Topic: The Corrs - No More Cry (Read 3459 times) previous topic - next topic
  • kjoonlee
For test purposes.
METADATA block #0
  type: 0 (STREAMINFO)
  is last: false
  length: 34
  minumum blocksize: 4608 samples
  maximum blocksize: 4608 samples
  minimum framesize: 14 bytes
  maximum framesize: 15862 bytes
  sample_rate: 44100 Hz
  channels: 2
  bits-per-sample: 16
  total samples: 1323000
  MD5 signature: a44f86933e90d611145476ebc541ab7e
METADATA block #1
  type: 3 (SEEKTABLE)
  is last: false
  length: 54
  seek points: 3
    point 0: sample_number=0, stream_offset=0, frame_samples=0
    point 1: sample_number=437760, stream_offset=0, frame_samples=1260078
    point 2: sample_number=880128, stream_offset=0, frame_samples=2494558
METADATA block #2
  type: 4 (VORBIS_COMMENT)
  is last: true
  length: 217
  vendor string: reference libFLAC 1.1.0 20030126
  comments: 7
    comment[0]: ALBUM=In Blue Special Edition
    comment[1]: DISCNUMBER=2
    comment[2]: TRACKNUMBER=2
    comment[3]: TITLE=No More Cry
    comment[4]: VERSION=Acoustic
    comment[5]: replaygain_track_gain=-6.83 dB
    comment[6]: replaygain_track_peak=0.99993896
bitrate = 1000
samplerate = 44100
channels = 2
bitspersample = 16
codec = FLAC
replaygain_track_gain = -6.83 dB
replaygain_track_peak = 0.99993896
1323000 samples @ 44100Hz
  • Last Edit: 22 September, 2003, 09:23:21 AM by kjoonlee
To test what?
  • kjoonlee
Someone said he would be very pleased if he could use this sample in a codec test of his.
  • 2Bdecided
Thanks kjoonlee - that's perfect. No need to be so cryptic though - the test won't be a secret!
I wonder what the other 12 people who downloaded it wanted it for?
David.
P.S. No I won't buy the CD - I already have the regular CD and DVD-A versions - I refuse to buy the album a third time, even for some extra tracks!
  • Atlantis
I was the first: I download everything i see
BTW: what test is?
Vital papers will demonstrate their vitality by spontaneously moving from where you left them to where you can't find them.
