Topic: Problems With Joint Stereo (LAME) (Read 12529 times) previous topic - next topic
  • Sonny
I’ve just registered to share my experience with you. I’ll TRY to be concise.
I’ve experienced some MASSIVE distorsion on high tunes, encoding some Metal songs that require high bitrate to sound good. After MANY try, I know what causes this distorsion : the Joint Stereo (JS) process (I use LAME 3.93 + RazorLame 1.1.5).
JS is supposed to be better than True Stereo (TS). Theorically. Indeed, JS encodes 2 channels, middle (M) and side (S) instead of left (L) and right ( R). Demonstration :
If M=(L+R)/2 and S=(L-R)/2 , then it is easy to get the L and R channel back :
M+S=(L+R+L-R)/2 = 2L/2=L and M-S=(L+R-(L-R))/2=(L+R-L+R)/2=2R/2=R
The trick is : you encode M on one side, and on the other, the more L and R are similar, the less the S channel will need bits to be properly encoded (ex: if L=R (=Mono), the needed space for S channel is zero !)
Conclusion : if you compare 2 files with the same size, the bits gained on similarities between L and R channel on the file encoded with JS enable an overall better encoding quality over the file encoded with TS.
Again, this is theory. Here what happen to me practically :
Sample encoded in 320kbps and TS (archive quality, 1.77Mo). Very close to the WAV sample.
Sample encoded with the --alt-preset standard, in JS (195kbps, 1.07Mo). You can hear the distorsion of high tunes even with a crappy sound board like mine !
Sample encoded with the --alt-preset standard -V 3, in JS (176kbps, 0.98Mo). In this file, I’ve lowered a bit the quality of the encoding (standard is ‘-V 2’). The overall quality should be good but the distorsion is now HUGE.
You can imagine what happens if I lower again the quality !!
Now let’s encode the sample in TS.
Sample encoded with the --alt-preset standard -V 4 –m s, in TS (188kbps, 1.04Mo). See? This file was encoded in lower quality (‘only’ -V4), yet, there is  no more distortion !!
Finally, here is a comparison of JS/TS encoding at lower bitrate :
Sample encoded @128kbps with JS (727ko).
Sample encoded @128kbps with TS (727ko).
There is no need to be a sound engineer to get the difference.
To end this test, here is a few remarks:
I’ve tried to encode in JS with the previous version of LAME (3.92), but I got the same result.
I’m not an expert, so tell me where I’m wrong or what could get this thing work good.
I’ve always been a convinced Lame user. I’m not THAT convinced now. But I’m not sure what to do. Continue in TS with Lame or change for something new. Any advice?
Finally, excuse my english, I’m just french!
  • Last Edit: 07 December, 2003, 03:29:58 PM by Sonny
  • Hanky
  • Members (Donating)
Please post the original losslessly compressed (flac) sample. All users here can do the encoding to mp3 themselves with various settings to do their listening tests.
[edit:  Be prepared that forum members are only willing to discuss problems with recommended LAME versions and recommended settings]
  • Last Edit: 07 December, 2003, 04:20:53 PM by Hanky
  • frozenspeed
just curious, but wasn't this discussed, like, a year ago and there was an update to lame 3.93.1 or something? Or am I way off? =)
Jeff
  • saratoga
Wow thats my kind of music.  Unfortunately without the orginal file i can't do anything with it.  Hopefully you can up a FLAC/APE somewhere?
Off Topic:  -sorry-
you're "just" french ?
be proud to be french
Kameloth?
Yes... fine music
  • zver
I remember lame3.93 had some big problems..Try recomended3.90.3 or 3.93.1 atleast
  • ExUser
  • Read-only
3.90.3 is the recommended version.
3.94betas may be better with some samples; there's been some major tweaking and tuning with that one, but these tweaks and tunes haven't been tested enough to be recommended yet.
If both are broken, report the 3.94beta breakage, along with a lossless copy of the file. (There's the Uploads forum specifically for problems like this.)
We're interested in hearing more about this. Thanks.
Edit: Also, try using --alt-preset extreme or --alt-preset insane. The latter is highly-tuned 320kbps encoding, while the former is highly-tuned ~240kbps(?) encoding. Try both with v3.90.3 and see how it works for you. Dibrom, the tuner, listens to metal as well, and the genre was one of many used in tuning 3.90.3.
  • Last Edit: 07 December, 2003, 06:39:31 PM by Canar
  • tigre
Huh? Who's talked about 3.94betas - have I missed it?
Anyway - Sonny: It has been said before ... for others being able to verify your findings it's necessary to upload a losslessly compressed (flac, monkey's, wavpack ...) sample. You can use upload forum for this and put a link to the upload thread here.
Have you mp3gained your files or used replaygain on playback to avoid clipping? If not, this could be a reason for the problems you hear too (Only a possibility - I haven't listened to your samples as without knowing the original this would be quite useless, so I can't tell for sure).
  • Sonny
I made a small mistake : after checking again, I didn't use lame 3.93 but lame 3.93.1 for this test. I've also tried the 3.92 version (same problems), but not the 3.90.
And all setting are from the recommanded Lame setting list (alt preset standard and alt preset cbr). I just changed the '-V' parameter on sample 2 and 3.
I've managed to save some spaces on my ftp so here is the LINK REMOVED
I also forgot something : I've downloaded a CBR 128kbps mp3 of this song that I've found on the net. It was encoded with FhG and Joint Stereo.  Well, I was surprised to hear that it has the same noisy distortion. Compares to my two others 128kbps samples, it sounds better than the JS one (less distortion) but worse than the True Stereo.
So I may conclude that for this kind of music -hungry for bits, with high tunes- the True Stereo compression sounds better than the Joint Stereo.
That's completly against what I've always read about...
Oh and btw, yes, Kamelot is good music !
Edit:
Sonny, the forum rules say
Fair use of short music clips (under 30 seconds) for codec testing purposes are allowed.
Please respect them (and read them before posting if you haven't done yet). For verifying your findings a sample of 20-30 seconds should be more than enough if it's as obvious as you say. Thank-you.
edit2: I'll attatch a cut sample (30 seconds) to this post, if it doesn't contain the positions you're talking about, upload your own.
  • Last Edit: 08 December, 2003, 04:56:32 AM by tigre
  • Sonny
I'll try with the 3.90.3 version and let you know. For now I stick with the True Stereo compression.
And yes, I've also tried the alt preset extreme (but not the 'insane'). I could still hear this crappy distortion though the sample sounded a bit better than with the standard preset. Logical, given it's encoded at higher bitrates (204kbps).
When you boost up the encoding quality with the '-V' parameter, the distortion is less and less audible but, hey, what's the point of encoding with VBR at nearly 240kbps ('extreme -V0') when you reach the same result at 200kbps or less with the TS (still talking of that specific distortion) ?!?!
  • kjempen
Sonny:
If you want people to take you more seriously in this forum, you should:
a. provide a losslessly compressed sample (FLAC or something like that)
b. provide some ABX results. Just saying this or that sounds better doesn't really prove anything without doing the proper testing
c. steer clear of doing too much command line tweaking unless you really know what you are doing, and are very familiar with the inner workings of LAME. (Usually you end up with worse results after "tweaking".)
  • JohnV
I haven't had time to test this, but it's pure madness to decide something based on one sample, especially when lots of testing has shown that mid/side coding is very clearly useful in alt-presets.
And this is lossy audio - of course there are exceptions. But the author should at least provide some blind listening test results first.
  • Last Edit: 08 December, 2003, 12:22:30 AM by JohnV
Juha Laaksonheimo
  • Hanky
I downloaded the original sample. Encoded with --aps (LAME 3.90.3)
A listening test between wav and the encoded file did not show any problems here.
[edit:]
westgroveg is right: retested with 3.93.1 , No (at least no obvious) problems either
  • Last Edit: 08 December, 2003, 05:28:24 AM by Hanky
  • tigre
Sonny, I tested with the (too long, see edit above) .ape sample you provided: lame 3.90.3 --aps, --aps -m s and couldn't hear anything obviously wrong. So please ...
- tell where exactly the problem is most obvious and what exactly it sounds like. Then upload an .ape sample < 30 seconds containing this position.
- perform an ABX test to prove that it's not just immagination using e.g. foobar2000's ABX comparator (other ABX tools: see the FAQ
Besides: There's indeed clipping on decoding if no replaygain/mp3gain is applied. It doesn't cause to me obvious problems but might be a reason for what you hear. So please use mp3gain or replaygain for testing (fb2k's ABX comparator forces you to use replaygain anyway ...).
Please try to understand. It has happened quite often that people come here, claim that there's something terribly wrong with some codec, but when they're asked to support their statement by providing double blind test results (ABX) and a sample they suddenly disappeared. Things like this cause the forums being polluted with wrong and/or unimportant information making valuable information hard to find. Also, audible problems reported by codec users can only be useful for developers (many of them read the forums here) if there's evidence. Some of the forum rules are there because of this.
As far as I understand your theory about "true" and joint stereo correctly, there's a basic mistake: The joint stereo used by the -alt-presets switch between "true" stereo (=Left/Right) and Middle/Side automatically, depending on the redundancy between channels. In many cases this saves bits that can be used to avoid audible problems. (Details see FAQ.)
  • Sonny
Sonny:
a. READ THE PREVIOUS POSTS BEFORE REPLYING
b. I trust my ears
c. I didn't know that the 'alt preset standard', 'alt preset cbr' and 'alt preset extreme' was "tweaked" command line.
  • westgroveg
why? in most cases joint stereo is better than stereo.
uh wot the hell ? can you read the previous post BEFORE replying ?
People try 3.93.1. Isn't hydrogenaudio interested in testing new problem samples anymore?
b. I trust my ears
hem...
You'd better to use ABX to get OBJECTIVE results...
I've made this mistake too to trust my ears and the conclusions show it's vey easy to suffer for the placebo effect.
Mea culpa.
Regards to all HA members thanks to which I understood.
  • Last Edit: 08 December, 2003, 05:29:22 AM by Nick Jr III
  • Moneo
b. I trust my ears
This argument can not, and will not, be accepted.
Time and again, sighted evaluation of audio quality has been proved to be unreliable. This is the reason why in this community statements regrding sound quality have to be supported by blind test results.
Please follow the suggestions given above: use replaygain and do an ABX test if you want your claims to be considered as valid.
  • tigre
How do you come to this conclusion? If you browse "I found a problem ..." threads you'll find 3 types:
1. ppl knowing and respecting the rules = providing ABX results + uploading samples
=> responses showing interest
~ 60 % of cases
2.1. ppl who don't know, understand and/or care about the rules, claim something and disappear when asked to back it up + to respect the rules saying something negative about this place
~ 35 %
2.2. ppl who don't know, understand and/or care about the rules, claim something and provide samples and do ABX tests when asked to back it up + to respect the rules, resulting in them learning something and becoming valuable members of this community.
~ 5 %
From the 1st few posts of someone "2-ish" it's impossible to tell if (s)he's 2.1 or 2.2. type of person. This is an explanation for what you seem to regard as "low interest in problem samples" (not an excuse).
  • Sonny
1. I didn't do ONE blind test, I've spent DAYS blind testing and made something like 10 tests, with up to 14 FILES and I always hear the distortion. Sometimes (for the 128kbps samples) I can hear it in less than 3 seconds. I begin lose the trace of that distortion when I change the command line, increasing encoding quality. In fact, using the '-V0', I wasn't able to hear anything distroted in high tunes (encoding in at nearly is at nearly 240 though)
2. tell you where is the distortion ? Did you actually listen to the 128kbps samples I've provided ? Surely not!! you wouldn't even ask.
3. My imagination is great thank you    but, again I trust my ears. If I've passed 10 blind tests, it means I really HEAR there's something wrong!! When I write 'I'm not an axpert' it didn't mean : 'I'm deaf' !!
Anyway, to be sure that I was not a fool with vivid imagination, I did one more.
There was 'only' 6 files : the original wav, a 320kbps TS and four 128kbps samples. Three of them were encoded with 'alt preset cbr 128' command line. Two of them were encoded with Lame 3.93.1 one with JS the other with TS (adding '-m s' to the commadn line). The third, and that's new to me, with Lame 3.90.3. The fourth sample is a file downloaded from the internet, encoded with FhG in Joint Stereo.
I ran this test THREE TIMES. Results:
128kbps JS LAME 3.93.1 : found distorted on high tunes 3/3
128kbps TS LAME 3.93.1 : found clean on high tunes 3/3
128kbps JS LAME 3.90.3 : found distorted on high tunes 3/3
WAV original sample : found clean on high tunes 3/3
320kbps TS LAME 3.93.1 : found clean on high tunes 3/3
128kbps FhG JS : results are inconcluding
So... maybe the problem is coming from my computer, not from Lame, since some didn't noticed anything wrong using the 3.90.3 version... but I'm still not convinced : in fact, why do I hear distortion with Lame JS while there's nothing wrong in TS...
I just love the friendly supportive environment that is being nurtured here.  Welcome to the Jungle, Sonny!
  • Gabriel
Well, you are not using the winamp equalizer or any dsp plugin, are you?
If you want some feedback, please provide a short sample. 40s is way too long.
  • Sonny
I use Ultra Player, without equalizer. I also made tests with winamp 2.8 and 3.0, with and without equalizer....... same results.
  • Sonny
yeah i've seen...
