Topic: Otachan's in_!mpg123 (Read 187192 times) previous topic - next topic
  • witt
mp3infp ver.2.44 released. (bugfix)
  • Last Edit: 21 March, 2004, 04:19:47 PM by witt
foobar2000 Wiki for Japanese Users
http://foobar.s53.xrea.com/fbwiki/
  • NatGun
the gapless playback doesnt seem to work for me, is there an option i need to select to enable it?
  • amano
*sigh*
maybe search the forums?
or activate sufficient "buffer ahead on track change" in out_ds?
  • kjoonlee
And there's one more thing: do the files have the correct encoder delay and correct encoder padding info written in their LAME tags?
Only then will the files be decoded gaplessly. Files encoded with recent versions of LAME, for example, will do nicely.
  • NatGun
i encode with 3.90.3 and the gapless decoding works fine in foobar. i dont get it.
  • kjoonlee
Then are you sure you're using "buffer ahead on track change"? How long is your buffer?
  • Last Edit: 22 March, 2004, 10:50:31 AM by kjoonlee
  • amano
And are you sure, that in_mpg123 is in use???
You have to remove/rename in_mp3 or remove the MP3 extension from in_MP3!
If both in_mpg123 and in_mp3 are in the plugins folder, Winamp will always use in_mp3!
You can test it out when choosing "File Info" in the PL.
EDIT: BTW, thanks to kjoonlee for updating the mpg123 information post again.
  • Last Edit: 22 March, 2004, 11:25:26 AM by amano
  • amano
Reply #32
otachan ot66 is out!!!
a bug with IDv2.4 seems to have been fixed.
  • bidz
There seems to be a bug with either Winamp 5.03 or the latest in_mpg123.dll plugin. Every time i right-click and select "view file info" from within Winamp 5.03, i get a message "Winamp has encountered a problem and needs to close."
This happens with and without mp3infp 2.44 (latest) installed.
Anyone else experiencing this?
myspace.com/borgei - last.fm/user/borgei
  • kjoonlee
Reply #34
I'm having no trouble with ot66 and Winamp 5.03. WinXP+SP1.
edit: P4, 1.4GHz.
  • Last Edit: 27 March, 2004, 11:01:52 PM by kjoonlee
  • Hyperion
Reply #35
Ver oc66 STILL has a BUG.
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 46 61 69 6c   ion Fail
0010: 75 72 65 20 20 77 69 6e   ure  win
0018: 61 6d 70 2e 65 78 65 20   amp.exe
0020: 35 2e 30 2e 30 2e 33 20   5.0.0.3
0028: 69 6e 20 6e 74 64 6c 6c   in ntdll
0030: 2e 64 6c 6c 20 35 2e 31   .dll 5.1
0038: 2e 32 36 30 30 2e 31 32   .2600.12
0040: 31 37 20 61 74 20 6f 66   17 at of
0048: 66 73 65 74 20 30 30 30   fset 000
0050: 31 39 65 63 64 0d 0a      19ecd..
  • Last Edit: 27 March, 2004, 10:30:35 PM by Hyperion
It's My Life,
It's Now Or Never,
I Ain't Gonna Live Forever,
I Just Want To Live While I'm Alive.
  • rt87
Reply #36
you should try VC++ 7.1 version
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot66vc71.zip
Sorry for my English.
  • Hyperion
Reply #37
That's GREAT.
THX rt87
It's My Life,
It's Now Or Never,
  • jormartr
Reply #38
It seems doesn't work under win98 with winamp 5.02.
I made a fresh installation with EVERY plugin and option that come in winamp installer off, then deleted in_mp3.dll and replaced by in_mpg123.dll.
Worked perfect under winxp.
After that just copied the winamp directory to a win98 machine. It didn't recognize the plugin.
Made some test, I installed some plugins, all of them worked perfect under XP and 98, but under Win98 im_mpg123 was not recognized at all.
  • kjoonlee
Reply #39
Could you try with this version instead?
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot66a.zip
  • smz
Reply #40
@jormartr:
Are you aware that in_mpg123 is available in different "flavours", compiled to support different instructions sets (bare X86, SSE, SSE2)?
Couldn't be the case that on the Win98 machine you have a processor that doesn't support SSE and/or SSE2 and you're using the worong version of in_mpg123?
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperor | Sennheiser HD430)
  • jormartr
Reply #41
  Obviously that was the reason...
Reply #42
You can use something like WCPUID or CPU-Z to check which instructions sets your processor supports.
  • cyde
Reply #43
Whats the difference between "INT" And "Float" Bitrate options?
For example.. Should I be using 32bit int or 32bit float on my audigy?
  • rt87
Reply #44
in_mpg123 ot67 released
*Plugin doesn't work in win95 issue fixed
*Otachan changed compiler to VC++ 7.1
*Marged three downloads into one
http://www3.cypress.ne.jp/otachan/in_mpg123_118ot67.zip
  • rt87
Reply #45
32bit float = 24bit int
if you use KX Project or something similar, you can use both of them.
  • rt87
Reply #46
  • amano
Reply #47
  • Last Edit: 11 April, 2004, 08:51:23 PM by amano
  • cyde
Reply #48
What is KX Project?
  • amano
Reply #49
http://kxproject.lugosoft.com/index.php?skip=1
A third party driver for some creative soundcards.
  • Last Edit: 11 April, 2004, 10:04:49 PM by amano
