Topic: 64kbps public listening test (Read 50537 times) previous topic - next topic
  • Mac
Reply #100
7R File: .\Sample09\Polonaise_8.wav
7R Rating: 3.0
7R Comment: It all sounds subtly different.  Couldn't tell on a casual listen through.
I noticed on a couple of samples that if you listened through the whole 20 seconds, Vorbis sounded just fine to me, but if you start listening to short 1 second chunks and concentrated, you noticed a staggering difference between it and the original?
Would it be over-optimistic to suggest this was the intention, make a codec that sounds better in every-day use than on short bursts of concentration?
ps. Roberto - 1) Awesome test, badbwoy! 2) Thankyou for 4 mentions on the funnies list
  • Last Edit: 24 September, 2003, 05:05:23 AM by Mac
< w o g o n e . c o m / l o l >
  • ScorLibran
  • Banned
Reply #101
Interesting concept...Subliminal Transparency.  You only *think* it's transparent if you hear it enough.
Wait...my whole collection is in Vorbis....-q 4.25..............Those Vorbis programmers fooled me!!!.......:fingers in ears:.....LALALALALALALALA.....not listening....not thinking about this.....it really IS transparent....all of it!!!......it's not just subliminal....
Especially worrisome considering I rated Vorbis below the low-anchor overall (8th out of 8).
But seriously, I'm going to train myself to hear artifacts better before I pull out all my CDs and the FLAC encoder.  This test was a *big* wake up call for me.  But it's actually a big difference between 64kbps nominal and 136kbps nominal, so I'm not losing sleep either.
  • webwonk
Reply #102
Which CODEC was used for the Real test. Cook or ATRC0? Thanks.
webwonk
  • ErikS
Reply #103
webwonk
AFAIK Cook.
see http://www.hydrogenaudio.org/forums/index....showtopic=13127
  • rjamorim
Reply #104
AFAIK Cook.
Yes, Cook.
AKA Real Audio Gecko.
http://www.rarewares.org
  • Garf
  • Developer (Donating)
Reply #105
  • Last Edit: 24 September, 2003, 12:07:35 PM by Garf
  • c_haese
  • Developer
Reply #106
Split Vorbis discussion/flamewar
I'd like to point out, for the record, that it was not I who started the flaming.
  • Garf
Reply #107
Nobody ever claimed so.
  • JohnV
  • Developer
Reply #108
Well.. I don't think there was/is any flamewar, we are strictly discussing in non-personal level. However, I'm expecting the promised clarification to the patent search issue (meaning documents or such online):
Please continue this discussion here (thread split):
http://www.hydrogenaudio.org/forums/index....showtopic=13531
Juha Laaksonheimo
  • phong
Reply #109
...I've produced a spreadsheet of the results.  You can download it in OpenOffice (yay!) format here.  You can also get it in Excell (boo!) format here....
I've updated the spreadsheet - it now has a section on the far right that lets you get a summary of all the results of any one listener and compare to the averages.  Just enter a listener's handle (where it says "garf" in blue right now) and it will show all their scores and the difference between their scores and the averages.  It even highlights lows/highs for each codec in different colors.
ps: I don't mean to pick on Garf.  :-)  His scores were quite average so they produce a nice "typical" chart.
  • Last Edit: 25 September, 2003, 01:55:14 AM by phong
I am *expanding!*  It is so much *squishy* to *smell* you!  *Campers* are the best!  I have *anticipation* and then what?  Better parties in *the middle* for sure.
http://www.phong.org/
  • tigre
Reply #110
Cool thing to play with - thanks!
  • saratoga
Reply #111
Any reason the link doesn't work?
I'd really like to take a look at the site.
http://audio.ciara.us/test/64test/results.html
  • verloren
Reply #112
No reason at all - I just tried it and it came up fine.  Perhaps you could post what happens and I'll try to sort it out.
Cheers, Paul
audio.ciara.us sponsor
  • Garf
Reply #113
If I interpret the results correctly, for me HE-AAC is a clear winner with MP3Pro second, followed at some distance by WMA and only then Vorbis, which did only marginally better than RealAudio.
There's a goofy result in that I rated the low anchor up to 5.0 in one test, while giving the high anchor a 3.8.
  • Last Edit: 04 October, 2003, 06:59:19 PM by Garf
  • ScorLibran
  • Banned
Reply #114
I had something similar, rating the low anchor at 5.0 on one sample, though the lowest rating I gave the high anchor was a 4.3.
Ironic it seems to me is that I rated Vorbis at this bitrate the lowest overall, slightly under the low anchor.  Ironic, since my entire collection is encoded in Vorbis, although at a bitrate that I tested on many tracks and found to be generally transparent to my ears.  Someone proposed that it may be that since I have listened to more Vorbis than any other codec recently, I may be more "tuned" to pick out artifacts with Vorbis.  I would have thought it would be the other way around...automatically tuning out Vorbis artifacts more than those of other codecs since I listen to Vorbis encodings every day.
Interesting psychoacoustic phenomena either way...
  • webwonk
Reply #115
Thanks to Both ErikS & rjamorim for their replies to my query (Was the Real CODEC cook or atrc0 - it was Cook), now the follow-up. Was there a reason for not including ATRC0 (Real's 66kbs ATRAC3 implementation) - besides, of course, the obvious difference of 66 and 64kbs. As they are so close, It would be interesting to see how ATRC0 compares to HE-AAC. Has anyone tried this? Any insight would be most appreciated. Thanks again for a very interesting test and subsequent discussion.
Sincerely,
Webwonk.
  • tigre
Reply #116
There is a pre-test thread with discussion about what codecs to include etc, you might find some answers there.
