Topic: How to extract chain ogg file (Read 6163 times) previous topic - next topic
  • siorin
I want to extract chain ogg file.
Please tell me how can I extract chain ogg file to each song.
I've tried oggcut.ext,But I need cut by manually and it isn't work good.
  • Biont
Hey, that's a good question! I'm believe there is no tool for directly cutting ogg into small oggs. I mean, there is no tool, that would search for specified silence gaps and automatically cut in that place. But does anyone know of such tool for wavs? There must be. Standalone or like DX plugin, so you could just input the whole album and it would cut it to songs.
  • john33
  • Developer
The oggdec and oggdropXPd at Rarewares will both decode a chained ogg file to separate wave files, but they don't split the chain into separate ogg files.
John
  • siorin
It is necessary to decode to wav in order to extract ogg chainfile into each track.
So It is better archive zip file then play by foobar.
  • Last Edit: 10 October, 2003, 12:10:15 AM by siorin
Check out http://www.xiph.org/archives/vorbis-dev/20...00308/0004.html, but you might need to compile it yourself. Unless the awesome people that run RareWares are watching, that is.
  • john33
  • Developer
Well, I downloaded and finally managed to get a clean MSVC compile. However, there is some sort of problem in that if I create a chained file using the usual:-
copy /b a.ogg+b.ogg c.ogg, for example and then run c.ogg against oggsplit, I simply get an error message. But if I run the file through oggdropXPd and decode to wav, I get the expected result. Any ideas? Have you tried it yourself?
John
  • dev0
  • Developer
Have you tried the more recent OggSplit 0.1.0?
  • john33
  • Developer
Yes, I have!  Even with the slightly later patch.
John
No, I haven't tried it myself. Maybe it's time to download MinGW so I can look at these things when I'm at home, too...
The first thing that comes to mind is that fopen() needs "rb" and "wb" on DOS successors, rather than simply "r" and "w".
Hmmm. I'll go install MinGW now, and see if I can make any headway.
Yeah, that seems to be it. At least, OggSplit 0.1.0 with the extra patch from later on in the thread, changing "r" to "rb" and "w" to "wb", compiled with MinGW, and run with the -c flag, successfully split the one test file I just created with copy /b. Confirmed identical to the original files with diff.
  • john33
  • Developer
Doh!!!  Braindead, again!!  Recompiled and tested OK. I'll upload to Rarewares in the next few minutes. Thanks Peter.
Edit: Available now.
  • Last Edit: 11 October, 2003, 06:49:43 AM by john33
John
  • Mac
Thanks John & Peter
I have a 140mb chained ogg with 50 streams inside..  when I actually have enough room (140mb free) to split it into individual files I'll give this tool a bash
< w o g o n e . c o m / l o l >
