Topic: foobar2000 v0.8 beta (Read 80715 times) previous topic - next topic
Reply #125
i've read entire topic, but i'm still not sure if anyone has the same problem as me.
i've been using 0.7 ver of f2k and after changing it to 0.8 i got something like this:
CLICK
all my files are mp3, correctly tagged, without any polish fonts.
if anyone could help me, i'd be glad.
You just had to show off your big-ass wallpaper in this ficking screenshot, right?
Seriously, 1.1MB for a screenshot.. ffs
</rant>
I want my 20 seconds back.
A riddle is a short sword attached to the next 2000 years.
Reply #126
damjanek, what is that skin / theme you're using? i like it
now for your problem, what tags are you using? seems like problem with codepage for id3v2 tag plugin.
Reply #127
With 0.8 beta 3 I get an extra Volume control in the Active DSPs every time I restart.
and Crossfader [span style='font-size:8pt;line-height:100%'](and Gapkiller (Advanced)) [/span] now cause LONG lag in Volume change - approximately the same length as the crossfade time.
Reply #128
@mazy
theme's called c10k 2.0 ... i really dont know where i've found it..
i've just removed foo_id3v2.dll and everything's right now..
thx for help..
@ssamadhi97
i've forgot bout cutting the image, so its in 1280x1024 resolution..
Shroud of virtue hung to mask your stigma as I smile and laugh and dance and sing your glory while you lie, cheat, and steal.
Reply #129
temporary hotfix for beta3 only
Reply #130
I have this problem as well.
Edit: Ah, hotfix. Thanks.
Edit 2: Hm, when I ran the .exe it gave me some error about missing utf8api.
Reply #131
You have to copy this file to fb2k's installation folder.
Reply #132
Good show on the auto-reloading of changed metadata on playback.. i have an ipod which i use itunes for, and i also use traktor, which puts data into id3v2 tags, so this has saved a lot of headaches for me with foobar always resetting tags to its database
one thing, though.. there seems to be a bit of a regression of behavior when using the masstagger in conjunction with id3v1+v2 tags (i can't use just apev2 on account of traktor.. doing so would strip all files of analysis, bpm, cuepoints, etc.. plus, it's nice to have full tags on the ipod, too).  a few versions ago (i believe somewhere after 0.7.2), _something_ changed somewhere that made it so the UI no longer locked when using the masstagger or the multi-file infobox to update tags on files using id3v2.. could still select songs, UI-integrated viz kept going, etc etc, basically, foobar remained responsive during this update. This behavior also was the case with the muti-file infobox.. foobar was responsive during the update. if i used 'rewrite file tags from database', foobar would still turn into a brick until this operation had completed.
Now, however, in the v0.8 betas, this behavior has returned... both the multi-file infobox and the masstagger do cause the UI to lock on file updates. responsiveness seems to return between individual file edits, but changing an id3v2 tag with its current implementation in foobar is not a quick operation  i'm a bit anal with respect to how i like to have my files tagged, so this situation is a pretty common one for me.
anyway, i was very, very happy to see this behavior disappear in 0.7, and i'd love to see it reappear in 0.8.. cheers, thanks for the good work
edit: forgot to include info re. my setup.. i'm using winxp sp1, and i installed the special installer of fb2k 0.8b3 into a fresh directory (i.e. nothing but what's in that special installer package). also, did some investigations and replaced the foo_id3v2.dll included with the special installer with the version from my previous foobar installation with no change of results.
Reply #133
Haha, of course, that wasn't too smart.  Thanks.
Reply #134
@mazy
thx for help..
@ssamadhi97
you can get the theme at neowin.net
Reply #135
wish there was an option to enable/disable it tho
edit: never mind, finally found a solution
Reply #136
What was your solution? I think I've got the same problem. Foobar wants to rewrite the database info from tags, even though the database info is more current.
Reply #137
what"s new on beta 2 and beta 3?
ps : i have still a id3v2 problem, so still id3v1....
I maintain the ID3v2 component. Please upload an example file so that I may find the problem.
Reply #138
Here you go.
Thanks in advance :]
f to c to f to c
Reply #139
Test report (Beta 3 - Special)W98 - MP3 only - Plugins : Foo_web, Foo_Infobox, Foo_dbsearch 0.11, Foo_utils 0.3
Small Bug found :
When Drag/Dropping albums from the album list to a playlist tab, songs are copied twice in the playlist window. It only happens with "Various artists" albums
Improvement :
foo_infobox plugin : Multiple items (standard) now seems to work (did'nt work in Beta 2)
Confirmation:
Volume control appeared twice in the DSP setting (even after removing it and reloading). Now seems to work with the Hotfix
Regression :
The playlist tabbed view cannot be disabled since 0.8 (Checkbox has dissapeared from the default UI settings)
Menu :
Adding a new group at the root does not work (maybe by design)
Thanks for this nice works anyway. The new Album list and menus are great !
Reply #140
Here's an example file on which I'm currently having problems with as well:
Download Here
Link to my problem, incase you missed it
We're all just noise on the wires..
Reply #141
new "Volume Control" item appears every time foobar2000 0.8b3 starts. if there were 2 items, after restart there will be 3, etc. my system is win2k sp4.
Reply #142
http://www.hydrogenaudio.org/forums/index....ndpost&p=178991
A few posts up this matter was already fixed....
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe
Reply #143
I have the same problem with the ID3 tags. I'm using 0.7.7b though. Using suggestion from someone else in the forums, I added foo_mpg123.dll for mp3 decoding and am using a modified version of std input without mp3 support. This fixes the issues for English (ASCII) tagged mp3s however, foo_mpg123 doesn't support unicode it seems so i get ???? for all the unicode ones. With the default components, I get a mess
Tags shown by foobar
Updated tags by copying from the location/filename
Hit reload after saving tag changes
Re-edited with windows to fix
There's more jargon in the first link because i think "beginning" was also stored in unicode. The masstagger in foobar was used for this (however, I do not recall if the OS was set to English or Japanese)
I don't think its a problem with the id3v2 support though, since using foo_mpg123.dll and the modified std input, under the corresponding regional modes the tags come out correctly. Meaning, unicode tags of Japanese comes out fine when my Windows is set to Japanese (This does not work with the regular std input even when Windows is set to Japanese), and Chinese tags work in Chinese mode, etc.  However lack of unicode support in mpg123 i believe makes it not work in English mode. So I think the issue might be in the std input itself and not in the id3v2 implementation
-Michael
Reply #144
oops.. i should read more carefully
Reply #145
-Michael
Hold on... foo_mpg123? Where can I get this?
Reply #146
I played around with the id3 weirdness and found that only my joint stereo mp3s go kanji-ish, the full stereo files i tried seem to be ok so far... Maybe foo_id3v2 doesn't like joint stereo anymore?
Reply #147
You probably won't want it because it does not support unicode..would you rather have jargon for your tags or ????????????s instead?  I don't think its much help XD
Reply #148
Eh, I'm bored, Might as well mess around with it. Whoever can link me, please do.
Reply #149
I'd be interested in trying foo_mpg123 aswell
