Topic: How much better is aac than ac3 ? (Read 9737 times) previous topic - next topic
i got a clear understanding from this forum that AAC woulde provide better audio quality then AC3 (alias Dolby Digital)
But how big is the difference..roughly ???
1: If i had acces to the uncompressed 5.1 sound for a movie
at what bitrate would psytell aac give a quality equal to 384kbits AC3 ?
2: If i was to compress a 384kbits ac3 stream. How low could i get bitrates befores big loss of audio quality* and/or loss of channels ?
*compared to running stereo at 128 mp3-abr
What i was hoping for was to get 5.1 audio below 256kbits but it almost sound like to few bits..
[edit]
Spelling errors corrected
Sven Bent - Denmark
[edit]
I would compare 448 kbps AC3 with 256 kbps MPEG-4 AAC for normal music. With transient signals
AC3 has much bigger problems than MP3, some examples also sounds at 640 kbps worse.
See compare of time resolution at my webpage.
--  Frank Klemm
Take a look at:
http://mpeg.telecomitalialab.com/quality_tests.htm
Document of interest:
http://mpeg.telecomitalialab.com/public/NBC_results.zip
(NBC encoder used was older version of MPEG AAC - current encoders are probably much better)
Codec and bitrate (kbit/s)   Encoding/decoding verification by:   Bitrate verification by:   Verified bitrate (kbit/s)
MPEG-2 NBC (320)   DMV, University of   Five Bats   320
MPEG-2 NBC (256)   Hanover and Five Bats      256
MPEG-2 NBC (224)         224
MPEG-2 NBC - low complexity (320)         320
Dolby AC-3 (640)   DMV, Five Bats, BBC   Not evaluated   Not evaluated
Dolby AC-3 (512)   Verification not possible (see section 2.3)   Not evaluated   Not evaluated
MPEG-2 Layer II (640)   Deutsche Telekom and   Deutsche Telekom   640
MPEG-2 Layer II (512)   Deutsche Thomson Brandt      512
I will use some 2 channels considerations (all assuming good implementations):
Ac3 192 is slighlty better than mp2 192. Aac 96 main profile should be equivalent to mp2 192.
I don't know if multichannel is better used by aac or ac3, but for 2 channels only, I think that you could consider that for the same quality aac should be 60% of an ac3 size
thanx for the info
Sven Bent - Denmark
