Topic: foo_shuffle (Read 121700 times) previous topic - next topic
foo_shuffle
finally a shuffle plugin! thanks kode
minor request: is it possible to also add a shuffle-menu-entry for the systray?
- Lyx
foo_shuffle
kode54: Awesome, exactly what myself and others were looking for.  Is it possible to maintain the functionality of Follow Cursor while using shuffle?
foo_shuffle
Thanks Kode54.
Indeed another great plugin from you.
Do you think it's possible to add a "minimum" jump range to the shuffle ? to be able to avoid playing next song in the album (fustrating when the playlist is big).
SU
foo_shuffle
Done.
foo_shuffle
foo_shuffle
Delicious!
foo_shuffle
great plug in !!
foo_shuffle
Nice; is it possible for you to add a "random album" mode (play all the songs of an album in order and then random to another album etc.) ?
please!!!
foo_shuffle
Random Album is exactly what I'm looking for. Also, I'm looking for it to shuffle between playlists as well, I like to sort my genres between different playlists.
foo_shuffle
Controlling which playlist the core plays from is beyond the power of a playback flow control service such as Shuffle.
Shuffle album is not. I'll see what I can do.
foo_shuffle
Uploaded v1.0.3.
  • Added album mode. Jump settings do not apply within album track selection.
It may need some tuning, or perhaps a proper way of staying a sufficient distance away from the previous track in the album, without screwing up the range. For now, it just uses the MT random function to pick from the unplayed tracks of the current album. When it finishes with the current album, it uses the original method to pick a new random track.
foo_shuffle
Quality plugin! Nice work kode54! Thanks for making it.
Any chance of being able to choose which field it uses for Album Shuffle? This would make it even more powerful (shuffle within categories, genres, artists etc.)
Ooh and a Next Album shortcut key would be wonderful too
foo_shuffle
...being able to choose which field it uses for Album Shuffle? ... shuffle within categories, genres, artists etc.
this is a GREAT idea  simple feature, endless possibilites
- Lyx
foo_shuffle
Uploaded v1.0.4.
  • Added tag set rule mode.
A set of unplayed tracks will be compiled based on the tag rule set.
Example:
Rules: -album|+genre
Previous track:
album=blah
genre is unset
Only the album rule will be observed, in which case the choice list will contain all unplayed tracks with unset album, blank album, or non-matching album.
If no matches are found, it will fall back on the standard shuffle track jump behavior.
For now, it only supports the first defined tag for each rule. More than one is possible, but will be complicated. (new conditions, ie. at least one match, or all must match; each value present in the checked tracks will have to be verified against all of the values collected from the previous track)
foo_shuffle
Uploaded v1.0.4.
Example:
Previous track:
album=blah
genre is unset
great! even better than I'd hoped (in theory). But..
If I understand your descriptions correctly, if I put +album as the rule and choose Shuffle tag set for the order, it should behave the same as Shuffle album? I tried this and it just seems to do normal random shuffle (not within album)... In fact I can't seem to get any + rule working..
foo_shuffle
kode54, could you add another kind of "random album" ?
it takes any album , starts at track 1, play all of them in order until the album is finished, then starts another album ?
Thanks already for your great foo_shuffle
foo_shuffle
Uploaded v1.0.5.
  • Fixed tag set + condition. (stupid typo)
foo_shuffle
Uploaded v1.0.6.
  • Added second album shuffle mode that does exactly what you want.
foo_shuffle
Uploaded v1.0.6.
where at??
foo_shuffle
"Shuffle album 2" in the order control list.
Note that if the history is smaller than the number of tracks in the current album, it will cycle through the album endlessly. If this is a problem, add more tracks to your playlist, or increase the history size. :B
foo_shuffle
no.  1.0.6 has not been uploaded anywhere
your site still has 1.0.5
foo_shuffle
Oops. Issue corrected.
foo_shuffle
i don't suppose there is any way to play the randomly selected album in order (starting from track 1), then move on to another album?
i figure some sort of internal queue could be used to queue up the entire cd in order or something.
just a thought.
foo_shuffle
just a thought.
Uhm, that's what "Shuffle album 2" is supposed to be doing, unless your files lack proper TRACKNUMBER values.
Maybe if everyone could vote on a better name than "Shuffle album 2..."
foo_shuffle
Component name - foo_shuffle
Component type (appropriate section) - General
Which foobar2000 version the component works with - 0.7.1
Short description of the component - Shuffle control with play history.
Compile date - October 17, 2003
Download link - http://www.saunalahti.fi/cse/kode54/foo_shuffle.zip
Author website link - http://www.saunalahti.fi/cse/kode54/
This pluggin is amazing !!!  Great work kode54
