Topic: Can't replaygain WAV files with 0.7rc8 (Read 3270 times) previous topic - next topic
  • Atlantis
INFO (CORE) : attempting to edit file info : file://E:\tmp\test\Illinois.wav
WARNING (CORE) : file info update failure on : file://E:\tmp\test\Illinois.wav
Files are not read-only and not locked by fb2k or other apps.
Anyone can confirm?
Thanks & bye.
edit = rg & metadata are added / edited correctly, but the console pops up with the error above mentioned.
  • Last Edit: 29 August, 2003, 11:27:41 AM by Atlantis
Vital papers will demonstrate their vitality by spontaneously moving from where you left them to where you can't find them.
  • TMA
Maybe you have to enable tag writing for .wav-files down in the standard input config...
  • Atlantis
Turned on tag writing and it works.
Is it intended?
  • Peter
  • Administrator
Is it intended?
Yes.
  • Atlantis
Does it help to have database enabled and the "don't write modified tags to files" option checked, in this case?
I mean, without having enabled the WAV tag writing option.
Are these similar functions?
Tia & bye
