Topic: plusV for OGG ??? (Read 8118 times) previous topic - next topic
plusV for OGG ???
"PlusV offers a method for compressing a part of the audio spectrum where MP3's own compression doesn't work particularly well. Combined with the excellent features of MP3, the new combined format called MP3+V can achieve incredibly small files while maintaining full compatibility with existing MP3 files. "
Even if i don't understand how it is licensed (they realese the sources...) i think it should be useful for OGG low bitrates too.
Any comment ?
plusV for OGG ???
Any comment ?
A) It's patented, which immediately makes it utterly useless for Ogg.
B) Ogg doesn't suffer from the same kind of restrictions MP3 has, so the hacks to drag on MP3 a bit longer (MP3Pro, PlusV) aren't transferrable to it.
GCP
plusV for OGG ???
Vorbis has a free license (BSD), not a restricted one like the GPL.
plusV for OGG ???
if you are curious... try it
http://www.geocities.com/gameplaya_15143/downloads
i fixed the *broken* plusv.exe so the -h (help) option actually works... and changed a few things so it is actually useful as a proof-of-concept encoder (or maybe disproof-of-concept  )
plusv -e input.wav 22khz.wav 44khz.pv
then encode 22khz.wav to your codec of choice (ie. vorbis). decode back to wav
plusv -d 22khzdecoded.wav 44khzdecoded.wav 44khz.pv
then listen to 44khzdecoded.wav and you can see how it sounds
ps. if you like crazy things... use 22khz.wav as input when encoding with plusv.exe
i removed the 32khz-or-higher-sample-rate limitation
enjoy  happy testing
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
plusV for OGG ???
Even if i don't understand how it is licensed (they realese the sources...) i think it should be useful for Ogg Vorbis low bitrates too.
Vorbis has noise normalization.  Garf pointed out too that PlusV is patented so it's of no use. I just don't understand what people don't get about this? ;-D.  More time and energy would be better spent in developing a hybrid filterbank. This is just my take on the situation of course backwards compatibility becomes an issue. ;-D.
budding I.T professional
