Topic: Self-written MP3 & WAV ripping program (Read 4036 times) previous topic - next topic
Hi, all !
I've already written about this program in the mp3/mp3pro forum. But I've found out that for many people the link below didn't work.
If so, you can try http://people.freenet.de/l2001/
or http://m1.703.telia.com/~u70308943/L2001.zip
I wrote a small program for my personal use, but I thought that it was too good to keep for myself only, and decided to release it. And as it deals with mp3, I write about it in this forum.
Here goes its features:
WAV & Mpeg Audio ripping from any files, Providing information about wav, vqf and mpeg audio files, Various WAVe manipulations (changing bit resolution, joining wavs), Various file manipulations (Change size, Truncate, Remove bytes from beginning, Split, Join), etc.
Minimal configuration: 80386 DX CPU, 1 MB RAM, MS DOS 5.0
My computer: ip200mmx, 128 MB RAM, MS WINDOWS 95 OSR 2
Usage: l2001.exe /XX file1 file2 parameter -switch1
Examples: l2001.exe /wi range.wav -> Gives info about WAV, VQF & MP3 files
l2001.exe /wr diablo.dat -> Finds and extracts WAVs from any other files.
All WAVe types supported (PCM,ADPCM,a-law,IMA,
Creative, etc.) !
l2001.exe /mr cooldemo.exe -> Extracts MPEG AUDIO (MPEG1, MPEG2, MPEG 2.5
all layers) from any other files
(cooldemo.exe in this example).
VBR files & ID3V1 tags are supported !
This function may be also used to remove some
rubbish from your mp3 files: RIFF headers,
ID3V2 tags. etc..
l2001.exe /tr porn.mpg hc.mpg 2048000 -> Sets filesize of porn.mpg = 2 048 000
bytes (cuts off the rest) and saves the result
as hc.mpg.
l2001.exe /t 5.exe 9.exe 666 -> Removes LAST 666 bytes of 5.exe (result: 9.exe)
l2001.exe /j f1 f2 ... fx all -> Joins files f1, f2,.. fx. Result: file "all"
l2001.exe /c atb.mp3 summer.mp3 4170 -> Cuts FIRST 4170 bytes of file atb.mp3
The result will be saved as summer.mp3
l2001.exe /s 039.mpg fff 512 -> Splits file 039.mpg into separate 512 kb parts
Parts will be named fff.* (fff.0, fff.1, ...)
or 039.* (if U skip "fff" & run /b 039.mpg 512)
l2001.exe /u fff.1 039.mpg -> ReCreates file 039.mpg (joins its parts
starting with fff.1 & finishin on the last one)
l2001.exe /mf rand1 8388608 -r -> Generate 8388608 bytes long file with RANDOM
content and save it under name "rand1"
l2001.exe /mf ccc 1024 66 -> Generate 1024 bytes long file named "ccc" filled
with characters whose ASCII value corresponds
to the last parameter (e.g. 66 -> letter "C")
If you don't specify last param, default is the
symbol with ASCII value 01.
l2001.exe /uw p1.wav p2.wav track01.wav -> Unite 2 WAV files with identical
parameters (Format, SampleRate, Channels, Bps)
l2001.exe /cwr metallica.wav 12 -r -> Downsample from 16 to 12 bits (use ROUND
method - round to nearest 12 bit values)
l2001.exe /cwr acid.wav 7 -r8b -> Downsample to 7 bits (ROUND) & save in 8 bit
format
l2001.exe /cwr fatboy.wav -8b -> Save in 8 bit format (use TRUNCATE method -
ignore the least significant bits)
l2001.exe /cwr velvet.wav vv.wav 2 -8b -> Downsample to 2 bits (TRUNCATE) and
save as vv.wav in 8bit format
l2001.exe /wf download.wav -> Fix corrupt (incomplete) pcm wav file
The program is under lazy development.
Send your error reports, suggestions, greets, love letters, money, etc.
to [/a]
You can download this program at [url=http://deranger.newmail.ru]http://deranger.newmail.ru
If it doesn't work, try [a href="http://people.freenet.de/l2001/" target="_blank"][a href="http://people.freenet.de/l2001/" target="_blank"][a href="http://people.freenet.de/l2001/" target="_blank"]http://people.freenet.de/l2001/://http://deranger.newmail.ru[/email] ...t.de/l2001/[/url][/a]://http://deranger.newmail.ru[/email] ...t.de/l2001/[/a][/a]://http://deranger.newmail.ru[/email] ...t.de/l2001/[/a][/a]
