Topic: static in eac rips (Read 6343 times) previous topic - next topic
static in eac rips
Got 6 new cd's for Christmas and trying  to rip them to my computer.  I  am using Exact Audio Copy v1.8.  New install of Win 11, AMD processor new, updated all drivers and keep getting the same results.  Playback on multiple machines and multiple different players with same result.  Any advice on where to look from here is appreciated.
Re: static in eac rips
Try with CueTools CD Ripper. Or play with rip commands for your CD drive in EAC, it may be something weird about it.
Do CDs have copy protection feature? Check online for info.
TAPE LOADING ERROR
After any rip, the first step is to verify the results using AccurateRip/CTDB (assuming a commercial CD).
Do I understand correctly that you have an entirely new setup and this is the first time you are extracting audio CDs on it? Check the drive options in EAC, there is the "Big Endian byte order" option under the Drive tab. Perhaps it has a wrong value, wrong endianess would definitely cause noise.
Thank you for your reply.  It's a new SuperMicro put in service about six months ago.  There is a fresh installation of Exact Audio Copy v1.8.  I have always (over 10 years) used EAC fresh from the box to rip my cd's.  Never had an issue nor have I ever done any configuration changes to the program until recently when it was running dog slow.  I changed the bit rate to 128.
Someone mentioned checking "Drive Options" so here's a screen shot of that.
OS Name   Microsoft Windows 11 Home
Version   10.0.26100 Build 26100
Other OS Description    Not Available
OS Manufacturer   Microsoft Corporation
System Name   DESKTOP-VIH62FD
System Manufacturer   Supermicro
System Model   AS -3015A-I
System Type   x64-based PC
System SKU   To be filled by O.E.M.
Processor   AMD Ryzen 9 7950X 16-Core Processor, 4501 Mhz, 16 Core(s), 32 Logical Processor(s)
BIOS Version/Date   American Megatrends International, LLC. 1.1, 8/25/2023
SMBIOS Version   3.5
Embedded Controller Version   255.255
BIOS Mode   UEFI
BaseBoard Manufacturer   Supermicro
BaseBoard Product   H13SAE-MF
BaseBoard Version   1.00
Platform Role   Desktop
Secure Boot State   Off
PCR7 Configuration   Elevation Required to View
Windows Directory   C:\WINDOWS
System Directory   C:\WINDOWS\system32
Boot Device   \Device\HarddiskVolume1
Locale   United States
Hardware Abstraction Layer   Version = "10.0.26100.1"
User Name   DESKTOP-VIH62FD\Rick
Time Zone   Eastern Standard Time
Installed Physical Memory (RAM)   32.0 GB
Total Physical Memory   31.1 GB
Available Physical Memory   13.0 GB
Total Virtual Memory   34.2 GB
Available Virtual Memory   986 MB
Page File Space   3.00 GB
Page File   C:\pagefile.sys
Kernel DMA Protection   Off
Virtualization-based security   Running
Virtualization-based security Required Security Properties
Virtualization-based security Available Security Properties   Base Virtualization Support, DMA Protection, UEFI Code Readonly, SMM Security Mitigations 1.0, Mode Based Execution Control
Virtualization-based security Services Configured   Hypervisor enforced Code Integrity
Virtualization-based security Services Running   Hypervisor enforced Code Integrity
App Control for Business policy   Enforced
App Control for Business user mode policy   Off
Automatic Device Encryption Support   Elevation Required to View
A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Drive is the next tab over. I circled the setting @Case  mentioned.
korth
