Topic: Quantization (Read 3643 times) previous topic - next topic
  • Max A.K.
Quantization
How to calculate the number of bits required to ensure that the quantization error for the tone is within the minimum masking threshold if i know power of the tone and masking threshold?
  • NumLOCK
  • Developer
Quantization
Seems simple.
I would use: ceil(log2(tone_power/masking_threshold))
Try Leeloo Chat at http://leeloo.webhop.net
  • Max A.K.
Quantization
Seems simple.
masking_threshold should be the minimum masking threshold in that segment?
  • NumLOCK
  • Developer
Quantization
Seems simple.
Yes.  This might depend on the codec, but in general if you don't take the minimum value, the quantization noise might get perceptible.
  • Max A.K.
Quantization
Seems simple.
Maybe you can give me some references where I can read more about it?
  • NumLOCK
  • Developer
Quantization
My apologies, I can't..  because I won't be home until some time
Edit: Since your question was pretty essential, you can probably get away with any good book on psychoacoustics (but I don't know which ones by heart).
  • Last Edit: 26 November, 2003, 04:38:36 AM by NumLOCK
  • Ivan Dimkovic
  • Developer
Quantization
The measure we are talking about here is called "perceptual entropy",  and the basic paper where it was described is:
J. D. Johnston, "Estimation of perceptual entropy using noise-masking criteria," in Proc. ICASSP, 1988, pp. 2524--2527.
Basically, for plurality of frequency lines, amount of the bits required to code the bitstream can't be lower than:
PE = SUM (0<i<-numlines) log2(Energy / MaskThr)
(where MaskThr is the masking threshold calculated by the psymodel)
PE is a theoretical minimum - and it can't be achieved in true codec (you need some side bits to represent the coding information, etc...)
So, for a real coding system, bits required to code a plurality of signals is most likely to be around:
BITS = p * PE + q
where  p and q are codec dependent parameters..  For example, for MPEG-4 AAC:
BITS = 0.6 * PE + 24 * sqrt (PE)
This is not exact measure, of course - since huffman codebooks are not perfect, and signal statistic might vary from frame to frame, etc..
  • Last Edit: 26 November, 2003, 06:00:31 AM by Ivan Dimkovic
  • Max A.K.
Quantization
BITS = p * PE + q
So if i have one tone (TF) and i know minimum masking threshold (MinT) i need
log2(TF / MinT)  bits to quantize this tone?
  • Ivan Dimkovic
  • Developer
Quantization
Yep.. actually, this should be the "theoretical minimum" - like with normal entropy.
You also have to add side data necessary to represent the compressed spectrum, like huffman table indexes or tables themselves - also, each huffman codebook has its own performance on different signal statistics, etc..
So, for a particular coding system (like MP3) the formula is little bit more complicated.
