WinCoded MP3 encoder
- Better support for MPC encoder (now on the fly encoding is supported)
- Added option in the External Encoder settings to send optionally a RIFF-WAV header when encoding from stdin
- Trim leading/trailing spaces when creating a directory.
Juha Laaksonheimo
CDex 1.50 beta4
Oh, the glee!!! Such a great feature!
(Yes, I admit, I asked for this about an year ago. And I'm really sorry.)
CDex 1.50 beta4
why not:
under setup
add 2 new buttons called 'user encoder1' and 'user encoder2' and rename 'encoder' into 'default encoder'  (or something) so one can configure 3 different encoders, even the same one with different settings and apply some keyboard shortcuts for those or maybe change the icons on the right (add few buttons).
CDex 1.50 beta4
Originally posted by smok3
why not:
under setup
Why not create two more profiles for this? Switching is easily done.
CDex 1.50 beta4
yeah, finally we can use vqf
CDex 1.50 beta4
lol, belive it or not, i couldnt find profiles for some time...., shame on me
CDex 1.50 beta4
As I've been told, this new release contains Lame encoder 3.93 Alpha 2.  Since that is nowhere defined as a stable version, does that mean the average user should stick with the 3.92 encoder?  In fact, with the difficulties with the 1.50 betas so far, maybe the "average user" should stick with CDEX 1.40 period.  just looking for opinions..
CDex 1.50 beta4
I believe most stability issues in CDex 1.50b1, b2 and b3 have been adressed in this version. So, it's not really imperative that newbies use 1.40
As for Lame, you should ask a Lame Dev.
In the past, CDex included alphas for a good reason: The latest stable was 3.70, which had much worse quality than 3.8x
Now, I think it's not really worth using unstable code. But just my opinion.
Regards;
Roberto.
CDex 1.50 beta4
You could use VQF before, but you needed Yamaha's SoundVQ encoder.
Now, you just need the dll. And it's free - SoundVQ is expensive.
Too bad both VQF sites - vqf.com and dalnetvqf.com - aren't working anymore to post these news.
Regards;
Roberto.
CDex 1.50 beta4
According to LAME history, previous LAME versions (from 3.80 to 3.89 - 18 months ! ) were BETA, not ALPHA. Just a name, or more « stability » (understand : mistake-free encoders) ?
CDex 1.50 beta4
Ok, if that's true, and I'm sure it is, then CDEX needs to get their act together with LAME.  Almost always, a new CDEX release, has a LAME encoder that says Alpha when you view it in settings.  Except for CDEX 1.40 which has the 3.92 non-beta and non-alpha LAME.  This can get terribly confusing.  :confused:
CDex 1.50 beta4
Well, see it this way:
CDex itself is in testing phase. (Beta)
So, why not test Lame alongside?
Besides, CDex creator (Albert Faber) is a Lame dev. I think he's acting together with Lame.
Regards;
Roberto.
