Topic: MP3 at 128kbps public listening test (Read 39655 times) previous topic - next topic
  • rjamorim
Reply #175
I think its not a good idea tweaking the Lame settings for my test. It goes against the HA mantra of "NEVAH tweak the presets", so it would not be representative of what forum readers use.
http://www.rarewares.org
  • Gabriel
  • Developer
Reply #176
Well, it's not that much tweaking, after all in 3.95 --preset 128 is just --abr 128. But I agree that it is not very representative of real use.
  • rossthiof
Reply #177
Gabriel, could you please tell me the tweaked preset for a bitrate around 128 kbps ?
  • Last Edit: 13 January, 2004, 09:54:05 AM by rossthiof
FLAC --> MP3 (Lame 3.96.1: V5 --athaa-sensitivity 1)
  • Gabriel
  • Developer
Reply #178
--preset 128
  • guruboolez
  • Members (Donating)
Reply #179
It would be nice if some users will perform individual tests with --abr 128 and --abr 128 -q0, before the end of the test. Then Roberto may post something like an appendix, or a comment as conclusion about the (possible) benefits of the -q0 switch. What do you think?
  • Gabriel
  • Developer
Reply #180
I think that at 128kbps the benefits of q0 regarding quality are clear. But it does not represent how users will be using Lame.
  • rjamorim
Reply #181
I agree with Guruboolez' idea, an appendix would indeed be better, specially considering usage representativity.
  • rjamorim
Reply #182
Hello.
I'd like to ask if anyone here is experiencing problems to reach the listening tests site -
http://audio.ciara.us/test/
It's been weeks since I could last log into it. If it's only a DNS problem in my ISP there are no worries, it should get fixed sooner or later. But if more people are having issues, I'll need to move it again.
Verloren, can you help? I can't login through my FTP account either.
Also, I couldn't login using HA's SSH server + lynx.
  • evereux
Reply #183
rjamorim, No problem reaching the page here.
daefeatures.co.uk
  • Atlantis
Reply #184
All fine from here, Roberto.
Vital papers will demonstrate their vitality by spontaneously moving from where you left them to where you can't find them.
  • rjamorim
Reply #185
Weird...
What's worse, I can't use the FTP account to upload the presentation page. So I guess I'll have to move the site to rjamorim.com anyway
Reply #186
I'd like to point that with 3.95, targetting 128kbps I think that -q1 and -q0 can really improve encoding quality.
is it possible to use this setting along with aps? How much longer would that take? I mean it says in the ChangeLog that the new release is 10% faster, so what's the deal? I rather wait a bit longer and have a smaller file or a file with better quality...
Yes, of course it is. Just add -q ??? after --preset standard.
But the test should be based on standard setting.
Very short speed test:
C:\Music\LAMEsamples>c:\Lame3-90-3\lame.exe --preset standard fatboy.wav
LAME version 3.90.3 MMX  (http://www.mp3dev.org/)
CPU features: i387, MMX (ASM used), 3DNow!, SIMD
Using polyphase lowpass  filter, transition band: 18671 Hz - 19205 Hz
Encoding fatboy.wav to fatboy.wav.mp3
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=2
   Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
  191/193    (99%)|    0:02/    0:02|    0:02/    0:02|   2.1150x|    0:00
32 [  1] *
128 [  2] %%
160 [ 24] %%%%%%%%%%********
192 [ 14] %%%%%%%%***
224 [ 13] %%********
256 [ 47] %%********************************
320 [ 92] ******************************************************************
average: 265.3 kbps   LR: 30 (15.54%)   MS: 163 (84.46%)
Writing LAME Tag...done
C:\Music\LAMEsamples>c:\Lame\lame.exe --preset standard -q 0 fatboy.wav
LAME version 3.95 MMX  (http://www.mp3dev.org/)
CPU features: MMX (ASM used), 3DNow! (ASM used), SSE
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=0
  191/193    (99%)|    0:04/    0:04|    0:04/    0:04|   1.1611x|    0:00
32 [  1] *
96 [  2] %*
112 [  3] %%
128 [ 11] %%******
160 [ 11] %%%%****
192 [  6] %***
224 [ 16] %%%%*******
256 [ 40] %%%%%%%*******************
320 [103] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%************************************
average: 267.7 kbps   LR: 73 (37.82%)   MS: 120 (62.18%)
ReplayGain: -2.2dB
C:\Music\LAMEsamples>c:\Lame\lame.exe --preset standard -q 1 fatboy.wav
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=1
  191/193    (99%)|    0:02/    0:02|    0:02/    0:02|   2.0867x|    0:00
32 [  1] *
96 [  2] %*
112 [  3] %*
128 [ 13] %%%******
160 [  7] %%%**
192 [  8] ******
224 [ 15] %%%%******
256 [ 39] %%%%%%%******************
320 [105] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%***********************************
average: 268.5 kbps   LR: 73 (37.82%)   MS: 120 (62.18%)
ReplayGain: -2.2dB
C:\Music\LAMEsamples>c:\Lame\lame.exe --preset standard -q 2 fatboy.wav
  191/193    (99%)|    0:01/    0:01|    0:01/    0:01|   4.4350x|    0:00
32 [  1] *
96 [  2] %*
112 [  6] %%**
128 [  6] %%**
160 [ 11] %%%*****
192 [  4] %%*
224 [ 24] %%%%************
256 [ 36] %%%%%%******************
320 [103] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%***********************************
average: 268.1 kbps   LR: 73 (37.82%)   MS: 120 (62.18%)
ReplayGain: -2.2dB
C:\Music\LAMEsamples>c:\Lame\lame.exe --preset standard fatboy.wav
Encoding as 44.1 kHz VBR(q=2) j-stereo MPEG-1 Layer III (ca. 7.3x) qval=3
32 [  1] *
96 [  2] %*
112 [  6] %%**
128 [  6] %%**
160 [ 11] %%%*****
192 [  4] %%*
ReplayGain: -2.2dB
Both compiles are ICL 7.1 by john33, most probably same optimisations...
  • Last Edit: 13 January, 2004, 04:33:19 PM by AstralStorm
ruxvilti'a
  • Jojo
Reply #187
does this actually mean that the standard setting is an abr (JS) mode instead of cbr (Stereo) like it used to be?
  • Gabriel
  • Developer
Reply #188
The default encoding mode in Lame is still cbr/128/JS.
Btw if you want to know what is the default mode, you can try it.
  • S_O
Reply #189
-Xing 1.5 VBR quality normal
Is that the newest version? I just read that (by Karl Lillevold: http://www.hydrogenaudio.org/forums/index....ndpost&p=173122):
P.S. I have been told the Xing encoder is much improved since its first incarnation, which is usually not well spoken of
You can also download a free plug-in supporting all bitrates encoding for RealPlayer. I would really like to see (confirm ) how bad it performs against Lame & other encoders using short blocks. I would be rather suprised not to see Xing at the last position, but this test could show the truth.
  • rjamorim
Reply #190
As you can read some posts above this one, I had no luck installing RealOne. So, no, sorry, this isn't the latest Xing. There's nothing I can do about it
BTW, test is now OPEN.
http://www.hydrogenaudio.org/show.php/showtopic/17563
