Topic: Frequency Cutoff Point (Read 4106 times) previous topic - next topic
You can test your hearing with the tone generators in Winamp or Foobar.
Flac stuff is here.
Below is a 17,500Hz pure tone.
  • Last Edit: 11 September, 2003, 10:52:25 PM by pseudoacoustic
  • gutzalpus
When I use foobar's tone generator, I get some sort of weird noises once I hit about 18,500hz.  Is there a flaw in the tone generator or is it likely an issue with my setup?
I can hear everything up to 18,500 so I'd like to be able to test a little further than that to see what happens...  of course in order to hear 18,000+ I need to jack the volume all the way up to max on my sound card.
  • tigre
Probably the soundcard is the guilty. Try 48Khz sampling rate, changing windows' audio settings (something like "sampling rate conversion quality" - don't know the exact name in english windows version) or lowering volume in mixer (Wave / Volume Controll).
Edit:
Pseudoacoustic,
according to CoolEdit's spectral view and frequency analysis your sample contains more than only 17500Hz (-5.11 dB):
1898 Hz: -77.41dB
6 lower peaks in 3000-10000 Hz range
10990 Hz: -73.5dB
14900 Hz: -73.05dB
3 peaks > 17500 Hz, among them
21390 Hz: -16.39dB
The lower frequency content is clearly audible so better use the sample I've uploaded.
  • Last Edit: 12 September, 2003, 05:13:33 AM by tigre
  • tigre
2 More "How high can you hear" threads:
How high can you hear?
How high can you hear (with music & lowpass), ABX required (with real music samples)
  • KikeG
Beware of your tweeters! With continuous, loud, high frequency tones, it's very easy to fry your speaker tweeters, has happened to some people here. Better use short, faded-in and out, test tones.
  • Last Edit: 23 September, 2003, 11:16:42 AM by KikeG
  • tigre
Maybe like this (-> sample):
  • KikeG
That one would be good, good editing. However, I would try to space a little bit more the tone bursts, just to be safer about not frying the tweeters.
