Topic: 5.1 Vorbis (Read 3403 times) previous topic - next topic
5.1 Vorbis
I got the 6 channel test from the Microsoft site (which has a wave and wma file) as well as the one from
http://www.digital-digest.com/dvd/download...s/trailers.html
where I used BeSweet to convert the vob to 5.1 wave.
I encoded the 5.1 waves using Vorbis using the command line
oggenc -q 3 -C 6 wave.wav
I played it in Winamp with in _vorbis 1.3.5 where it downmixed to 2 channels.  Left, right, centre, and LFE seemed ok but surround left appeared on the right channel and surround right appeared on the left channel.....
Am I doing something wrong?
5.1 Vorbis
you configured the winamp vorbis plugin to "leave as is"???
sorry about my english... aprendan castellano wevones! :P
5.1 Vorbis
No, I used the Downmix to stereo since I've only two speakers.
Anyone, just to update on the situation, I've tried again to encode the Microsoft 5.1 channel wave where the test ordering is:  FL FR C BL BR LFE  with
oggenc -q 2 --raw-chan=6
Then I played it in Winamp 5.01 (in_vorbis 1.35), configuring the plugin to 'leave as is' (and listening on two speakers).  FL played on BL (very soft on the left), FR played on BR (very soft on the right), C played FL (strong on the left), BL played on C, BR disappeared, HFE played on FR (strong on the right).
Now, I configured the plugin to downmix to 2 channels (ds) with the 'correct' channel ordering.
5.1 Vorbis
when i posted in this topic? !!!!
i cant remember...
5.1 Vorbis
i cant remember...
Nov. 23 apparently.
Any ideas on this problem?  Am I encoding it wrong or something?
5.1 Vorbis
Since you got the source file from Microsoft, the channels are probably in AIFF-standard order. Vorbis uses ITU's standard (which is also used by Dolby Digital). You probably need to re-shuffle the channels before encoding.
Don't you just love standards?
